Is rtems available on a 4-cores cortex A72 (ARM-v8a) bsp?
Fri Jul 24 17:44:37 UTC 2020
On Fri, Jul 24, 2020 at 2:28 AM smallphd at aliyun.com <smallphd at aliyun.com> wrote:
> xilinx-zynqmp BSP has a ARM cortex A53 processor. Is it a ARMv8-A architeture?
https://developer.arm.com/ip-products/processors/cortex-a/cortex-a53
> ________________________________
> From: Sebastian Huber
> Date: 2020-07-24 12:49
> To: smallphd at aliyun.com; joel
> CC: devel
> Subject: Re: Is rtems available on a 4-cores cortex A72 (ARM-v8a) bsp?
> On 24/07/2020 03:09, smallphd at aliyun.com wrote:
> > 32-bit mode is OK.
> > Does it fully support SMP and MMU in this bsp?
> RTEMS supports SMP on ARMv7-A and in particular the xilinx-zynqmp BSP.
> The MMU is statically set up. RTEMS doesn't support processes with
> virtual memory.
> devel mailing list
> devel at rtems.org
