Segmentation fault whie setting up translation table for small pages in ARMv7 MMU
Utkarsh Rai
utkarsh.rai60 at gmail.com
Sun Jul 26 12:03:46 UTC 2020
Hello,
I was facing issues while changing the memory entries for a section. The
thread can be viewed here
<https://lists.rtems.org/pipermail/devel/2020-July/060884.html>. The error
is most probably due to the fact that while I change the memory entry of my
desired region it ends up changing the memory permission of the entire 1Mb
section, which causes fatal errors.
To prevent this, I decided to set up translation table entries in
small-page format. Unfortunately, during the static initialization of the
translation table, the qemu hangs up (I am using Xilinx-zynq BSP). On
stepping through the debugger I encounter a segmentation fault.
Can someone please point me in the right direction? This is the final issue
that I have to resolve before I send my patches.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200726/325cf2df/attachment.html>
