[GSoC 2020]: Weekly thread: Preparing RSB recipies for EPICS
Chris Johns
chrisj at rtems.org
Sun Jul 26 23:59:05 UTC 2020
On 22/7/20 6:16 am, Mritunjay Sharma wrote:
> I cancelled the earlier message because the log file size was very big
> and could not be posted in the devel list.
OK. If we need a large log it is normally compressed and loaded onto a server
somewhere and a link provided.
> [UPDATE]: Applying PATCH for RTEMS-pc386 support to EPICS and
> making other changes in code worked and EPICS7 was successfully built
> and installed using the RSB recipe.
Yes the PC patch ... more on this below ...
> Tha changes that made it work:
> diff --git a/rtems/config/epics/epics-7-1.cfg b/rtems/config/epics/epics-7-1.cfg
> new file mode 100644
> index 00000000..ed1f768b
> --- /dev/null
> +++ b/rtems/config/epics/epics-7-1.cfg
> @@ -0,0 +1,28 @@
> +# EPICS 3afec267ab08568ea454789e562450b00feea5c0
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +#%include %{_configdir}/rtems-bsp.cfg
> +# EPICS Version
> +%define epics_version 3afec267ab08568ea454789e562450b00feea5c0
> +#%hash sha512 epics-%{ntp_version}.tar.gz
> 8d76fc7e92b2ea6dd5031e6030a7aba4ff6fb3e19d3bc0153852509861be5d0960e70604814163caedb81f8315a451d78371f99634a50b55cfe1cbd2c69e3046
> +# Patch for RTEMS support.
> +%patch add epics -p1
> file:///home/mritunjay/development/rtems/src/rsb_GSoC/rtems/patches/0001-Added-Support-for-RTEMS-pc386.patch
I cannot see this file if it is local to your machine.
> +#%hash sha512 rtems-ntp-4.2.6p5.diff
> 257223d207d0b77cde2b9d7add22e3b9d657b58998411d2e20d0b1adf36910be21f1277386c54c34f5d9616fccd29f721d007295708047ea7ae0270a00be25a0
> +# EPICS Build configuration
> +%include %{_configdir}/epics-7-1.cfg
> diff --git a/rtems/config/epics/epics-base.bset b/rtems/config/epics/epics-base.bset
> index 00000000..550daad0
> --- /dev/null
> +++ b/rtems/config/epics/epics-base.bset
> @@ -0,0 +1,26 @@
> +# Build set for EPICS
> +%define release 1
> +# RTEMS Version
> +%define rtems_version 5
> +# The RTEMS URL paths.
> +%include rtems-urls.bset
> +# The RTEMS Package defines
> +%include rtems-package.bset
> +# Build EPICS.
> +epics/epics-7-1.cfg
> \ No newline at end of file
> diff --git a/source-builder/config/epics-7-1.cfg
> b/source-builder/config/epics-7-1.cfg
> index ea25f284..b18f62bd 100644
> --- a/source-builder/config/epics-7-1.cfg
> +++ b/source-builder/config/epics-7-1.cfg
> @@ -31,6 +31,7 @@ URL: https://epics.mpg.de/
> source_dir_epics="epicsBaseOwnPlayground-%{epics_version}"
> %source setup epics -q -n epicsBaseOwnPlayground-%{epics_version}
> + %patch setup epics -p1
> cd ${build_top}
> @@ -43,10 +44,7 @@ URL: https://epics.mpg.de/
> %{__make} PREFIX=%{_prefix}
> - ./configure \
> - --prefix=%{_prefix}
> - %{__make} %{?_smp_mflags}
> + #%{__make} %{?_smp_mflags}
> cd ${build_top}
> The changes can also be looked here:
> https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support?expand=1
> On Tue, Jul 21, 2020 at 10:23 PM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> On Tue, Jul 21, 2020 at 10:42 AM Mritunjay Sharma
> <mritunjaysharma394 at gmail.com <mailto:mritunjaysharma394 at gmail.com>> wrote:
> > [UPDATE]: The error was actually a mismatch of names which was fixed with
> the following
> > changes:
> > index fe1fb458..ea25f284 100644
> > @@ -10,7 +10,7 @@
> > -Name: epics-%{epics_version}-%{_host}-%{release}
> > +Name: epicsBaseOwnPlayground-%{epics_version}-%{_host}-%{release}
> > Summary: EPICS v%{epics_version} for target %{_target} on host %{_host}
> > Version: %{epics_version}
> > Release: %{release}
> > @@ -19,7 +19,8 @@ URL: https://epics.mpg.de/
> > # Source
> > -%source set epics --rsb-file=epics-%{epics_version}.zip
> https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%{epics_version}.zip
> <https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%%7Bepics_version%7D.zip>
> > +%source set epics
> --rsb-file=epicsBaseOwnPlayground-%{epics_version}.tar.gz
> https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%{epics_version}.tar.gz
> <https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%%7Bepics_version%7D.tar.gz>
> > # Prepare the source code.
> > @@ -27,25 +28,20 @@ URL: https://epics.mpg.de/
> > %prep
> > build_top=$(pwd)
> > - source_dir_epics="epics-%{epics_version}"
> > + source_dir_epics="epicsBaseOwnPlayground-%{epics_version}"
> > - %source setup epics -q -n epics-%{epics_version}
> > + %source setup epics -q -n epicsBaseOwnPlayground-%{epics_version}
> We will eventually want this to work from the upstream EPICS.
> Yes, I think we need to discuss it with Heinz when he is available.
> > cd ${build_top}
> > %build
> > build_top=$(pwd)
> > - %{build_directory}
> > - mkdir -p ${build_dir}
> > - cd ${build_dir}
> > + cd ${source_dir_epics}
> > - %{host_build_flags}
> > + %{build_build_flags}
> > - #cd ${source_dir_epics}
> > + %{__make} PREFIX=%{_prefix}
> > ./configure \
> > --prefix=%{_prefix}
> > After this, I ran the command
> > `../source-builder/sb-builder --prefix=/home/mritunjay/development
> --log=log_epics epics-7-1 --trace`
> > again. The error that has come now was expected because the changes I made
> in epicsBaseOwnPlayground/configure file
> > were done manually and here it has to be done through a script. The
> changes that I did manually were;
> >> in epics-base/configure/CONFIG_SITE
> >> set
> >> CROSS_COMPILER_TARGET_ARCHS=
> > What I entered:
> > CROSS_COMPILER_TARGET_ARCHS= RTEMS-pc386-qemu
> >> e.g. RTEMS-pc386
> >> or RTEMS-xilinx_zynq_a9_qemu
> >> in epics-base/configure/os there must be a file for the target used,
> >> e.g.
> >> CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
> >> or
> >> CONFIG.Common.RTEMS-pc386
> > Checked. CONFIG.Common.RTEMS-pc386 was there
> >> Then you have to set in configure/os/CONFIG_SITE.Common.RTEMS
> >> where to find RTEMS:
> >> # Where to find RTEMS
> >> # APS:
> >> #RTEMS_VERSION = 4.10.2
> >> #RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
> > In my system, I entered this:
> > #FHI
> > RTEMS_VERSION = 5
> > RTEMS_BASE = /home/mritunjay/development/rtems/$(RTEMS_VERSION)
> > I have a doubt on how to implement the above changes in the
> `source-builder/config/epics-7-1.cfg` to make it work.
> > Do we have to write a patch? And what will be the best way to do it?
> This is a good question. These configuration changes need to be
> populated somehow based on the target being built. If this is only
> doable by writing files directly, then we'll probably need a way to
> apply patches for each different target. This seems unwieldy, so
> further thought should be considered on how to configure EPICS based
> on the RTEMS BSP build.
> You can start with a manually-created patch file, but eventually we
> need something that can be used across different BSPs / architectures.
> The manually-created patch file has worked.
Sure but I cannot find it online. Have you published it somewhere? You blog
makes no reference to it or the PC build of EPICS you did by hand.
> Now, what can be done to make it work across different BSPs / architectures?
I would need to see what is needed.
> Will writing similar patches for each architecture should be our way?
Good question, I do not know.
> And I guess in the #FHI section as well we have to do something so that user
> can add the path interactively where the user's BSP are installed?
> Would you like to give any other feedback/suggestions?
I need more information.
Thanks
