[PATCH v2 2/2] break fenv.c file to function files
    Sebastian Huber
    Mon Jul 27 04:49:44 UTC 2020
On 25/07/2020 19:15, Eshan dhawan wrote:
> Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
>   newlib/libc/machine/arm/sys/fenv.h        |   8 +
>   newlib/libm/machine/arm/Makefile.am       |   6 +-
>   newlib/libm/machine/arm/Makefile.in       |  34 +++-
>   newlib/libm/machine/arm/fe_dfl_env.c      |  38 +++-
>   newlib/libm/machine/arm/feclearexcept.c   |  45 ++++-
>   newlib/libm/machine/arm/fedisableexcept.c |  47 +++++
>   newlib/libm/machine/arm/feenableexcept.c  |  48 +++++
>   newlib/libm/machine/arm/fegetenv.c        |  42 +++-
>   newlib/libm/machine/arm/fegetexcept.c     |  44 +++++
>   newlib/libm/machine/arm/fegetexceptflag.c |  46 ++++-
>   newlib/libm/machine/arm/fegetround.c      |  49 ++++-
>   newlib/libm/machine/arm/feholdexcept.c    |  47 ++++-
>   newlib/libm/machine/arm/fenv.c            | 223 ----------------------
>   newlib/libm/machine/arm/feraiseexcept.c   |  44 ++++-
>   newlib/libm/machine/arm/fesetenv.c        |  43 ++++-
>   newlib/libm/machine/arm/fesetexceptflag.c |  47 ++++-
>   newlib/libm/machine/arm/fesetround.c      |  46 ++++-
>   newlib/libm/machine/arm/fetestexcept.c    |  45 ++++-
>   newlib/libm/machine/arm/feupdateenv.c     |  50 ++++-
>   19 files changed, 670 insertions(+), 282 deletions(-)
>   create mode 100644 newlib/libm/machine/arm/fedisableexcept.c
>   create mode 100644 newlib/libm/machine/arm/feenableexcept.c
>   create mode 100644 newlib/libm/machine/arm/fegetexcept.c
>   delete mode 100644 newlib/libm/machine/arm/fenv.c
> diff --git a/newlib/libc/machine/arm/sys/fenv.h b/newlib/libc/machine/arm/sys/fenv.h
> index 70bd57be4..8712b2f33 100644
> --- a/newlib/libc/machine/arm/sys/fenv.h
> +++ b/newlib/libc/machine/arm/sys/fenv.h
> @@ -62,6 +62,14 @@ typedef int fexcept_t;
>   #define	FE_DOWNWARD		0x00800000
>   #define	FE_TOWARDZERO		0x00c00000
> +#ifndef __SOFTFP__
> +#define	vmrs_fpscr(__r)	__asm __volatile("vmrs %0, fpscr" : "=&r"(__r))
> +#define	vmsr_fpscr(__r)	__asm __volatile("vmsr fpscr, %0" : : "r"(__r))
> +#define	_FPU_MASK_SHIFT	8
> +#define	_ROUND_MASK	(FE_TONEAREST | FE_DOWNWARD | \
> +			 FE_UPWARD | FE_TOWARDZERO)
> +#endif
I would still prefer to have this in an internal header file
"newlib/libm/machine/arm/_fenv.h" which is included via #include "_fenv.h".
If you really want to have it visible via <fenv.h>, then the vm*()
should at least be renamed to _vmrs_fpscr() and _vmsr_fpscr().
> diff --git a/newlib/libm/machine/arm/fe_dfl_env.c b/newlib/libm/machine/arm/fe_dfl_env.c
> index 8cbee7771..07aee8e7c 100644
> --- a/newlib/libm/machine/arm/fe_dfl_env.c
> +++ b/newlib/libm/machine/arm/fe_dfl_env.c
> @@ -1,7 +1,37 @@
> - * SPDX-License-Identifier: BSD-2-Clause
> + * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
> - * (c) Copyright 2019 Joel Sherrill <joel at rtems.org>
> + * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
> + * Copyright (c) 2013 Andrew Turner <andrew at FreeBSD.ORG>
> + * All rights reserved.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> + * $FreeBSD$
> -#include "../../fenv/fenv_stub.c"
> +#include <fenv.h>
> +  fenv_t __fe_dfl_env = { 0 };
> +  const fenv_t *_fe_dfl_env = &__fe_dfl_env;
Why indent?
There is a blank line at the end of the file. Please remove the blank
line at the end of all files from this patch.
