[PATCH v2 2/2] break fenv.c file to function files
Eshan Dhawan
eshandhawan51 at gmail.com
Mon Jul 27 06:11:32 UTC 2020
> On 27-Jul-2020, at 10:19 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 25/07/2020 19:15, Eshan dhawan wrote:
>> Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
>> newlib/libc/machine/arm/sys/fenv.h | 8 +
>> newlib/libm/machine/arm/Makefile.am | 6 +-
>> newlib/libm/machine/arm/Makefile.in | 34 +++-
>> newlib/libm/machine/arm/fe_dfl_env.c | 38 +++-
>> newlib/libm/machine/arm/feclearexcept.c | 45 ++++-
>> newlib/libm/machine/arm/fedisableexcept.c | 47 +++++
>> newlib/libm/machine/arm/feenableexcept.c | 48 +++++
>> newlib/libm/machine/arm/fegetenv.c | 42 +++-
>> newlib/libm/machine/arm/fegetexcept.c | 44 +++++
>> newlib/libm/machine/arm/fegetexceptflag.c | 46 ++++-
>> newlib/libm/machine/arm/fegetround.c | 49 ++++-
>> newlib/libm/machine/arm/feholdexcept.c | 47 ++++-
>> newlib/libm/machine/arm/fenv.c | 223 ----------------------
>> newlib/libm/machine/arm/feraiseexcept.c | 44 ++++-
>> newlib/libm/machine/arm/fesetenv.c | 43 ++++-
>> newlib/libm/machine/arm/fesetexceptflag.c | 47 ++++-
>> newlib/libm/machine/arm/fesetround.c | 46 ++++-
>> newlib/libm/machine/arm/fetestexcept.c | 45 ++++-
>> newlib/libm/machine/arm/feupdateenv.c | 50 ++++-
>> 19 files changed, 670 insertions(+), 282 deletions(-)
>> create mode 100644 newlib/libm/machine/arm/fedisableexcept.c
>> create mode 100644 newlib/libm/machine/arm/feenableexcept.c
>> create mode 100644 newlib/libm/machine/arm/fegetexcept.c
>> delete mode 100644 newlib/libm/machine/arm/fenv.c
>> diff --git a/newlib/libc/machine/arm/sys/fenv.h b/newlib/libc/machine/arm/sys/fenv.h
>> index 70bd57be4..8712b2f33 100644
>> --- a/newlib/libc/machine/arm/sys/fenv.h
>> +++ b/newlib/libc/machine/arm/sys/fenv.h
>> @@ -62,6 +62,14 @@ typedef int fexcept_t;
>> #define FE_DOWNWARD 0x00800000
>> #define FE_TOWARDZERO 0x00c00000
>> +#ifndef __SOFTFP__
>> +#define vmrs_fpscr(__r) __asm __volatile("vmrs %0, fpscr" : "=&r"(__r))
>> +#define vmsr_fpscr(__r) __asm __volatile("vmsr fpscr, %0" : : "r"(__r))
>> +#define _FPU_MASK_SHIFT 8
>> +#define _ROUND_MASK (FE_TONEAREST | FE_DOWNWARD | \
>> + FE_UPWARD | FE_TOWARDZERO)
>> +#endif
> I would still prefer to have this in an internal header file "newlib/libm/machine/arm/_fenv.h" which is included via #include "_fenv.h".
> If you really want to have it visible via <fenv.h>, then the vm*() should at least be renamed to _vmrs_fpscr() and _vmsr_fpscr().
I am not able to get you point could you provide a little detail
I understood that you are saying that create an alternative _fenv.h in machine/arm in libm.
But I am not able to understand why.
If the symbols are visible with fenv.h than does that cause any issues?
Or how does renaming them causes any change?
>> diff --git a/newlib/libm/machine/arm/fe_dfl_env.c b/newlib/libm/machine/arm/fe_dfl_env.c
>> index 8cbee7771..07aee8e7c 100644
>> --- a/newlib/libm/machine/arm/fe_dfl_env.c
>> +++ b/newlib/libm/machine/arm/fe_dfl_env.c
>> @@ -1,7 +1,37 @@
>> - * SPDX-License-Identifier: BSD-2-Clause
>> + * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
>> - * (c) Copyright 2019 Joel Sherrill <joel at rtems.org>
>> + * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
>> + * Copyright (c) 2013 Andrew Turner <andrew at FreeBSD.ORG>
>> + * All rights reserved.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + * notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + * notice, this list of conditions and the following disclaimer in the
>> + * documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> -#include "../../fenv/fenv_stub.c"
>> +#include <fenv.h>
>> + fenv_t __fe_dfl_env = { 0 };
>> + const fenv_t *_fe_dfl_env = &__fe_dfl_env;
> Why indent?
> There is a blank line at the end of the file. Please remove the blank line at the end of all files from this patch.
I will correct that :)
