[PATCH v2 1/2] Changed ARM fenv support similar to RISCV
Eshan Dhawan
eshandhawan51 at gmail.com
Mon Jul 27 05:38:15 UTC 2020
> On 27-Jul-2020, at 10:21 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 25/07/2020 19:15, Eshan dhawan wrote:
>> Removed soft float files
>> arm/fenv.c: Fix use of defines and format
>> Fix the build. Remove superfluous code. Remove parameter names in
>> the header file. Move implementation details out of the header file.
>> Patch By : Eshan Dhawan<Eshandhawan51 at gmail.com> & sebastian huber
>> Signed-off-by: Eshan dhawan<eshandhawan51 at gmail.com>
> I think this commit message is not really an improvement compared to the potential v1 of this patch:
> https://sourceware.org/pipermail/newlib/2020/017780.html
> How does this patch differ from the one sent to the Newlib list?
This is the same patch as on the newlib list.
It’s in this series just that the patches could be directly applied to the master.
Since the patch on the newlib isn’t yet merged
