[PATCH v2 1/2] Changed ARM fenv support similar to RISCV
Mon Jul 27 05:43:39 UTC 2020
On 27/07/2020 07:38, Eshan Dhawan wrote:
>> On 27-Jul-2020, at 10:21 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 25/07/2020 19:15, Eshan dhawan wrote:
>>> Removed soft float files
>>> arm/fenv.c: Fix use of defines and format
>>> Fix the build.  Remove superfluous code.  Remove parameter names in
>>> the header file.  Move implementation details out of the header file.
>>> Patch By : Eshan Dhawan<Eshandhawan51 at gmail.com>  & sebastian huber
>>> Signed-off-by: Eshan dhawan<eshandhawan51 at gmail.com>
>> I think this commit message is not really an improvement compared to the potential v1 of this patch:
>> https://sourceware.org/pipermail/newlib/2020/017780.html
>> How does this patch differ from the one sent to the Newlib list?
> This is the same patch as on the newlib list.
The same patch except the commit message. Why did you change the commit
message?
> It’s in this series just that the patches could be directly applied to the master.
> Since the patch on the newlib isn’t yet merged
Ok, good. Could you please address the minor issues in the patch set and
send a v3 to the RTEMS list.
