Need help in writing the Strong APA code
Richi Dubey richidubey at gmail.com
Mon Jul 27 12:34:30 UTC 2020
I should have gone through the definition before asking for help.
Without RTEMS_DEBUG, _Assert() does nothing
#else
  #define _Assert( _e ) ( ( void ) 0 )
Thank you for your help.
On Mon, Jul 27, 2020 at 4:33 PM Sebastian Huber <
> On 27/07/2020 10:40, Richi Dubey wrote:
> > Hi,
> > When I am compiling my current code, I am getting the following
> > compiler warning:
> /home/richi/quick-start/src/rtems/c/src/../../cpukit/score/src/schedulerstrongapa.c:
> > In function '_Scheduler_strong_APA_Extract_from_ready':
> /home/richi/quick-start/src/rtems/c/src/../../cpukit/score/src/schedulerstrongapa.c:400:37:
> > warning: variable 'self' set but not used [-Wunused-but-set-variable]
> >    Scheduler_strong_APA_Context     *self;
> > This warning refers to the following code:
> https://github.com/richidubey/rtems/blob/3a9843f61bbd547d150d2ee2d791668cfb5aa282/cpukit/score/src/schedulerstrongapa.c#L415
> > We can see that the self variable is used to get the status of the
> > chain, why would I get such a warning then?
> void _Scheduler_strong_APA_Extract_from_ready(
>    Scheduler_Context *context,
>    Scheduler_Node    *node_to_extract
>    Scheduler_strong_APA_Node        *node;
>    self = _Scheduler_strong_APA_Get_self( context );
>    node = _Scheduler_strong_APA_Node_downcast( node_to_extract );
>    _Assert( _Chain_Is_empty(self->allNodes) == false );
>    _Assert( _Chain_Is_node_off_chain( &node->Node ) == false );
>     _Chain_Extract_unprotected( &node->Node );    //Removed from allNodes
>     _Chain_Set_off_chain( &node->Node );
> It is only used in the _Assert(). I guess you build without the
> configure option --enable-rtems-debug? During development it is useful
> to enable the RTEMS_DEBUG support.
> You should not compare boolean values against true or false. Just write
> _Assert( !_Chain_Is_empty(self->allNodes) );
> for example.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200727/dba53a16/attachment.html>
