Need help in writing the Strong APA code
Sebastian Huber
Mon Jul 27 11:03:44 UTC 2020
On 27/07/2020 10:40, Richi Dubey wrote:
> Hi,
> When I am compiling my current code, I am getting the following
> compiler warning:
> /home/richi/quick-start/src/rtems/c/src/../../cpukit/score/src/schedulerstrongapa.c:
> In function '_Scheduler_strong_APA_Extract_from_ready':
> /home/richi/quick-start/src/rtems/c/src/../../cpukit/score/src/schedulerstrongapa.c:400:37:
> warning: variable 'self' set but not used [-Wunused-but-set-variable]
> Scheduler_strong_APA_Context *self;
> This warning refers to the following code:
> https://github.com/richidubey/rtems/blob/3a9843f61bbd547d150d2ee2d791668cfb5aa282/cpukit/score/src/schedulerstrongapa.c#L415
> We can see that the self variable is used to get the status of the
> chain, why would I get such a warning then?
void _Scheduler_strong_APA_Extract_from_ready(
Scheduler_Context *context,
Scheduler_Node *node_to_extract
Scheduler_strong_APA_Node *node;
self = _Scheduler_strong_APA_Get_self( context );
node = _Scheduler_strong_APA_Node_downcast( node_to_extract );
_Assert( _Chain_Is_empty(self->allNodes) == false );
_Assert( _Chain_Is_node_off_chain( &node->Node ) == false );
_Chain_Extract_unprotected( &node->Node ); //Removed from allNodes
_Chain_Set_off_chain( &node->Node );
It is only used in the _Assert(). I guess you build without the
configure option --enable-rtems-debug? During development it is useful
to enable the RTEMS_DEBUG support.
You should not compare boolean values against true or false. Just write
_Assert( !_Chain_Is_empty(self->allNodes) );
for example.
