Strong APA Scheduler : First Draft
Richi Dubey richidubey at gmail.com
Tue Jul 28 04:09:31 UTC 2020
My bad. Please find the new pull request at :
https://github.com/richidubey/rtems/pull/4
On Tue, Jul 28, 2020 at 9:08 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Jul 27, 2020 at 7:11 AM Richi Dubey <richidubey at gmail.com> wrote:
> > Dear Dr. Bloom,
> > Please find the pull request of my branch with my repo's master at
> https://github.com/richidubey/rtems/pull/3. All the compiler errors and
> warnings have been removed, but the implementation would not work because
> there are some places with no code (backtracking). It'd be great if you can
> point out any wrong logic/code.
> Please double-check your pull request. Something looks wrong. It just
> has a template of a testsuite directory.
> > Thanks.
> > Richi.
> > On Mon, Jul 27, 2020 at 1:14 PM Richi Dubey <richidubey at gmail.com>
> wrote:
> >>> Which compiler error do you get? Maybe there is a cyclic dependency.
> >> I assumed that the schedulersmp.h already includes the percpu.h which
> was not the case. My bad. The error has been removed.
> >> I assumed this because schedulersmp.h uses Per_CPU_Control and does not
> show any compilation error, so it should have the percpu.h included in one
> of its included header files right? If it has, why did my
> schedulerstrongapa.h that had the schedulersmp.h included give the
> following error:
> /home/richi/quick-start/src/rtems/cpukit/include/rtems/score/schedulerstrongapa.h:102:3:
> error: unknown type name 'Per_CPU_Control'
> >>    Per_CPU_Control cpu;
> >> On Mon, Jul 27, 2020 at 10:30 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >>> On 26/07/2020 16:03, Gedare Bloom wrote:
> >>> > On Sat, Jul 25, 2020 at 11:21 AM Richi Dubey<richidubey at gmail.com>
> wrote:
> >>> >> Dear Dr. Bloom,
> >>> >> Please find the pull request at the following link:
> https://github.com/RTEMS/rtems/pull/39.
> >>> > It would be great if you can create a GitHub Pull Request (PR) for
> >>> > your branch against your "master" branch in your fork.
> >>> > I'd prefer you not submit a PR to RTEMS repo, but rather, to your
> >>> > forked repo. We don't review PRs on RTEMS/github in general, so it is
> >>> > better to keep this review off the github mirror.
> >>> Yes, this would be nice.
> >>> >> Please note that I have tried to remove all the compilation errors
> but this still won't compile right now, because my implementation requires
> the use of percpu.h file, which (I'm assuming) is not currently linked with
> the source files related to Strong APA.
> >>> > That seems strange.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200728/f024a1c2/attachment.html>
