On 29/07/2020 11:14, Eshan Dhawan wrote: > Could you check the MIPS patch as well > https://lists.rtems.org/pipermail/devel/2020-July/060762.html > This patch removed soft float support from MIPS > As it was the other architecture that could cause error Where can I find the hard float support in the MIPS files?
