[PATCH 0/2] Fix fenv support for ARM
Eshan Dhawan
eshandhawan51 at gmail.com
Wed Jul 29 10:59:35 UTC 2020
> On 29-Jul-2020, at 3:28 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 29/07/2020 11:14, Eshan Dhawan wrote:
>> Could you check the MIPS patch as well
>> https://lists.rtems.org/pipermail/devel/2020-July/060762.html
>> This patch removed soft float support from MIPS
>> As it was the other architecture that could cause error
> Where can I find the hard float support in the MIPS files?
Apologies I sent the wrong link
Actually I was sending the patch link
https://lists.rtems.org/pipermail/devel/2020-July/060808.html
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200729/160907f8/attachment-0001.html>
