[PATCH RTEMS 3/7] libfreebsd: Added ofw_if.h
Wed Jul 29 15:59:03 UTC 2020
On Wed, Jul 15, 2020 at 12:32 AM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
> This file is the RTEMS implementation of ofw_if.h in FreeBSD. The
> ofw_if.h in FreeBSD is an autogenerated header file that maps the
> OF_function calls to their respective implementation. But in RTEMS
> this file maps the OF_functions directly to their FDT implementation.
>  cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h | 62 ++++++++++++++++++++++
>  1 file changed, 62 insertions(+)
>  create mode 100644 cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h
You may have mentioned this elsewhere, but if this header file needs
to be installed it should go under the include/ tree.
> diff --git a/cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h b/cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h
> new file mode 100644
> index 0000000000..f66c02884e
> --- /dev/null
> +++ b/cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h
> @@ -0,0 +1,62 @@
> +/* SPDX-License-Identifier: BSD-2-Clause
> + * @file
> + * @ingroup LIBFREEBSD
These usually aren't all caps. They're not consistent, but LibFreeBSD
makes more sense to me.
> + * @brief Declaration of OFW functions.
> + * Copyright (C) <2020> Niteesh Babu <niteesh.gs at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _LIBFREEBSD_OFW_IF_H
> +#define _LIBFREEBSD_OFW_IF_H
> +#include <dev/ofw/openfirm.h>
This means that header is installed. Please put the headers under the
include/dev tree instead.
> +typedef void*  ofw_t;
> +int OFW_INIT(ofw_t ofw_obj, void *cookie);
> +phandle_t OFW_PEER(ofw_t ofw_obj, phandle_t node);
> +phandle_t OFW_CHILD(ofw_t ofw_obj, phandle_t node);
> +phandle_t OFW_PARENT(ofw_t ofw_obj, phandle_t node);
> +phandle_t OFW_INSTANCE_TO_PACKAGE(ofw_t ofw_obj, ihandle_t instance);
> +ssize_t OFW_GETPROPLEN(ofw_t ofw_obj, phandle_t package, const char *propname);
> +ssize_t OFW_GETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
> +           void *buf, size_t buflen);
> +int OFW_NEXTPROP(ofw_t ofw_obj, phandle_t package, const char *prev, char *buf,
> +           size_t size);
> +int OFW_SETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
> +           const void *buf, size_t len);
> +ssize_t OFW_CANON(ofw_t ofw_obj, const char *device, char *buf, size_t len);
> +phandle_t OFW_FINDDEVICE(ofw_t ofw_obj, const char *device);
> +ssize_t OFW_INSTANCE_TO_PATH(ofw_t ofw_obj, ihandle_t instance, char *buf,
> +           size_t len);
> +ssize_t OFW_PACKAGE_TO_PATH(ofw_t ofw_obj, phandle_t package, char *buf,
> +           size_t len);
Doxygen?
> +#endif /* _LIBFREEBSD_OFW_IF_H */
> 2.17.1
