[PATCH RTEMS 3/7] libfreebsd: Added ofw_if.h
Niteesh G. S.
niteesh.gs at gmail.com
Wed Jul 29 18:45:09 UTC 2020
On Wed, Jul 29, 2020 at 9:29 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Jul 15, 2020 at 12:32 AM G S Niteesh Babu <niteesh.gs at gmail.com>
> wrote:
> > This file is the RTEMS implementation of ofw_if.h in FreeBSD. The
> > ofw_if.h in FreeBSD is an autogenerated header file that maps the
> > OF_function calls to their respective implementation. But in RTEMS
> > this file maps the OF_functions directly to their FDT implementation.
> > cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h | 62 ++++++++++++++++++++++
> > 1 file changed, 62 insertions(+)
> > create mode 100644 cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h
> You may have mentioned this elsewhere, but if this header file needs
> to be installed it should go under the include/ tree.
This header is not intended to be installed.
> > diff --git a/cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h
> b/cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h
> > new file mode 100644
> > index 0000000000..f66c02884e
> > --- /dev/null
> > +++ b/cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h
> > @@ -0,0 +1,62 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause
> > + * @file
> > + * @ingroup LIBFREEBSD
> These usually aren't all caps. They're not consistent, but LibFreeBSD
> makes more sense to me.
OK. I'll change this to LibFreeBSD everywhere.
> > + * @brief Declaration of OFW functions.
> > + * Copyright (C) <2020> Niteesh Babu <niteesh.gs at gmail.com>
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + * notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + * notice, this list of conditions and the following disclaimer in
> the
> > + * documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifndef _LIBFREEBSD_OFW_IF_H
> > +#define _LIBFREEBSD_OFW_IF_H
> > +#include <dev/ofw/openfirm.h>
> This means that header is installed. Please put the headers under the
> include/dev tree instead.
Why does this mean the header is installed?
In FreeBSD, these two files are present in the same directory. The
openfirm.h
is what provides the OFW API and ofw_if.h is responsible for calling the
correct
implementation of OFW using KOBJs in case of RTEMS this is hard-wired to the
FDT implementation in libBSD as well as RTEMS.
Previously, openfirm.h and ofw_if.h were in the same directory but since I
had
to install openfirm.h I moved it cpukit/include.
And if this helps, the include is present only to provide a definition for
phandle_t.
> > +typedef void* ofw_t;
> > +int OFW_INIT(ofw_t ofw_obj, void *cookie);
> > +phandle_t OFW_PEER(ofw_t ofw_obj, phandle_t node);
> > +phandle_t OFW_CHILD(ofw_t ofw_obj, phandle_t node);
> > +phandle_t OFW_PARENT(ofw_t ofw_obj, phandle_t node);
> > +phandle_t OFW_INSTANCE_TO_PACKAGE(ofw_t ofw_obj, ihandle_t instance);
> > +ssize_t OFW_GETPROPLEN(ofw_t ofw_obj, phandle_t package, const char
> *propname);
> > +ssize_t OFW_GETPROP(ofw_t ofw_obj, phandle_t package, const char
> *propname,
> > + void *buf, size_t buflen);
> > +int OFW_NEXTPROP(ofw_t ofw_obj, phandle_t package, const char *prev,
> char *buf,
> > + size_t size);
> > +int OFW_SETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
> > + const void *buf, size_t len);
> > +ssize_t OFW_CANON(ofw_t ofw_obj, const char *device, char *buf, size_t
> len);
> > +phandle_t OFW_FINDDEVICE(ofw_t ofw_obj, const char *device);
> > +ssize_t OFW_INSTANCE_TO_PATH(ofw_t ofw_obj, ihandle_t instance, char
> *buf,
> > + size_t len);
> > +ssize_t OFW_PACKAGE_TO_PATH(ofw_t ofw_obj, phandle_t package, char *buf,
> > + size_t len);
> Doxygen?
I don't think this is the right place for Doxygen since as mentioned above
this
is not exposed. A better place would be openfirm.h.
> > +#endif /* _LIBFREEBSD_OFW_IF_H */
> > 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200730/51ca9b23/attachment.html>
