[PATCH] avoid GCC 10 warning -Wstringop-truncation
Thu Jul 30 15:53:57 UTC 2020
On Thu, Jul 30, 2020 at 9:44 AM Sebastian Huber
> On 30/07/2020 13:36, Aschref Ben-Thabet wrote:
> > diff --git a/testsuites/psxtests/psxndbm01/init.c b/testsuites/psxtests/psxndbm01/init.c
> > index a13afa7315..b524aff0df 100644
> > --- a/testsuites/psxtests/psxndbm01/init.c
> > +++ b/testsuites/psxtests/psxndbm01/init.c
> > @@ -218,7 +218,7 @@ rtems_task Init(rtems_task_argument ignored)
> >     puts( "Fetch non-existing record and confirm error." );
> >     test_strings = (char*)malloc(6);
> > -  strncpy( test_strings, "Hello", 5 );
> > +  memcpy( test_strings, "Hello", 5 );
> >     test_strings[5] = '\0';
> In the glibc devel list this approach was suggested for problems like this:
> *(char *) mempcpy( test_strings, "Hello", 5 ) = '\0';
> https://sourceware.org/legacy-ml/libc-alpha/2000-08/msg00061.html
This code is suspect/wrong. that should create a NUL at the start of
the test_strings. I'd rather see the memcpy followed by appending the
NUL. It is easy enough to understand I think.
> devel mailing list
> devel at rtems.org
