[PATCH] avoid GCC 10 warning -Wstringop-truncation
Thu Jul 30 15:55:38 UTC 2020
On 30/07/2020 17:53, Gedare Bloom wrote:
> On Thu, Jul 30, 2020 at 9:44 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> On 30/07/2020 13:36, Aschref Ben-Thabet wrote:
>>> diff --git a/testsuites/psxtests/psxndbm01/init.c b/testsuites/psxtests/psxndbm01/init.c
>>> index a13afa7315..b524aff0df 100644
>>> --- a/testsuites/psxtests/psxndbm01/init.c
>>> +++ b/testsuites/psxtests/psxndbm01/init.c
>>> @@ -218,7 +218,7 @@ rtems_task Init(rtems_task_argument ignored)
>>>      puts( "Fetch non-existing record and confirm error." );
>>>      test_strings = (char*)malloc(6);
>>> -  strncpy( test_strings, "Hello", 5 );
>>> +  memcpy( test_strings, "Hello", 5 );
>>>      test_strings[5] = '\0';
>> In the glibc devel list this approach was suggested for problems like this:
>> *(char *) mempcpy( test_strings, "Hello", 5 ) = '\0';
>> https://sourceware.org/legacy-ml/libc-alpha/2000-08/msg00061.html
> This code is suspect/wrong. that should create a NUL at the start of
> the test_strings. I'd rather see the memcpy followed by appending the
> NUL. It is easy enough to understand I think.
Yes, this was also my impression then I did read this code snippet.
Please note that this is memPcpy(), a GNU extension.
