docs.rtems.org Rendering Issue
Fri Jul 31 01:26:00 UTC 2020
On 31/7/20 8:29 am, Joel Sherrill wrote:
> https://docs.rtems.org/branches/master/c-user/rate_monotonic_manager.html#processor-utilization-rule
> Should have match symbols in it. I assume something isn't installed or is not
> quite right.
The commit says "Use Latex math for utilization formulas". This is an HTML
render so unless there is some magic that transforms Latex into HTML I am not
sure. The PDF looks OK. I see this ...
https://www.sphinx-doc.org/en/master/usage/restructuredtext/directives.html?#math
and it takes me to ...
https://www.sphinx-doc.org/en/master/usage/extensions/math.html#math-support
I have not looked into this any further.
> Any ideas?
Does this render for you when you build HTML?
If so could you please upload a copy somewhere so I can have a look?
