[PATCH 2/2] irqs01/smpirqs01: New tests
Fri Jul 31 11:45:26 UTC 2020
Close #4034.
 spec/build/testsuites/libtests/grp.yml       |   2 +
 spec/build/testsuites/libtests/irqs01.yml    |  19 ++
 spec/build/testsuites/smptests/grp.yml       |   2 +
 spec/build/testsuites/smptests/smpirqs01.yml |  20 ++
 testsuites/libtests/irqs01/init.c            | 294 +++++++++++++++++++
 testsuites/libtests/irqs01/irqs01.doc        |  16 +
 testsuites/smptests/smpirqs01/init.c         | 197 +++++++++++++
 testsuites/smptests/smpirqs01/smpirqs01.doc  |  13 +
 8 files changed, 563 insertions(+)
 create mode 100644 spec/build/testsuites/libtests/irqs01.yml
 create mode 100644 spec/build/testsuites/smptests/smpirqs01.yml
 create mode 100644 testsuites/libtests/irqs01/init.c
 create mode 100644 testsuites/libtests/irqs01/irqs01.doc
 create mode 100644 testsuites/smptests/smpirqs01/init.c
 create mode 100644 testsuites/smptests/smpirqs01/smpirqs01.doc
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index e6e0ce75ae..aff46c9f8f 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -158,6 +158,8 @@ links:
   uid: iconvclose
 - role: build-dependency
   uid: iconvopen
+- role: build-dependency
+  uid: irqs01
   uid: kill
diff --git a/spec/build/testsuites/libtests/irqs01.yml b/spec/build/testsuites/libtests/irqs01.yml
new file mode 100644
index 0000000000..0ad3898317
--- /dev/null
+++ b/spec/build/testsuites/libtests/irqs01.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/irqs01/init.c
+stlib: []
+target: testsuites/libtests/irqs01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/smptests/grp.yml b/spec/build/testsuites/smptests/grp.yml
index 8564cf2294..771708503e 100644
--- a/spec/build/testsuites/smptests/grp.yml
+++ b/spec/build/testsuites/smptests/grp.yml
@@ -59,6 +59,8 @@ links:
   uid: smpfatal09
   uid: smpipi01
+  uid: smpirqs01
   uid: smpload01
diff --git a/spec/build/testsuites/smptests/smpirqs01.yml b/spec/build/testsuites/smptests/smpirqs01.yml
index 0000000000..8e4e86ac09
--- /dev/null
+++ b/spec/build/testsuites/smptests/smpirqs01.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_SMP
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/smptests/smpirqs01/init.c
+stlib: []
+target: testsuites/smptests/smpirqs01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/libtests/irqs01/init.c b/testsuites/libtests/irqs01/init.c
index 0000000000..d3131d0f75
--- /dev/null
+++ b/testsuites/libtests/irqs01/init.c
@@ -0,0 +1,294 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test.h>
+#include <rtems/test-info.h>
+#include <rtems.h>
+#include <rtems/irq-extension.h>
+typedef struct {
+  rtems_interrupt_server_control base;
+  int magic;
+} server_control;
+static void destroy(rtems_interrupt_server_control *base)
+  server_control *control;
+  control = (server_control *) base;
+  T_step_eq_int(2, control->magic, 0x54192a88);
+static const rtems_interrupt_server_config valid_config = {
+  .priority = 123,
+  .stack_size = RTEMS_MINIMUM_STACK_SIZE,
+  .modes = RTEMS_DEFAULT_MODES,
+  .attributes = RTEMS_DEFAULT_ATTRIBUTES,
+  .destroy = destroy
+T_TEST_CASE(InterruptServerBuildDestroy)
+  server_control control;
+  rtems_status_code sc;
+  uint32_t server_index;
+  rtems_task_priority prio;
+  T_plan(7);
+  memset(&control, 0xff, sizeof(control));
+  control.magic = 0x54192a88;
+  server_index = 0x2833763f;
+  sc = rtems_interrupt_server_build(
+    &control.base,
+    &valid_config,
+    &server_index
+  T_step_rsc_success(0, sc);
+  T_step_ne_u32(1, server_index, 0x2833763f);
+  sc = rtems_interrupt_server_destroy(server_index);
+  T_step_rsc_success(3, sc);
+  /* Make sure the interrupt server terminated */
+  prio = 0;
+  sc = rtems_task_set_priority(RTEMS_SELF, 124, &prio);
+  T_step_rsc_success(4, sc);
+  sc = rtems_task_set_priority(RTEMS_SELF, prio, &prio);
+  T_step_rsc_success(5, sc);
+  T_step_eq_u32(6, prio, 124);
+static const rtems_interrupt_server_config invalid_config = {
+  .priority = 0,
+T_TEST_CASE(InterruptServerBuildError)
+  rtems_interrupt_server_control control;
+  rtems_interrupt_server_control control_2;
+  memset(&control_2, 0xff, sizeof(control_2));
+  server_index = 0x235e8766;
+  sc = rtems_interrupt_server_build(&control, &invalid_config, &server_index);
+  T_rsc(sc, RTEMS_INVALID_PRIORITY);
+  T_eq_mem(&control, &control_2, sizeof(control));
+  T_eq_u32(server_index, 0x235e8766);
+static const rtems_interrupt_server_config request_config = {
+  .priority = 123,
+static void not_called(void *arg)
+  (void) arg;
+  T_unreachable();
+static void request(void *arg)
+  rtems_id *id;
+  id = arg;
+  T_step(4);
+  sc = rtems_event_transient_send(*id);
+  T_step_rsc_success(6, sc);
+T_TEST_CASE(InterruptServerRequest)
+  rtems_interrupt_server_request req;
+  rtems_id id;
+  T_plan(11);
+  memset(&req, 0xff, sizeof(req));
+  server_index = 0x99d225bd;
+    &control,
+    &request_config,
+    &server_index
+  T_step_ne_u32(1, server_index, 0x99d225bd);
+  sc = rtems_interrupt_server_request_initialize(
+    server_index,
+    &req,
+    not_called,
+    NULL
+  T_step_rsc_success(2, sc);
+  rtems_interrupt_server_request_submit(&req);
+  rtems_interrupt_server_request_destroy(&req);
+  id = rtems_task_self();
+    server_index,
+    &req,
+    request,
+    &id
+  sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  T_step_rsc_success(7, sc);
+  prio = 0;
+  T_step_rsc_success(8, sc);
+  T_step_rsc_success(9, sc);
+  T_step_eq_u32(10, prio, 124);
+T_TEST_CASE(InterruptServerInitializeDestroy)
+  uint32_t server_count;
+  sc = rtems_interrupt_server_destroy(0);
+  T_rsc(sc, RTEMS_INVALID_ID);
+  server_count = 456;
+  sc = rtems_interrupt_server_initialize(
+    123,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &server_count
+  T_rsc_success(sc);
+  T_eq_u32(server_count, 1);
+    123,
+    &server_count
+  T_rsc(sc, RTEMS_INCORRECT_STATE);
+  T_eq_u32(server_count, 0);
+  prio = 0;
+  T_eq_u32(prio, 124);
+    0,
+    &server_count
+    123,
+    &server_count
+  prio = 0;
+const char rtems_test_name[] = "IRQS 1";
+static void Init(rtems_task_argument argument)
+  rtems_test_run(argument, TEST_STATE);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/irqs01/irqs01.doc b/testsuites/libtests/irqs01/irqs01.doc
index 0000000000..43b9f07037
--- /dev/null
+++ b/testsuites/libtests/irqs01/irqs01.doc
@@ -0,0 +1,16 @@
+This file describes the directives and concepts tested by this test set.
+test set name: irqs01
+directives:
+  - rtems_interrupt_server_build()
+  - rtems_interrupt_server_destroy()
+  - rtems_interrupt_server_initialize()
+  - rtems_interrupt_server_request_destroy()
+  - rtems_interrupt_server_request_initialize()
+  - rtems_interrupt_server_request_submit()
+concepts:
+  - Ensure that the interrupt server works.
diff --git a/testsuites/smptests/smpirqs01/init.c b/testsuites/smptests/smpirqs01/init.c
index 0000000000..5849698297
--- /dev/null
+++ b/testsuites/smptests/smpirqs01/init.c
@@ -0,0 +1,197 @@
+ * are met:
+#endif
+#include <rtems.h>
+#include <rtems/malloc.h>
+static void ensure_server_termination(void)
+  rtems_id id;
+  uint32_t cpu_self;
+  uint32_t cpu_other;
+  prio = 0;
+  cpu_self = rtems_scheduler_get_processor();
+  cpu_other = (cpu_self + 1) % 2;
+  sc = rtems_scheduler_ident_by_processor(cpu_other, &id);
+  sc = rtems_task_set_scheduler(RTEMS_SELF, id, 124);
+  sc = rtems_scheduler_ident_by_processor(cpu_self, &id);
+  sc = rtems_task_set_scheduler(RTEMS_SELF, id, prio);
+T_TEST_CASE(InterruptServerSMPInitializeDestroy)
+  void *greedy;
+  T_assert_eq_u32(rtems_scheduler_get_processor_maximum(), 2);
+    123,
+    &server_count
+  T_eq_u32(server_count, 2);
+    123,
+    &server_count
+  ensure_server_termination();
+  sc = rtems_interrupt_server_destroy(1);
+    0,
+    &server_count
+    123,
+    &server_count
+  greedy = rtems_heap_greedy_allocate(NULL, 0);
+    123,
+    &server_count
+  T_rsc(sc, RTEMS_NO_MEMORY);
+  rtems_heap_greedy_free(greedy);
+const char rtems_test_name[] = "SMPIRQS 1";
+#define CONFIGURE_MAXIMUM_TASKS 3
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_PROCESSORS 2
+#define CONFIGURE_SCHEDULER_EDF_SMP
+#include <rtems/scheduler.h>
+RTEMS_SCHEDULER_EDF_SMP(a);
+RTEMS_SCHEDULER_EDF_SMP(b);
+#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
+  RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name('A', ' ', ' ', ' ')), \
+  RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' '))
+#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
+  RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
+  RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL)
diff --git a/testsuites/smptests/smpirqs01/smpirqs01.doc b/testsuites/smptests/smpirqs01/smpirqs01.doc
index 0000000000..28dd3bc683
--- /dev/null
+++ b/testsuites/smptests/smpirqs01/smpirqs01.doc
@@ -0,0 +1,13 @@
+test set name: smpirqs01
+directives:
+concepts:
+  - Ensure that the interrupt server initialization with more than one
+    processor works.
2.26.2
