[PATCH v2] rtems: Add rtems_interrupt_server_create()
Fri Jul 31 16:10:11 UTC 2020
Add rtems_interrupt_server_destroy().
Before this patch, the only way to create interrupt servers was
rtems_interrupt_server_initialize(). This function creates the default
interrupt server and in SMP configurations additional interrupt servers
for the additional processors. The interrupt server is heavily used by
libbsd. This includes the epoch based reclamation which performs time
consuming resource and memory deallocation work. This does not work well
with time critical services, for example an UART over SPI or I2C. One
approach to address this problem is to allow the application to create
custom interrupt servers with the right priority and task properties.
The interrupt server API accounted for this, however, it was not
implemented before this patch.
Closes #4033.
 bsps/shared/irq/irq-server.c         | 365 ++++++++++++++++++---------
 cpukit/include/rtems/irq-extension.h | 143 ++++++++++-
 2 files changed, 378 insertions(+), 130 deletions(-)
diff --git a/bsps/shared/irq/irq-server.c b/bsps/shared/irq/irq-server.c
index 93e2d144d8..eb5b0b3998 100644
--- a/bsps/shared/irq/irq-server.c
+++ b/bsps/shared/irq/irq-server.c
@@ -7,13 +7,7 @@
- * Copyright (c) 2009, 2019 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
+ * Copyright (C) 2009, 2020 embedded brains GmbH (http://www.embedded-brains.de)
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
@@ -21,6 +15,7 @@
+#include <string.h>
 #include <rtems/chain.h>
@@ -30,54 +25,43 @@
 #define BSP_INTERRUPT_SERVER_MANAGEMENT_VECTOR (BSP_INTERRUPT_VECTOR_MAX + 1)
-typedef struct {
-  RTEMS_INTERRUPT_LOCK_MEMBER(lock);
-  rtems_chain_control entries;
-  rtems_id server;
-  unsigned errors;
-} bsp_interrupt_server_context;
+static rtems_interrupt_server_control bsp_interrupt_server_default;
-#if defined(RTEMS_SMP)
-static bsp_interrupt_server_context *bsp_interrupt_server_instances;
-#else
-static bsp_interrupt_server_context bsp_interrupt_server_instance;
-#endif
+static rtems_chain_control bsp_interrupt_server_chain =
+  RTEMS_CHAIN_INITIALIZER_EMPTY(bsp_interrupt_server_chain);
-static bsp_interrupt_server_context *bsp_interrupt_server_get_context(
+static rtems_interrupt_server_control *bsp_interrupt_server_get_context(
   uint32_t server_index,
   rtems_status_code *sc
-  if (bsp_interrupt_server_instances == NULL) {
-    *sc = RTEMS_INCORRECT_STATE;
-    return NULL;
-#else
-  if (bsp_interrupt_server_instance.server == RTEMS_ID_NONE) {
-    return NULL;
-#endif
+  rtems_chain_node *node;
+  bsp_interrupt_lock();
+  node = rtems_chain_first(&bsp_interrupt_server_chain);
-  if (server_index >= rtems_scheduler_get_processor_maximum()) {
-    *sc = RTEMS_INVALID_ID;
-    return NULL;
+  while (node != rtems_chain_tail(&bsp_interrupt_server_chain)) {
+    rtems_interrupt_server_control *s;
+    s = RTEMS_CONTAINER_OF(node, rtems_interrupt_server_control, node);
+    if (s->index == server_index) {
+      bsp_interrupt_unlock();
+      return s;
+    node = rtems_chain_next(node);
-  *sc = RTEMS_SUCCESSFUL;
-  return &bsp_interrupt_server_instances[server_index];
-#else
-  return &bsp_interrupt_server_instance;
-#endif
+  *sc = RTEMS_INVALID_ID;
+  return NULL;
 static void bsp_interrupt_server_trigger(void *arg)
   rtems_interrupt_lock_context lock_context;
   rtems_interrupt_server_entry *e = arg;
-  bsp_interrupt_server_context *s = e->server;
+  rtems_interrupt_server_control *s = e->server;
   if (bsp_interrupt_is_valid_vector(e->vector)) {
     bsp_interrupt_vector_disable(e->vector);
@@ -137,7 +121,7 @@ static rtems_interrupt_server_entry *bsp_interrupt_server_query_entry(
 typedef struct {
-  bsp_interrupt_server_context *server;
+  rtems_interrupt_server_control *server;
   rtems_vector_number vector;
   rtems_option options;
   rtems_interrupt_handler handler;
@@ -281,7 +265,7 @@ static void bsp_interrupt_server_remove_helper(void *arg)
 static rtems_status_code bsp_interrupt_server_call_helper(
-  bsp_interrupt_server_context *s,
+  rtems_interrupt_server_control *s,
   rtems_vector_number vector,
   rtems_option options,
   rtems_interrupt_handler handler,
@@ -314,7 +298,7 @@ static rtems_status_code bsp_interrupt_server_call_helper(
 static rtems_interrupt_server_entry *bsp_interrupt_server_get_entry(
@@ -337,7 +321,7 @@ static rtems_interrupt_server_entry *bsp_interrupt_server_get_entry(
 static void bsp_interrupt_server_task(rtems_task_argument arg)
-  bsp_interrupt_server_context *s = (bsp_interrupt_server_context *) arg;
+  rtems_interrupt_server_control *s = (rtems_interrupt_server_control *) arg;
   while (true) {
     rtems_event_set events;
@@ -377,7 +361,7 @@ rtems_status_code rtems_interrupt_server_handler_install(
   rtems_status_code sc;
-  bsp_interrupt_server_context *s;
   s = bsp_interrupt_server_get_context(server_index, &sc);
   if (s == NULL) {
@@ -402,7 +386,7 @@ rtems_status_code rtems_interrupt_server_handler_remove(
   if (s == NULL) {
@@ -464,7 +448,7 @@ rtems_status_code rtems_interrupt_server_handler_iterate(
   bsp_interrupt_server_handler_iterate_helper_data hihd;
   if (s == NULL) {
@@ -487,103 +471,252 @@ rtems_status_code rtems_interrupt_server_handler_iterate(
-rtems_status_code rtems_interrupt_server_initialize(
+ * The default server is statically allocated.  Just clear the structure so
+ * that it can be re-initialized.
+static void bsp_interrupt_server_destroy_default(
+  memset(s, 0, sizeof(*s));
+#if defined(RTEMS_SMP)
+static void bsp_interrupt_server_destroy_secondary(
+  free(s);
+#endif
+static rtems_status_code bsp_interrupt_server_create(
   rtems_task_priority priority,
   size_t stack_size,
   rtems_mode modes,
   rtems_attribute attributes,
-  uint32_t *server_count
+  uint32_t cpu_index
-  uint32_t cpu_index;
-  uint32_t cpu_count;
-  uint32_t dummy;
-  bsp_interrupt_server_context *instances;
+  rtems_status_code sc;
+  rtems_id scheduler;
+  cpu_set_t cpu;
+#endif
-  if (server_count == NULL) {
-    server_count = &dummy;
+  rtems_interrupt_lock_initialize(&s->lock, "Interrupt Server");
+  rtems_chain_initialize_empty(&s->entries);
-  cpu_count = rtems_scheduler_get_processor_maximum();
+  sc = rtems_task_create(
+    rtems_build_name('I', 'R', 'Q', 'S'),
+    priority,
+    stack_size,
+    modes,
+    attributes,
+    &s->server
+  if (sc != RTEMS_SUCCESSFUL) {
+    return sc;
-  instances = calloc(cpu_count, sizeof(*instances));
-  if (instances == NULL) {
-    return RTEMS_NO_MEMORY;
+  sc = rtems_scheduler_ident_by_processor(cpu_index, &scheduler);
+    /* Do not start an interrupt server on a processor without a scheduler */
+    return RTEMS_SUCCESSFUL;
+  sc = rtems_task_set_scheduler(s->server, scheduler, priority);
+  _Assert(sc == RTEMS_SUCCESSFUL);
+  /* Set the task to processor affinity on a best-effort basis */
+  CPU_ZERO(&cpu);
+  CPU_SET(cpu_index, &cpu);
+  (void) rtems_task_set_affinity(s->server, sizeof(cpu), &cpu);
 #else
-  instances = &bsp_interrupt_server_instance;
+  (void) cpu_index;
 #endif
-  for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) {
-    bsp_interrupt_server_context *s = &instances[cpu_index];
-    rtems_status_code sc;
+  rtems_chain_append_unprotected(&bsp_interrupt_server_chain, &s->node);
+  sc = rtems_task_start(
+    s->server,
+    bsp_interrupt_server_task,
+    (rtems_task_argument) s
+  return sc;
+rtems_status_code rtems_interrupt_server_initialize(
+  rtems_task_priority priority,
+  size_t stack_size,
+  rtems_mode modes,
+  rtems_attribute attributes,
+  uint32_t *server_count
+  uint32_t cpu_index;
-    rtems_id scheduler;
-    cpu_set_t cpu;
+  uint32_t cpu_count;
 #endif
-    rtems_interrupt_lock_initialize(&s->lock, "Interrupt Server");
-    rtems_chain_initialize_empty(&s->entries);
+  cpu_index = 0;
+  s = &bsp_interrupt_server_default;
+  if (s->server != 0) {
+    sc = RTEMS_INCORRECT_STATE;
+    goto done;
+  s->destroy = bsp_interrupt_server_destroy_default;
+  sc = bsp_interrupt_server_create(
+    s,
+    priority,
+    stack_size,
+    modes,
+    attributes,
+    cpu_index
+    goto done;
+  cpu_index = 1;
+  cpu_count = rtems_scheduler_get_processor_maximum();
+  while (cpu_index < cpu_count) {
+    s = calloc(1, sizeof(*s));
-    sc = rtems_task_create(
-      rtems_build_name('I', 'R', 'Q', 'S'),
+    if (s == NULL) {
+      sc = RTEMS_NO_MEMORY;
+      goto done;
+    s->destroy = bsp_interrupt_server_destroy_secondary;
+    s->index = cpu_index;
+      s,
       priority,
       stack_size,
       modes,
       attributes,
-      &s->server
+      cpu_index
-      *server_count = cpu_index;
-      if (cpu_index > 0) {
-        bsp_interrupt_server_instances = instances;
-        return RTEMS_SUCCESSFUL;
+      goto done;
-      free(instances);
+    ++cpu_index;
 #endif
-      return RTEMS_TOO_MANY;
+done:
-    sc = rtems_scheduler_ident_by_processor(cpu_index, &scheduler);
-    if (sc != RTEMS_SUCCESSFUL) {
-      /* Do not start an interrupt server on a processor without a scheduler */
-      continue;
+  if (server_count != NULL) {
+    *server_count = cpu_index;
-    sc = rtems_task_set_scheduler(s->server, scheduler, priority);
-    _Assert(sc == RTEMS_SUCCESSFUL);
+  return sc;
-    /* Set the task to processor affinity on a best-effort basis */
-    CPU_ZERO(&cpu);
-    CPU_SET(cpu_index, &cpu);
-    (void) rtems_task_set_affinity(s->server, sizeof(cpu), &cpu);
-#endif
+rtems_status_code rtems_interrupt_server_create(
+  const rtems_interrupt_server_config *config,
+  uint32_t                            *server_index
-    sc = rtems_task_start(
-      s->server,
-      bsp_interrupt_server_task,
-      (rtems_task_argument) s
+    config->name,
+    config->priority,
+    config->storage_size,
+    config->modes,
+    config->attributes,
+    &s->server
+    return sc;
-#endif
+  s->destroy = config->destroy;
+  s->index = rtems_object_id_get_index(s->server)
+    + rtems_scheduler_get_processor_maximum();
+  *server_index = s->index;
+  rtems_chain_initialize_node(&s->node);
+    s->server,
+  return sc;
+static void bsp_interrupt_server_destroy_helper(void *arg)
+  bsp_interrupt_server_helper_data *hd = arg;
+  rtems_interrupt_server_control *s = hd->server;
+  rtems_chain_extract_unprotected(&s->node);
+  if (s->destroy != NULL) {
+    (*s->destroy)(s);
+  sc = rtems_event_transient_send(hd->task);
+  (void) sc;
+  rtems_task_exit();
+rtems_status_code rtems_interrupt_server_destroy(uint32_t server_index)
+  s = bsp_interrupt_server_get_context(server_index, &sc);
+  if (s == NULL) {
+    return sc;
+  bsp_interrupt_server_call_helper(
+    s,
+    BSP_INTERRUPT_SERVER_MANAGEMENT_VECTOR,
+    0,
+    NULL,
+    NULL,
+    bsp_interrupt_server_destroy_helper
 static void bsp_interrupt_server_entry_initialize(
   rtems_interrupt_server_entry *entry,
   rtems_chain_set_off_chain(&entry->node);
@@ -611,7 +744,7 @@ rtems_status_code rtems_interrupt_server_entry_initialize(
   if (s == NULL) {
@@ -645,7 +778,7 @@ rtems_status_code rtems_interrupt_server_entry_move(
   s = bsp_interrupt_server_get_context(destination_server_index, &sc);
   if (s == NULL) {
@@ -667,7 +800,7 @@ void rtems_interrupt_server_entry_destroy(
   s = entry->server;
@@ -698,7 +831,7 @@ rtems_status_code rtems_interrupt_server_request_initialize(
   if (s == NULL) {
@@ -727,8 +860,8 @@ static void bsp_interrupt_server_handler_move_helper(void *arg)
   e = bsp_interrupt_server_query_entry(hd->vector, &trigger_options);
   if (e != NULL) {
-    bsp_interrupt_server_context *src = e->server;
-    bsp_interrupt_server_context *dst = hihd->arg;
+    rtems_interrupt_server_control *src = e->server;
+    rtems_interrupt_server_control *dst = hihd->arg;
     bool pending;
     /* The source server is only used in SMP configurations for the lock */
@@ -763,8 +896,8 @@ rtems_status_code rtems_interrupt_server_move(
-  bsp_interrupt_server_context *src;
-  bsp_interrupt_server_context *dst;
+  rtems_interrupt_server_control *src;
+  rtems_interrupt_server_control *dst;
   src = bsp_interrupt_server_get_context(source_server_index, &sc);
@@ -810,7 +943,7 @@ static void bsp_interrupt_server_entry_suspend_helper(void *arg)
 rtems_status_code rtems_interrupt_server_suspend(uint32_t server_index)
   if (s == NULL) {
@@ -831,7 +964,7 @@ rtems_status_code rtems_interrupt_server_suspend(uint32_t server_index)
 rtems_status_code rtems_interrupt_server_resume(uint32_t server_index)
   if (s == NULL) {
@@ -858,7 +991,7 @@ rtems_status_code rtems_interrupt_server_set_affinity(
   rtems_id scheduler;
diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
index 0d77b320bc..bde75ec765 100644
--- a/cpukit/include/rtems/irq-extension.h
+++ b/cpukit/include/rtems/irq-extension.h
@@ -9,13 +9,7 @@
  * Based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
- * Copyright (C) 2008, 2019 embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
+ * Copyright (C) 2008, 2020 embedded brains GmbH (http://www.embedded-brains.de)
@@ -259,6 +253,76 @@ typedef struct rtems_interrupt_server_action {
 #define RTEMS_INTERRUPT_SERVER_DEFAULT 0
+ * @brief An interrupt server control.
+ * This structure must be treated as an opaque data type.  Members must not be
+ * accessed directly.
+ * @see rtems_interrupt_server_create()
+typedef struct rtems_interrupt_server_control {
+  RTEMS_INTERRUPT_LOCK_MEMBER( lock )
+  rtems_chain_control          entries;
+  rtems_id                     server;
+  unsigned long                errors;
+  uint32_t                     index;
+  rtems_chain_node             node;
+  void ( *destroy )( struct rtems_interrupt_server_control * );
+} rtems_interrupt_server_control;
+ * @brief An interrupt server configuration.
+typedef struct {
+   * @brief The task name of the interrupt server.
+  rtems_name name;
+   * @brief The initial task priority of the interrupt server.
+  rtems_task_priority priority;
+   * @brief The task storage area of the interrupt server.
+   * It shall be NULL for interrupt servers created by
+   * rtems_interrupt_server_create().
+  void *storage_area;
+   * @brief The task storage size of the interrupt server.
+   * For interrupt servers created by rtems_interrupt_server_create() this is
+   * the task stack size.
+  size_t storage_size;
+   * @brief The initial task modes of the interrupt server.
+  rtems_mode modes;
+   * @brief The task attributes of the interrupt server.
+  rtems_attribute attributes;
+   * @brief An optional handler to destroy the interrupt server control handed
+   *   over to rtems_interrupt_server_create().
+   * This handler is called in the context of the interrupt server to be
+   * destroyed.
+  void ( *destroy )( rtems_interrupt_server_control * );
+} rtems_interrupt_server_config;
  * @brief An interrupt server entry.
@@ -309,16 +373,19 @@ typedef struct {
  * The server count pointer @a server_count may be @a NULL.
+ * The task name of interrupt servers created by this function is
+ * rtems_build_name( 'I', 'R', 'Q', 'S' ).
  * This function may block.
- * @see rtems_task_create().
+ * @retval RTEMS_SUCCESSFUL The operation was successful.
- * @retval RTEMS_SUCCESSFUL Successful operation.
- * @retval RTEMS_INCORRECT_STATE The interrupt servers are not initialized.
- * @retval RTEMS_NO_MEMORY Not enough memory.
- * @retval RTEMS_TOO_MANY No free task available to create at least one server task.
- * @retval RTEMS_UNSATISFIED Task stack size too large.
- * @retval RTEMS_INVALID_PRIORITY Invalid task priority.
+ * @retval RTEMS_INCORRECT_STATE The interrupt servers were already initialized.
+ * @return The function uses rtems_task_create().  If this operation is not
+ *   successful, then its status code is returned.
+ * @see rtems_interrupt_server_create() and rtems_interrupt_server_destroy().
@@ -328,6 +395,54 @@ rtems_status_code rtems_interrupt_server_initialize(
+ * @brief Creates an interrupt server.
+ * This function may block.
+ * @param[out] control is the interrupt server control.  The ownership of this
+ *   structure is transferred from the caller of this function to the interrupt
+ *   server management.
+ * @param config is the interrupt server configuration.
+ * @param[out] server_index is the pointer to a server index variable.  The
+ *   index of the built interrupt server will be stored in the referenced
+ *   variable if the operation was successful.
+ * @see rtems_interrupt_server_initialize() and
+ *   rtems_interrupt_server_destroy().
+  rtems_interrupt_server_control      *control,
+ * @brief Destroys the interrupt server.
+ * The interrupt server deletes itself, so after the return of the function the
+ * interrupt server may be still in the termination process depending on the
+ * task priorities of the system.
+ * @param server_index is the index of the interrupt server to destroy.  Use
+ *   ::RTEMS_INTERRUPT_SERVER_DEFAULT to specify the default server.
+ * @retval RTEMS_INVALID_ID The interrupt server index was invalid.
+rtems_status_code rtems_interrupt_server_destroy( uint32_t server_index );
  * @brief Installs the interrupt handler routine @a handler for the interrupt
  * vector with number @a vector on the server @a server.
2.26.2
