Error in building application with rpi BSP with waf build system
Utkarsh Rai
utkarsh.rai60 at gmail.com
Mon Jun 1 04:02:09 UTC 2020
Hello,
I was unable to build a sample app for raspberrypi, I followed the docs
<https://docs.rtems.org/branches/master/user/start/app.html> and was able
to build the app for Xilinx-qemu and beagleboard.
The waf configure command was - ./waf configure
--rtems=$HOME/sandbox/rtems/5 --rtems-bsp=arm/raspberrypi
The log file shows the following message-
# project configured on Mon Jun 1 09:19:15 2020 by
# waf 2.0.19 (abi 20, python 20711f0 on linux2)
# using ./waf configure --rtems=/home/utkarsh/sandbox/rtems/5
Setting top to
/home/utkarsh/Desktop/rtems_test
Setting out to
/home/utkarsh/Desktop/rtems_test/build
from /home/utkarsh/Desktop/rtems_test: No valid arch/bsps found"
A ./rtems-bsps shows that the valid BSP name for RPI is the same as that in
configure command.
Is there a typo in my configure command or the waf build does not support
raspberrypi BSP? Kindly point out my error.
Regards,
Utkarsh Rai.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200601/730cf7b3/attachment-0001.html>
