Error in building application with rpi BSP with waf build system
Utkarsh Rai
utkarsh.rai60 at gmail.com
Mon Jun 1 04:23:22 UTC 2020
On Mon, Jun 1, 2020 at 9:32 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> Hello,
> I was unable to build a sample app for raspberrypi, I followed the docs
> <https://docs.rtems.org/branches/master/user/start/app.html> and was able
> to build the app for Xilinx-qemu and beagleboard.
> The waf configure command was - ./waf configure
> --rtems=$HOME/sandbox/rtems/5 --rtems-bsp=arm/raspberrypi
> The log file shows the following message-
> # project configured on Mon Jun 1 09:19:15 2020 by
> # waf 2.0.19 (abi 20, python 20711f0 on linux2)
> # using ./waf configure --rtems=/home/utkarsh/sandbox/rtems/5
> Setting top to
> /home/utkarsh/Desktop/rtems_test
> Setting out to
> /home/utkarsh/Desktop/rtems_test/build
> from /home/utkarsh/Desktop/rtems_test: No valid arch/bsps found"
> A ./rtems-bsps shows that the valid BSP name for RPI is the same as that
> in configure command.
> Is there a typo in my configure command or the waf build does not support
> raspberrypi BSP? Kindly point out my error.
> Regards,
> Utkarsh Rai.
Sorry, this is resolved, I had deleted my RPI BSP build and was then trying
to build the app.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200601/757b5ad5/attachment.html>
