[PATCH] fenv support arm
Eshan dhawan eshandhawan51 at gmail.com
Tue Jun 2 00:09:57 UTC 2020
This patch adds support for ARM fenv to newlib
the files are taken from FreeBSD
Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
 newlib/libc/machine/arm/machine/acle-compat.h | 182 ++++++++++
 newlib/libc/machine/arm/machine/fenv-mangle.h |  53 +++
 .../libc/machine/arm/machine/fenv-softfloat.h | 187 ++++++++++
 newlib/libc/machine/arm/machine/fenv-vfp.h    | 187 ++++++++++
 newlib/libc/machine/arm/sys/fenv.h            | 122 +++++++
 newlib/libm/machine/arm/Makefile.am           |  18 +-
 newlib/libm/machine/arm/fe_dfl_env.c          |   7 +
 newlib/libm/machine/arm/feclearexcept.c       |   7 +
 newlib/libm/machine/arm/fegetenv.c            |   7 +
 newlib/libm/machine/arm/fegetexceptflag.c     |   7 +
 newlib/libm/machine/arm/fegetround.c          |   7 +
 newlib/libm/machine/arm/feholdexcept.c        |   7 +
 newlib/libm/machine/arm/fenv-softfp.c         |  32 ++
 newlib/libm/machine/arm/fenv-vfp.c            |  32 ++
 newlib/libm/machine/arm/fenv.c                | 328 ++++++++++++++++++
 newlib/libm/machine/arm/feraiseexcept.c       |   7 +
 newlib/libm/machine/arm/fesetenv.c            |   7 +
 newlib/libm/machine/arm/fesetexceptflag.c     |   7 +
 newlib/libm/machine/arm/fesetround.c          |   7 +
 newlib/libm/machine/arm/fetestexcept.c        |   7 +
 newlib/libm/machine/arm/feupdateenv.c         |   7 +
 21 files changed, 1224 insertions(+), 1 deletion(-)
 create mode 100644 newlib/libc/machine/arm/machine/acle-compat.h
 create mode 100644 newlib/libc/machine/arm/machine/fenv-mangle.h
 create mode 100644 newlib/libc/machine/arm/machine/fenv-softfloat.h
 create mode 100644 newlib/libc/machine/arm/machine/fenv-vfp.h
 create mode 100644 newlib/libc/machine/arm/sys/fenv.h
 create mode 100644 newlib/libm/machine/arm/fe_dfl_env.c
 create mode 100644 newlib/libm/machine/arm/feclearexcept.c
 create mode 100644 newlib/libm/machine/arm/fegetenv.c
 create mode 100644 newlib/libm/machine/arm/fegetexceptflag.c
 create mode 100644 newlib/libm/machine/arm/fegetround.c
 create mode 100644 newlib/libm/machine/arm/feholdexcept.c
 create mode 100644 newlib/libm/machine/arm/fenv-softfp.c
 create mode 100644 newlib/libm/machine/arm/fenv-vfp.c
 create mode 100644 newlib/libm/machine/arm/fenv.c
 create mode 100644 newlib/libm/machine/arm/feraiseexcept.c
 create mode 100644 newlib/libm/machine/arm/fesetenv.c
 create mode 100644 newlib/libm/machine/arm/fesetexceptflag.c
 create mode 100644 newlib/libm/machine/arm/fesetround.c
 create mode 100644 newlib/libm/machine/arm/fetestexcept.c
 create mode 100644 newlib/libm/machine/arm/feupdateenv.c
diff --git a/newlib/libc/machine/arm/machine/acle-compat.h b/newlib/libc/machine/arm/machine/acle-compat.h
new file mode 100644
index 000000000..888ae2ea8
--- /dev/null
+++ b/newlib/libc/machine/arm/machine/acle-compat.h
@@ -0,0 +1,182 @@
+ * Copyright (c) 2014 ARM Ltd
+ * All rights reserved.
+ * are met:
+ * 3. The name of the company may not be used to endorse or promote
+ *    products derived from this software without specific prior written
+ *    permission.
+ * THIS SOFTWARE IS PROVIDED BY ARM LTD ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL ARM LTD BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
+ * TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+ * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+ * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+ * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#ifndef __ARM_ARCH
+/* ACLE standardises a set of pre-defines that describe the ARM architecture.
+   These were mostly implemented in GCC around GCC-4.8; older versions
+   have no, or only partial support.  To provide a level of backwards
+   compatibility we try to work out what the definitions should be, given
+   the older pre-defines that GCC did produce.  This isn't complete, but
+   it should be enough for use by routines that depend on this header.  */
+/* No need to handle ARMv8, GCC had ACLE support before that.  */
+# ifdef __ARM_ARCH_7__
+/* The common subset of ARMv7 in all profiles.  */
+#  define __ARM_ARCH 7
+#  define __ARM_ARCH_ISA_THUMB 2
+#  define __ARM_FEATURE_CLZ
+#  define __ARM_FEATURE_LDREX 7
+#  define __ARM_FEATURE_UNALIGNED
+# endif
+# if defined (__ARM_ARCH_7A__) || defined (__ARM_ARCH_7R__)
+#  define __ARM_ARCH_ISA_ARM
+#  define __ARM_FEATURE_SIMD32
+#  define __ARM_FEATURE_DSP
+#  define __ARM_FEATURE_QBIT
+#  define __ARM_FEATURE_SAT
+#  define __ARM_FEATURE_LDREX 15
+#  ifdef __ARM_ARCH_7A__
+#   define __ARM_ARCH_PROFILE 'A'
+#  else
+#   define __ARM_ARCH_PROFILE 'R'
+#  endif
+# endif
+# ifdef __ARM_ARCH_7EM__
+#  define __ARM_ARCH_PROFILE 'M'
+# endif
+# ifdef __ARM_ARCH_7M__
+# endif
+# ifdef __ARM_ARCH_6T2__
+#  define __ARM_ARCH 6
+#  define __ARM_FEATURE_LDREX 4
+# endif
+# ifdef __ARM_ARCH_6M__
+#  define __ARM_ARCH_ISA_THUMB 1
+# endif
+# if defined (__ARM_ARCH_6__) || defined (__ARM_ARCH_6J__) \
+  || defined (__ARM_ARCH_6K__) || defined (__ARM_ARCH_6Z__) \
+  || defined (__ARM_ARCH_6ZK__)
+#  ifndef __thumb__
+#   if defined (__ARM_ARCH_6K__) || defined (__ARM_ARCH_6ZK__)
+#   else
+#   endif
+#  endif
+# endif
+# if defined (__ARM_ARCH_5TE__) || defined (__ARM_ARCH_5E__)
+#  define __ARM_ARCH 5
+#  ifdef __ARM_ARCH_5TE__
+#  endif
+# endif
+# if defined (__ARM_ARCH_5T__) || defined (__ARM_ARCH_5__)
+#  endif
+# endif
+# ifdef __ARM_ARCH_4T__
+#  define __ARM_ARCH 4
+# endif
+# ifdef __ARM_ARCH_4__
+# endif
+# if defined (__ARM_ARCH_3__) || defined (__ARM_ARCH_3M__)
+#  define __ARM_ARCH 3
+# endif
+# ifdef __ARM_ARCH_2__
+#  define __ARM_ARCH 2
+# endif
+# ifdef __ARMEB__
+#  define __ARM_BIG_ENDIAN
+# endif
+/* If we still don't know what the target architecture is, then we're
+   probably not using GCC.  */
+# ifndef __ARM_ARCH
+#  error Unable to determine architecture version.
+# endif
+#endif /* __ARM_ARCH  */
diff --git a/newlib/libc/machine/arm/machine/fenv-mangle.h b/newlib/libc/machine/arm/machine/fenv-mangle.h
index 000000000..476f7b20c
--- /dev/null
+++ b/newlib/libc/machine/arm/machine/fenv-mangle.h
@@ -0,0 +1,53 @@
+ * Copyright (c) 2013 Andrew Turner <andrew at FreeBSD.ORG>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifdef _FENV_MANGLE_H_
+#error Only include fenv-mangle.h once
+#endif
+#define	_FENV_MANGLE_H_
+#ifndef FENV_MANGLE
+#error FENV_MANGLE is undefined
+#endif
+#define	feclearexcept	FENV_MANGLE(feclearexcept)
+#define	fegetexceptflag	FENV_MANGLE(fegetexceptflag)
+#define	fesetexceptflag	FENV_MANGLE(fesetexceptflag)
+#define	feraiseexcept	FENV_MANGLE(feraiseexcept)
+#define	fetestexcept	FENV_MANGLE(fetestexcept)
+#define	fegetround	FENV_MANGLE(fegetround)
+#define	fesetround	FENV_MANGLE(fesetround)
+#define	fegetenv	FENV_MANGLE(fegetenv)
+#define	feholdexcept	FENV_MANGLE(feholdexcept)
+#define	fesetenv	FENV_MANGLE(fesetenv)
+#define	feupdateenv	FENV_MANGLE(feupdateenv)
+#define	feenableexcept	FENV_MANGLE(feenableexcept)
+#define	fedisableexcept	FENV_MANGLE(fedisableexcept)
+#define	fegetexcept	FENV_MANGLE(fegetexcept)
diff --git a/newlib/libc/machine/arm/machine/fenv-softfloat.h b/newlib/libc/machine/arm/machine/fenv-softfloat.h
index 000000000..b650437cc
--- /dev/null
+++ b/newlib/libc/machine/arm/machine/fenv-softfloat.h
@@ -0,0 +1,187 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2004-2011 David Schultz <das at FreeBSD.ORG>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_SYS_FENV_H_
+#error "This file is meant to be included only by <sys/fenv.h>."
+#endif
+/* the file can be added from architecture specific fenv.h file found in
+ *libc/sys/arch/sys *
+ * This file implements the functionality of <fenv.h> on platforms that
+ * lack an FPU and use softfloat in libc for floating point.  To use it,
+ * you must write an <fenv.h> that provides the following:
+ *   - a typedef for fenv_t, which may be an integer or struct type
+ *   - a typedef for fexcept_t (XXX This file assumes fexcept_t is a
+ *     simple integer type containing the exception mask.)
+ *   - definitions of FE_* constants for the five exceptions and four
+ *     rounding modes in IEEE 754, as described in fenv(3)
+ *   - a definition, and the corresponding external symbol, for FE_DFL_ENV
+ *   - a macro __set_env(env, flags, mask, rnd), which sets the given fenv_t
+ *     from the exception flags, mask, and rounding mode
+ *   - macros __env_flags(env), __env_mask(env), and __env_round(env), which
+ *     extract fields from an fenv_t
+ *   - a definition of __fenv_static
+ * If the architecture supports an optional FPU, it's recommended that you
+ * define fenv_t and fexcept_t to match the hardware ABI.  Otherwise, it
+ * doesn't matter how you define them.
+#include <errno.h>
+int __softfloat_float_exception_flags;
+int __softfloat_float_exception_mask;
+int __softfloat_float_rounding_mode;
+__fenv_static inline int
+feclearexcept(int excepts)
+	__softfloat_float_exception_flags &= ~excepts;
+	return (0);
+fegetexceptflag(fexcept_t *flagp, int excepts)
+	*flagp = __softfloat_float_exception_flags & excepts;
+	return (0);
+fesetexceptflag(const fexcept_t *flagp, int excepts)
+	__softfloat_float_exception_flags |= *flagp & excepts;
+	return (0);
+feraiseexcept(int excepts)
+	return (excepts  ?  -ENOTSUP : 0);
+fetestexcept(int excepts)
+	return (__softfloat_float_exception_flags & excepts);
+fegetround(void)
+	return (__softfloat_float_rounding_mode);
+fesetround(int round)
+	__softfloat_float_rounding_mode = round;
+	return (0);
+fegetenv(fenv_t *envp)
+	__set_env(*envp, __softfloat_float_exception_flags,
+	    __softfloat_float_exception_mask, __softfloat_float_rounding_mode);
+	return (0);
+feholdexcept(fenv_t *envp)
+	fenv_t __env;
+	fegetenv(envp);
+	__softfloat_float_exception_flags = 0;
+	__softfloat_float_exception_mask = 0;
+	return (0);
+fesetenv(const fenv_t *envp)
+	__softfloat_float_exception_flags = __env_flags(*envp);
+	__softfloat_float_exception_mask = __env_mask(*envp);
+	__softfloat_float_rounding_mode = __env_round(*envp);
+	return (0);
+feupdateenv(const fenv_t *envp)
+	int __oflags = __softfloat_float_exception_flags;
+	fesetenv(envp);
+	feraiseexcept(__oflags);
+	return (0);
+#if __BSD_VISIBLE
+/* We currently provide no external definitions of the functions below. */
+feenableexcept(int __mask)
+	int __omask = __softfloat_float_exception_mask;
+	__softfloat_float_exception_mask |= __mask;
+	return (__omask);
+fedisableexcept(int __mask)
+	__softfloat_float_exception_mask &= ~__mask;
+	return (__omask);
+fegetexcept(void)
+	return (__softfloat_float_exception_mask);
+#endif /* __BSD_VISIBLE */
diff --git a/newlib/libc/machine/arm/machine/fenv-vfp.h b/newlib/libc/machine/arm/machine/fenv-vfp.h
index 000000000..25d71f3ab
--- /dev/null
+++ b/newlib/libc/machine/arm/machine/fenv-vfp.h
@@ -0,0 +1,187 @@
+ * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#define	vmrs_fpscr(__r)	__asm __volatile("vmrs %0, fpscr" : "=&r"(__r))
+#define	vmsr_fpscr(__r)	__asm __volatile("vmsr fpscr, %0" : : "r"(__r))
+#define _FPU_MASK_SHIFT	8
+__fenv_static inline int feclearexcept(int excepts)
+	fexcept_t __fpsr;
+	vmrs_fpscr(__fpsr);
+	__fpsr &= ~excepts;
+	vmsr_fpscr(__fpsr);
+	return (0);
+	fexcept_t __fpsr;
+	*flagp = __fpsr & excepts;
+	return (0);
+	fexcept_t __fpsr;
+	__fpsr |= *flagp & excepts;
+	return (0);
+	fexcept_t __ex = excepts;
+	fesetexceptflag(&__ex, excepts);	/* XXX */
+	return (0);
+	fexcept_t __fpsr;
+	return (__fpsr & excepts);
+fegetround(void)
+	fenv_t __fpsr;
+	return (__fpsr & _ROUND_MASK);
+	fenv_t __fpsr;
+	__fpsr &= ~(_ROUND_MASK);
+	__fpsr |= round;
+	return (0);
+	vmrs_fpscr(*envp);
+	return (0);
+	fenv_t __env;
+	vmrs_fpscr(__env);
+	*envp = __env;
+	__env &= ~(FE_ALL_EXCEPT);
+	vmsr_fpscr(__env);
+	return (0);
+	vmsr_fpscr(*envp);
+	return (0);
+	fexcept_t __fpsr;
+	feraiseexcept(__fpsr & FE_ALL_EXCEPT);
+	return (0);
+#if __BSD_VISIBLE
+	fenv_t __old_fpsr, __new_fpsr;
+	vmrs_fpscr(__old_fpsr);
+	__new_fpsr = __old_fpsr |
+	    ((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
+	vmsr_fpscr(__new_fpsr);
+	return ((__old_fpsr >> _FPU_MASK_SHIFT) & FE_ALL_EXCEPT);
+	__new_fpsr = __old_fpsr &
+	    ~((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
+fegetexcept(void)
+	fenv_t __fpsr;
+	return (__fpsr & FE_ALL_EXCEPT);
diff --git a/newlib/libc/machine/arm/sys/fenv.h b/newlib/libc/machine/arm/sys/fenv.h
index 000000000..af74c5f47
--- /dev/null
+++ b/newlib/libc/machine/arm/sys/fenv.h
@@ -0,0 +1,122 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#define _SYS_FENV_H_ 1
+#include <sys/_types.h>
+#include <sys/cdefs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifndef	__fenv_static
+#define	__fenv_static static
+#endif
+typedef int fenv_t;
+typedef int fexcept_t;
+/* Exception flags */
+#define	FE_INVALID	0x0001
+#define	FE_DIVBYZERO	0x0002
+#define	FE_OVERFLOW	0x0004
+#define	FE_UNDERFLOW	0x0008
+#define	FE_INEXACT	0x0010
+#ifdef __ARM_PCS_VFP
+#define	FE_DENORMAL	0x0080
+#define	FE_ALL_EXCEPT	(FE_DIVBYZERO | FE_INEXACT | \
+			 FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW | FE_DENORMAL)
+#else
+			 FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW)
+#endif
+/* Rounding modes */
+#define	VFP_FE_TONEAREST	0x00000000
+#define	VFP_FE_UPWARD		0x00400000
+#define	VFP_FE_DOWNWARD		0x00800000
+#define	VFP_FE_TOWARDZERO	0x00c00000
+#define	FE_TONEAREST	VFP_FE_TONEAREST
+#define	FE_UPWARD	VFP_FE_UPWARD
+#define	FE_DOWNWARD	VFP_FE_DOWNWARD
+#define	FE_TOWARDZERO	VFP_FE_TOWARDZERO
+#else
+#define	FE_TONEAREST	0x0000
+#define	FE_TOWARDZERO	0x0001
+#define	FE_UPWARD	0x0002
+#define	FE_DOWNWARD	0x0003
+#endif
+#define	_ROUND_MASK	(FE_TONEAREST | FE_DOWNWARD | \
+			 FE_UPWARD | FE_TOWARDZERO)
+/* Default floating-point environment */
+extern const fenv_t	*_fe_dfl_env;
+#define	FE_DFL_ENV	(_fe_dfl_env)
+/* We need to be able to map status flag positions to mask flag positions */
+#ifndef __ARM_PCS_VFP
+#define	_FPUSW_SHIFT	16
+#define	_ENABLE_MASK	(FE_ALL_EXCEPT << _FPUSW_SHIFT)
+#endif
+int feclearexcept(int excepts);
+int fegetexceptflag(fexcept_t *flagp, int excepts);
+int fesetexceptflag(const fexcept_t *flagp, int excepts);
+int feraiseexcept(int excepts);
+int fetestexcept(int excepts);
+int fegetround(void);
+int fesetround(int round);
+int fegetenv(fenv_t *envp);
+int feholdexcept(fenv_t *envp);
+int fesetenv(const fenv_t *envp);
+int feupdateenv(const fenv_t *envp);
+#if __BSD_VISIBLE
+int feenableexcept(int __mask);
+int fedisableexcept(int __mask);
+int fegetexcept(void);
+#endif	/* __ARM_PCS_VFP */
+#ifdef __cplusplus
+#endif
+#endif	/* _SYS_FENV_H_ */
diff --git a/newlib/libm/machine/arm/Makefile.am b/newlib/libm/machine/arm/Makefile.am
index 1f10a7a40..a64ee59d5 100644
--- a/newlib/libm/machine/arm/Makefile.am
+++ b/newlib/libm/machine/arm/Makefile.am
@@ -19,7 +19,23 @@ LIB_SOURCES = \
 	sf_nearbyint.c \
 	sf_rint.c \
 	sf_round.c \
-	sf_trunc.c
+	sf_trunc.c \
+	feclearexcept.c \
+	fe_dfl_env.c\
+	fegetenv.c \
+	fegetexceptflag.c \
+	fegetround.c \
+	feholdexcept.c \
+	fenv.c \
+	feraiseexcept.c \
+	fesetenv.c \
+	fesetexceptflag.c \
+	fesetround.c \
+	fetestexcept.c \
+	feupdateenv.c \
+	fenv-vfp.c \
+	fenv-softfp.c
 noinst_LIBRARIES = lib.a
 lib_a_SOURCES = $(LIB_SOURCES)
diff --git a/newlib/libm/machine/arm/fe_dfl_env.c b/newlib/libm/machine/arm/fe_dfl_env.c
index 000000000..8cbee7771
--- /dev/null
+++ b/newlib/libm/machine/arm/fe_dfl_env.c
@@ -0,0 +1,7 @@
+ * (c) Copyright 2019 Joel Sherrill <joel at rtems.org>
+#include "../../fenv/fenv_stub.c"
diff --git a/newlib/libm/machine/arm/feclearexcept.c b/newlib/libm/machine/arm/feclearexcept.c
--- /dev/null
+++ b/newlib/libm/machine/arm/feclearexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fegetenv.c b/newlib/libm/machine/arm/fegetenv.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fegetenv.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fegetexceptflag.c b/newlib/libm/machine/arm/fegetexceptflag.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fegetexceptflag.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fegetround.c b/newlib/libm/machine/arm/fegetround.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fegetround.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/feholdexcept.c b/newlib/libm/machine/arm/feholdexcept.c
--- /dev/null
+++ b/newlib/libm/machine/arm/feholdexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fenv-softfp.c b/newlib/libm/machine/arm/fenv-softfp.c
index 000000000..a576cc1b2
--- /dev/null
+++ b/newlib/libm/machine/arm/fenv-softfp.c
@@ -0,0 +1,32 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#define	FENV_MANGLE(x)	__softfp_ ##x
+#include <machine/fenv-mangle.h>
+#include "fenv.c"
diff --git a/newlib/libm/machine/arm/fenv-vfp.c b/newlib/libm/machine/arm/fenv-vfp.c
index 000000000..297e81296
--- /dev/null
+++ b/newlib/libm/machine/arm/fenv-vfp.c
@@ -0,0 +1,32 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#define	FENV_MANGLE(x)	__vfp_ ##x
+#include "fenv.c"
diff --git a/newlib/libm/machine/arm/fenv.c b/newlib/libm/machine/arm/fenv.c
index 000000000..5b61ab81f
--- /dev/null
+++ b/newlib/libm/machine/arm/fenv.c
@@ -0,0 +1,328 @@
+ * Copyright (c) 2004 David Schultz <das at FreeBSD.ORG>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#include <fenv.h>
+#include <machine/acle-compat.h>
+#if __ARM_ARCH >= 6
+#define FENV_ARMv6
+#endif
+/* When SOFTFP_ABI is defined we are using the softfp ABI. */
+#if defined(__VFP_FP__) && !defined(__ARM_PCS_VFP)
+#define SOFTFP_ABI
+#endif
+ * Hopefully the system ID byte is immutable, so it's valid to use
+ * this as a default environment.
+fenv_t __fe_dfl_env = { 0 };
+const fenv_t *_fe_dfl_env = &__fe_dfl_env;
+#endif
+/* If this is a non-mangled softfp version special processing is required */
+#if defined(FENV_MANGLE) || !defined(SOFTFP_ABI) || !defined(FENV_ARMv6)
+ * The following macros map between the softfloat emulator's flags and
+ * the hardware's FPSR.  The hardware this file was written for doesn't
+ * have rounding control bits, so we stick those in the system ID byte.
+#define	__set_env(env, flags, mask, rnd) env = ((flags)			\
+						| (mask)<<_FPUSW_SHIFT	\
+						| (rnd) << 24)
+#define	__env_flags(env)		((env) & FE_ALL_EXCEPT)
+#define	__env_mask(env)			(((env) >> _FPUSW_SHIFT)	\
+						& FE_ALL_EXCEPT)
+#define	__env_round(env)		(((env) >> 24) & _ROUND_MASK)
+#include <machine/fenv-softfloat.h>
+#else /* __ARM_PCS_VFP PRESENT */
+#include <machine/fenv-vfp.h>
+#ifdef __GNUC_GNU_INLINE__
+#error "This file must be compiled with C99 'inline' semantics"
+#endif
+extern inline int feclearexcept(int excepts);
+extern inline int fegetexceptflag(fexcept_t *flagp, int excepts);
+extern inline int fesetexceptflag(const fexcept_t *flagp, int excepts);
+extern inline int feraiseexcept(int excepts);
+extern inline int fetestexcept(int excepts);
+extern inline int fegetround(void);
+extern inline int fesetround(int round);
+extern inline int fegetenv(fenv_t *envp);
+extern inline int feholdexcept(fenv_t *envp);
+extern inline int fesetenv(const fenv_t *envp);
+extern inline int feupdateenv(const fenv_t *envp);
+extern inline int feenableexcept(int __mask);
+extern inline int fedisableexcept(int __mask);
+extern inline int fegetexcept(void);
+#else /* !FENV_MANGLE && SOFTFP_ABI */
+/* Set by libc when the VFP unit is enabled */
+int _libc_arm_fpu_present;
+int __softfp_feclearexcept(int excepts);
+int __softfp_fegetexceptflag(fexcept_t *flagp, int excepts);
+int __softfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
+int __softfp_feraiseexcept(int excepts);
+int __softfp_fetestexcept(int excepts);
+int __softfp_fegetround(void);
+int __softfp_fesetround(int round);
+int __softfp_fegetenv(fenv_t *envp);
+int __softfp_feholdexcept(fenv_t *envp);
+int __softfp_fesetenv(const fenv_t *envp);
+int __softfp_feupdateenv(const fenv_t *envp);
+int __softfp_feenableexcept(int __mask);
+int __softfp_fedisableexcept(int __mask);
+int __softfp_fegetexcept(void);
+int __vfp_feclearexcept(int excepts);
+int __vfp_fegetexceptflag(fexcept_t *flagp, int excepts);
+int __vfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
+int __vfp_feraiseexcept(int excepts);
+int __vfp_fetestexcept(int excepts);
+int __vfp_fegetround(void);
+int __vfp_fesetround(int round);
+int __vfp_fegetenv(fenv_t *envp);
+int __vfp_feholdexcept(fenv_t *envp);
+int __vfp_fesetenv(const fenv_t *envp);
+int __vfp_feupdateenv(const fenv_t *envp);
+int __vfp_feenableexcept(int __mask);
+int __vfp_fedisableexcept(int __mask);
+int __vfp_fegetexcept(void);
+static int
+__softfp_round_to_vfp(int round)
+	switch (round) {
+	case FE_TONEAREST:
+	default:
+		return VFP_FE_TONEAREST;
+	case FE_TOWARDZERO:
+		return VFP_FE_TOWARDZERO;
+	case FE_UPWARD:
+		return VFP_FE_UPWARD;
+	case FE_DOWNWARD:
+		return VFP_FE_DOWNWARD;
+static int
+__softfp_round_from_vfp(int round)
+	switch (round) {
+	case VFP_FE_TONEAREST:
+	default:
+		return FE_TONEAREST;
+	case VFP_FE_TOWARDZERO:
+		return FE_TOWARDZERO;
+	case VFP_FE_UPWARD:
+		return FE_UPWARD;
+	case VFP_FE_DOWNWARD:
+		return FE_DOWNWARD;
+	if (_libc_arm_fpu_present)
+		__vfp_feclearexcept(excepts);
+	__softfp_feclearexcept(excepts);
+	return (0);
+	fexcept_t __vfp_flagp;
+	__vfp_flagp = 0;
+		__vfp_fegetexceptflag(&__vfp_flagp, excepts);
+	__softfp_fegetexceptflag(flagp, excepts);
+	*flagp |= __vfp_flagp;
+	return (0);
+		__vfp_fesetexceptflag(flagp, excepts);
+	__softfp_fesetexceptflag(flagp, excepts);
+	return (0);
+		__vfp_feraiseexcept(excepts);
+	__softfp_feraiseexcept(excepts);
+	return (0);
+	int __got_excepts;
+	__got_excepts = 0;
+		__got_excepts = __vfp_fetestexcept(excepts);
+	__got_excepts |= __softfp_fetestexcept(excepts);
+	return (__got_excepts);
+		return __softfp_round_from_vfp(__vfp_fegetround());
+	return __softfp_fegetround();
+		__vfp_fesetround(__softfp_round_to_vfp(round));
+	__softfp_fesetround(round);
+	return (0);
+	fenv_t __vfp_envp;
+	__vfp_envp = 0;
+		__vfp_fegetenv(&__vfp_envp);
+	__softfp_fegetenv(envp);
+	*envp |= __vfp_envp;
+	return (0);
+	__vfp_envp = 0;
+		__vfp_feholdexcept(&__vfp_envp);
+	__softfp_feholdexcept(envp);
+	return (0);
+		__vfp_fesetenv(envp);
+	__softfp_fesetenv(envp);
+	return (0);
+		__vfp_feupdateenv(envp);
+	__softfp_feupdateenv(envp);
+	return (0);
+	int __unmasked;
+	__unmasked = 0;
+		__unmasked = __vfp_feenableexcept(__mask);
+	__unmasked |= __softfp_feenableexcept(__mask);
+	return (__unmasked);
+	int __unmasked;
+	__unmasked = 0;
+		__unmasked = __vfp_fedisableexcept(__mask);
+	__unmasked |= __softfp_fedisableexcept(__mask);
+	int __unmasked;
+	__unmasked = 0;
+		__unmasked = __vfp_fegetexcept();
+	__unmasked |= __softfp_fegetexcept();
+#endif
diff --git a/newlib/libm/machine/arm/feraiseexcept.c b/newlib/libm/machine/arm/feraiseexcept.c
--- /dev/null
+++ b/newlib/libm/machine/arm/feraiseexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fesetenv.c b/newlib/libm/machine/arm/fesetenv.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fesetenv.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fesetexceptflag.c b/newlib/libm/machine/arm/fesetexceptflag.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fesetexceptflag.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fesetround.c b/newlib/libm/machine/arm/fesetround.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fesetround.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/fetestexcept.c b/newlib/libm/machine/arm/fetestexcept.c
--- /dev/null
+++ b/newlib/libm/machine/arm/fetestexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/arm/feupdateenv.c b/newlib/libm/machine/arm/feupdateenv.c
--- /dev/null
+++ b/newlib/libm/machine/arm/feupdateenv.c
@@ -0,0 +1,7 @@
2.17.1
