[PATCH v1 0/9] Enable SMP for pc386 based bsps
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Thu Jun 18 07:42:22 UTC 2020
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Thursday, June 11, 2020 4:22 AM
> To: Sommer, Jan; devel at rtems.org
> Subject: Re: [PATCH v1 0/9] Enable SMP for pc386 based bsps
> On 1/6/20 12:22 am, Jan Sommer wrote:
> > Hello,
> > Some details on the missing tests:
> > smpfatal09: This test actually does pass, but because the fatal error handler
> is executed before the console is initialized, no output is produced.
> > smpclock01.exe: Here CPU0 disables its local interrupts and waits for a
> barrier release of CPU1. This means it doesn't handle timer interrupts
> anymore and doesn't send corresponding IPIs to other CPUs.
> > At the same time CPU1 is waiting for a timer event before releasing the
> barrier. Any hints how to resolve this are very welcome.
> Please create a ticket.
https://devel.rtems.org/ticket/4008
> > smpatomic01: This test seems very large and a bit complicated to me. I will
> have a look at it next, but any suggestions are welcome. It fails with this
> information:
> > ] === atomic or/and test case ===
> > ] worker 0 value: 1
> > ] worker 1 value: 0
> > ] atomic value: expected = 1, actual = 1
> > ] ../../../../../../smp-refex-
> rtems/c/src/../../testsuites/smptests/smpatomic01/init.c: 404 n - s <
> LONG_MAX
> > ] *** FATAL ***
> > smpopenmp01: I don't know more about openmp then what is on
> wikipedia. It has currently a low priority for me.
https://devel.rtems.org/ticket/4009
> > Some details regarding the patch set:
> > - The first 3 commits are basically cleaning the original start16.S to be used
> for starting the application processors only and updating the general bring up
> infrastructure.
> > - The next 2 commits are updating the low level context switch and isr
> handling in assembly. I used the ARM implementation as a template and
> tried to stay comparably close to it.
> > - The last 4 commits are smaller changes made after debugging certain test
> cases.
> > My next step would be to test the SMP functionality on HW. My goal would
> be to get the final revision published as part of the RTEMS5 release.
> This is something I would like to see. I feel a first step of getting the
> changes merge as SMP experimental would be acceptable if no one objects
> and then
> branch release can look at moving SMP to functional if the changed lets us do
> that. That may also depend on RTEMS 6 and it's time frame. My hope is a lot
> shorter than 5.
Ok, the single core testsuites now ran through on hardware.
Here is the comparison between the pre-SMP-patches and the current snapshot.
For the latter I also built everything from the ground up to test the snapshot. Everything worked fine.
Pre-SMP-Patches:                           5.0.0-m2006-2 release snapshot:
Passed:        564                         Passed:        570
Failed:          7                         Failed:          6
User Input:      9                         User Input:      4
Expected Fail:   0                         Expected Fail:   0
Indeterminate:   0                         Indeterminate:   0
Benchmark:       3                         Benchmark:       3
Timeout:         6                         Timeout:         9
Invalid:         3                         Invalid:         0
Wrong Version:   0                         Wrong Version:   0
Wrong Build:     0                         Wrong Build:     0
Wrong Tools:     0                         Wrong Tools:     0
Total:         592                         Total:         592
Failures:                                  Failures:
 dl01.exe                                   dl02.exe
 dl05.exe                                   dl06.exe
 dl07.exe                                   dl07.exe
 dl08.exe                                   dl08.exe
 dl09.exe                                   dl09.exe
 tmcontext01.exe                            spconsole01.exe
 tmfine01.exe                              User Input:
User Input:                                 dl10.exe
 dl10.exe                                   monitor.exe
 monitor.exe                                termios.exe
 termios.exe                                top.exe
 top.exe                                   Benchmark:
 ttest01.exe                                dhrystone.exe
 tztest.exe                                 linpack.exe
 uid01.exe                                  whetstone.exe
 capture.exe                               Timeouts:
 cdtest.exe                                 dl04.exe
Benchmark:                                  dl05.exe
 dhrystone.exe                              cdtest.exe
 linpack.exe                                cxx_iostream.exe
 whetstone.exe                              fileio.exe
Timeouts:                                   spfatal09.exe
 dl02.exe                                   spfatal12.exe
 dl04.exe                                   spstkalloc02.exe
 dl06.exe                                   tmtimer01.exe
 cxx_iostream.exe                          Average test time: 0:00:49.426009
 fileio.exe                                Testing time     : 8:07:40.197135
 spfatal12.exe
Invalid:
 fsnofs01.exe
 fsrfsbitmap01.exe
 fsrofs01.exe
Average test time: 0:00:47.982294
Testing time     : 7:53:25.518093
Next, I will look at the tests in SMP configuration.
Best regards,
   Jan
> Chris
> > If you would like to see any logs from a testsuite run with certain
> parameters, just tell me.
> > Best regards,
> >     Jan
> > Jan Sommer (9):
> >   bsp/pc386: Fix Makefile for building with SMP
> >   bsp/pc386: Turn start16.S into a startAP.S
> >   bsp/pc386: Update GDT to work for SMP
> >   bsp/pc386: Update context switch and restore
> >   bsp/pc386: Define interrupt stack frame for smp
> >   bsps/pc386: Fix Clock_isr for SMP
> >   bsps/pc386: Separate smp API functions. Makes smpfatal08 link
> >   smpsignal01: Change state before sending the signal
> >   bsp/pc386: Disable interrupt nesting for job handler
> >  bsps/i386/include/bsp/smp-imps.h                   |   3 +
> >  bsps/i386/pc386/clock/ckinit.c                     |   2 +-
> >  bsps/i386/pc386/include/bsp.h                      |   7 +
> >  bsps/i386/pc386/include/bsp/tblsizes.h             |   8 +-
> >  bsps/i386/pc386/start/bspsmp.c                     |  43 ++++
> >  bsps/i386/pc386/start/getcpuid.c                   |  22 --
> >  bsps/i386/pc386/start/ldsegs.S                     |   4 +-
> >  bsps/i386/pc386/start/smp-imps.c                   |  79 ++++---
> >  bsps/i386/pc386/start/start16.S                    | 254 ---------------------
> >  bsps/i386/pc386/start/startAP.S                    | 118 ++++++++++
> >  bsps/i386/shared/irq/irq_asm.S                     | 102 +++++----
> >  c/src/lib/libbsp/i386/pc386/Makefile.am            |   8 +-
> >  cpukit/score/cpu/i386/cpu_asm.S                    |  74 ++++--
> >  cpukit/score/cpu/i386/include/rtems/asm.h          |  26 +++
> >  cpukit/score/cpu/i386/include/rtems/score/cpu.h    |  32 +--
> >  .../score/cpu/i386/include/rtems/score/cpuimpl.h   |   2 +
> >  testsuites/smptests/smpsignal01/init.c             |   2 +-
> >  17 files changed, 382 insertions(+), 404 deletions(-)
> >  create mode 100644 bsps/i386/pc386/start/bspsmp.c
> >  delete mode 100644 bsps/i386/pc386/start/getcpuid.c
> >  delete mode 100644 bsps/i386/pc386/start/start16.S
> >  create mode 100644 bsps/i386/pc386/start/startAP.S
