[PATCH 1/5] bsps/shared/freebsd: Import OFW files from FreeBSD.
Niteesh G. S.
niteesh.gs at gmail.com
Thu Jun 4 04:09:20 UTC 2020
Hello,
This email is a reminder since this thread has lost activity.
Thanks,
Niteesh.
On Tue, Jun 2, 2020 at 12:25 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> On Fri, May 29, 2020 at 6:49 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 29/05/2020 12:41, Niteesh G. S. wrote:
> Hello Sebastian,
>> > Hello,
>> > On Fri, May 29, 2020 at 12:52 PM Sebastian Huber
>> > <sebastian.huber at embedded-brains.de
>> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> > Hello,
>> > since this code is not BSP-specific it should be located in
>> > cpukit. How
>> > many FreeBSD source files do you intend to import within this
>> project?
>> > This code depends on a bsp that has FDT support. We first imported it to
>> > cpukit but then decided to move it to bsps/shared since we weren't able
>> to
>> > import BSP related files (bsp/fdt.h in this case) from cpukit.
>> Please think about how BSP dependencies can be avoided since this will
>> also allow us to write unit tests for this infrastructure. One option is
>> to add an API to register the device tree. BSPs which have a device tree
>> do this before the API is used. Unit tests override the device tree to
>> run the test cases.
> From what I understood, the API will have the responsibility to provide
> all objects
> which will be used by the FreeBSD source. In the current case, it is the
> DTB.
> During testing, we override the DTB that will be supplied by the BSP with
> a custom
> one like the one in libfdt test. Please correct if I misunderstood it.
> Can you please provide some pointers on how to implement one? Or please
> point
> to sources of something similar if available.
> I can think of a really simple design where the API holds a reference to
> the FDT blob
> which it gets through the register function. Under normal operation, the
> BSP will register
> the FDT during start up. And while testing just the before running the
> test we can override
> the FDT reference by again registering with a custom FDT blob. But I don't
> think this
> would scale well in the future. So, please mention about the design and
> implementation
> of the API.
> Thanks,
> Niteesh.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200604/d2156f3a/attachment.html>
