[PATCH 1/5] bsps/shared/freebsd: Import OFW files from FreeBSD.
Niteesh G. S.
niteesh.gs at gmail.com
Mon Jun 1 18:55:45 UTC 2020
On Fri, May 29, 2020 at 6:49 PM Sebastian Huber <
> On 29/05/2020 12:41, Niteesh G. S. wrote:
Hello Sebastian,
> > Hello,
> > On Fri, May 29, 2020 at 12:52 PM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > Hello,
> > since this code is not BSP-specific it should be located in
> > cpukit. How
> > many FreeBSD source files do you intend to import within this
> project?
> > This code depends on a bsp that has FDT support. We first imported it to
> > cpukit but then decided to move it to bsps/shared since we weren't able
> to
> > import BSP related files (bsp/fdt.h in this case) from cpukit.
> Please think about how BSP dependencies can be avoided since this will
> also allow us to write unit tests for this infrastructure. One option is
> to add an API to register the device tree. BSPs which have a device tree
> do this before the API is used. Unit tests override the device tree to
> run the test cases.
>From what I understood, the API will have the responsibility to provide all
objects
which will be used by the FreeBSD source. In the current case, it is the
DTB.
During testing, we override the DTB that will be supplied by the BSP with a
custom
one like the one in libfdt test. Please correct if I misunderstood it.
Can you please provide some pointers on how to implement one? Or please
point
to sources of something similar if available.
I can think of a really simple design where the API holds a reference to
the FDT blob
which it gets through the register function. Under normal operation, the
BSP will register
the FDT during start up. And while testing just the before running the test
we can override
the FDT reference by again registering with a custom FDT blob. But I don't
think this
would scale well in the future. So, please mention about the design and
implementation
of the API.
Thanks,
Niteesh.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200602/bc41ca25/attachment.html>
