[PATCH] Use a complete sentence for acronym definitions
Sebastian Huber
Thu Jun 4 13:01:41 UTC 2020
c-user/glossary.rst | 71 +++++++++++++++++++++++----------------------
eng/glossary.rst | 20 ++++++-------
2 files changed, 46 insertions(+), 45 deletions(-)
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index dfbda11..86350a8 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -10,7 +10,7 @@ Glossary
:sorted:
ABI
- An acronym for Application Binary Interface.
+ This term is an acronym for Application Binary Interface.
active
A term used to describe an object which has been created by an
@@ -21,13 +21,13 @@ Glossary
deadline.
API
- An acronym for Application Programming Interface.
+ This term is an acronym for Application Programming Interface.
application
In this document, software which makes use of RTEMS.
ASR
- An acronym for :term:`Asynchronous Signal Routine`.
+ This term is an acronym for :term:`Asynchronous Signal Routine`.
assembler language
The assembler language is a programming language which can be translated very
@@ -77,7 +77,7 @@ Glossary
To simultaneously send a message to a logical set of destinations.
BSP
- An acronym for :term:`Board Support Package`.
+ This term is an acronym for :term:`Board Support Package`.
buffer
A fixed length block of memory allocated from a partition.
@@ -99,7 +99,7 @@ Glossary
set which must be preserved.
CCB
- An acronym for Change Control Board.
+ This term is an acronym for Change Control Board.
Central Processing Unit
This term is equivalent to the terms processor and microprocessor.
@@ -140,14 +140,14 @@ Glossary
of the executive should not be used directly by applications.
CPU
- An acronym for :term:`Central Processing Unit`.
+ This term is an acronym for :term:`Central Processing Unit`.
critical section
A section of code which must be executed indivisibly.
CRT
- An acronym for Cathode Ray Tube. Normally used in reference to the
- man-machine interface.
+ This term is an acronym for Cathode Ray Tube. Normally used in reference to
+ the man-machine interface.
deadline
A fixed time limit by which a task must have completed a set of actions.
@@ -186,10 +186,10 @@ Glossary
addresses.
EARS
- An acronym for Easy Approach to Requirements Syntax.
+ This term is an acronym for Easy Approach to Requirements Syntax.
ELF
- An acronym for
`Executable and Linkable Format <https://en.wikipedia.org/wiki/Executable_and_Linkable_Format>`_.
embedded
@@ -236,7 +236,7 @@ Glossary
system which do not own the memory.
FIFO
- An acronym for :term:`First In First Out`.
+ This term is an acronym for :term:`First In First Out`.
First In First Out
A discipline for manipulating entries in a data structure.
@@ -250,7 +250,7 @@ Glossary
A resource that has been released by the application to RTEMS.
GCC
- An acronym for `GNU Compiler Collection <https://gcc.gnu.org/>`_.
+ This term is an acronym for `GNU Compiler Collection <https://gcc.gnu.org/>`_.
global
An object that has been created with the GLOBAL attribute and exported to
@@ -261,7 +261,7 @@ Glossary
:term:`GCC`.
GNU
- An acronym for `GNU's Not Unix <https://www.gnu.org/>`_.
+ This term is an acronym for `GNU's Not Unix <https://www.gnu.org/>`_.
handler
The equivalent of a manager, except that it is internal to RTEMS and
@@ -292,7 +292,7 @@ Glossary
A multiprocessor computer system composed of a single type of processor.
I/O
- An acronym for Input/Output.
+ This term is an acronym for Input/Output.
ID
An RTEMS assigned identification tag used to access an active object.
@@ -330,10 +330,10 @@ Glossary
An ISR is invoked by the CPU to process a pending interrupt.
ISR
- An acronym for :term:`Interrupt Service Routine`.
+ This term is an acronym for :term:`Interrupt Service Routine`.
ISVV
- An acronym for Independent Software Verification and Validation.
+ This term is an acronym for Independent Software Verification and Validation.
kernel
In this document, this term is used as a synonym for executive.
@@ -372,7 +372,7 @@ Glossary
over resources.
MCS
- An acronym for Mellor-Crummey Scott.
+ This term is an acronym for Mellor-Crummey Scott.
memory pool
Used interchangeably with heap.
@@ -402,7 +402,8 @@ Glossary
disable level used by the task.
MPCI
- An acronym for :term:`Multiprocessor Communications Interface Layer`.
+ :term:`Multiprocessor Communications Interface Layer`.
multiprocessing
The simultaneous execution of two or more processes by a multiple
@@ -440,7 +441,7 @@ Glossary
The state occupied by an uncreated or deleted task.
NUMA
- An acronym for Non-Uniform Memory Access.
+ This term is an acronym for Non-Uniform Memory Access.
numeric coprocessor
A component used in computer systems to enhance performance in
@@ -547,13 +548,13 @@ Glossary
proxy.
PTCB
- An acronym for :term:`Partition Control Block`.
+ This term is an acronym for :term:`Partition Control Block`.
PXCB
- An acronym for :term:`Proxy Control Block`.
+ This term is an acronym for :term:`Proxy Control Block`.
QCB
- An acronym for :term:`Message Queue Control Block`.
+ This term is an acronym for :term:`Message Queue Control Block`.
quantum
The application defined unit of time in which the processor is allocated.
@@ -597,7 +598,7 @@ Glossary
the calling task.
ReqIF
- An acronym for
`Requirements Interchange Format <https://www.omg.org/spec/ReqIF/About-ReqIF/>`_.
resource
@@ -616,7 +617,7 @@ Glossary
:term:`status code`.
RNCB
- An acronym for :term:`Region Control Block`.
+ This term is an acronym for :term:`Region Control Block`.
round-robin
A task scheduling discipline in which tasks of equal priority are
@@ -626,7 +627,7 @@ Glossary
A standard for serial communications.
RTEMS
- An acronym for Real-Time Executive for Multiprocessor Systems.
+ This term is an acronym for Real-Time Executive for Multiprocessor Systems.
running
The state of a rate monotonic timer while it is being used to delineate a
@@ -684,10 +685,10 @@ Glossary
pending signals and the signals sent to a task.
SMCB
- An acronym for :term:`Semaphore Control Block`.
+ This term is an acronym for :term:`Semaphore Control Block`.
SMP
- An acronym for Symmetric Multiprocessing.
+ This term is an acronym for Symmetric Multiprocessing.
SMP barriers
The SMP barriers ensure that a defined set of independent threads of
@@ -790,7 +791,7 @@ Glossary
The system on which the application will ultimately execute.
TAS
- An acronym for Test-And-Set.
+ This term is an acronym for Test-And-Set.
task
This project uses the
@@ -823,7 +824,7 @@ Glossary
processor from one task and given to another.
TCB
- An acronym for :term:`Task Control Block`.
+ This term is an acronym for :term:`Task Control Block`.
thread
This term has the same meaning as :term:`task`.
@@ -862,12 +863,12 @@ Glossary
task.
TLS
- An acronym for Thread-Local Storage :cite:`Drepper:2013:TLS`. TLS is
- available in :term:`C11` and :term:`C++11`. The support for TLS depends
- on the CPU port :cite:`RTEMS:CPU`.
+ This term is an acronym for Thread-Local Storage :cite:`Drepper:2013:TLS`.
+ TLS is available in :term:`C11` and :term:`C++11`. The support for TLS
+ depends on the CPU port :cite:`RTEMS:CPU`.
TMCB
- An acronym for :term:`Timer Control Block`.
+ This term is an acronym for :term:`Timer Control Block`.
transient overload
A temporary rise in system activity which may cause deadlines to be
@@ -875,7 +876,7 @@ Glossary
deadlines will be met under transient overload.
TTAS
- An acronym for Test and Test-And-Set.
+ This term is an acronym for Test and Test-And-Set.
User Extension Table
A table which contains the entry points for each user extensions.
@@ -905,7 +906,7 @@ Glossary
them.
YAML
- An acronym for `YAML Ain't Markup Language <https://yaml.org/>`_.
+ This term is an acronym for `YAML Ain't Markup Language <https://yaml.org/>`_.
yield
When a task voluntarily releases control of the processor.
diff --git a/eng/glossary.rst b/eng/glossary.rst
index f0c0fce..e4adbef 100644
--- a/eng/glossary.rst
+++ b/eng/glossary.rst
:sorted:
API
assembler language
@@ -26,28 +26,28 @@ Glossary
The standard ISO/IEC 9899:2011.
CCB
Doorstop
`Doorstop <https://github.com/doorstop-dev/doorstop>`_ is a
requirements management tool.
EARS
ELF
- An acronym for
GCC
GNAT
*GNAT* is the :term:`GNU` compiler for Ada, integrated into the
:term:`GCC`.
GNU
interrupt service
An *interrupt service* consists of an
@@ -61,14 +61,14 @@ Glossary
ISVV
ReqIF
- An acronym for
RTEMS
software component
This term is defined by ECSS-E-ST-40C 3.2.28 as a "part of a software
@@ -141,4 +141,4 @@ Glossary
YAML
2.26.2
