[PATCH 1/4] eng: Simplify wording for specification items
Sebastian Huber
Thu Jun 4 13:02:26 UTC 2020
Update #3715.
eng/req/items.rst | 464 ++++++++++++++++++++++------------------------
1 file changed, 217 insertions(+), 247 deletions(-)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 05104a6..6bf992f 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -127,9 +127,8 @@ attribute key name shall be a :ref:`SpecTypeName`. In particular, key
names which begin with an underscore (``_``) are reserved for internal
use in tools.
-This is the root specification item type. All explicitly defined attributes
-shall be specified. The following attributes are explicitly defined for this
-type:
+This is the root specification item type. All explicit attributes shall be
+specified. The explicit attributes for this type are:
SPDX-License-Identifier
The attribute value shall be a :ref:`SpecTypeSPDXLicenseIdentifier`. It
@@ -187,8 +186,8 @@ Build Item Type
This type refines the :ref:`SpecTypeRootItemType` though the ``type`` attribute
if the value is ``build``. This set of attributes specifies a build item. All
-explicitly defined attributes shall be specified. The following attributes are
-explicitly defined for this type:
+explicit attributes shall be specified. The explicit attributes for this type
+are:
build-type
The attribute value shall be a :ref:`SpecTypeName`. It shall be the build
@@ -230,8 +229,8 @@ additional objects provided by :ref:`SpecTypeBuildObjectsItemType` items. Test
programs have an implicit ``enabled-by`` attribute value which is controlled by
the option action :ref:`set-test-state <SpecTypeBuildOptionItemType>`. If the
test state is set to ``exclude``, then the test program is not built. All
+are:
ada-main
The attribute value shall be a string. It shall be the path to the Ada main
@@ -320,8 +319,8 @@ Build BSP Item Type
This type refines the :ref:`SpecTypeBuildItemType` though the ``build-type``
attribute if the value is ``bsp``. This set of attributes specifies a base BSP
-variant to build. All explicitly defined attributes shall be specified. The
-following attributes are explicitly defined for this type:
+variant to build. All explicit attributes shall be specified. The explicit
+attributes for this type are:
arch
The attribute value shall be a string. It shall be the target architecture
@@ -407,8 +406,8 @@ This type refines the :ref:`SpecTypeBuildItemType` though the ``build-type``
attribute if the value is ``config-file``. This set of attributes specifies a
configuration file placed in the build tree. The configuration file is
generated during the configure command execution and are placed in the build
-tree. All explicitly defined attributes shall be specified. The following
-attributes are explicitly defined for this type:
+tree. All explicit attributes shall be specified. The explicit attributes for
+this type are:
content
The attribute value shall be a string. It shall be the content of the
@@ -454,8 +453,8 @@ configure command execution and is placed in the build tree. All collected
configuration defines are written to the configuration header file during the
configure command execution. To have all configuration defines from sibling
items available it is recommended to link them in the proper order. All
+are:
guard
The attribute value shall be a string. It shall be the header guard define.
@@ -480,8 +479,8 @@ attribute if the value is ``group``. This set of attributes provides a means to
aggregate other build items and modify the build item context which is used by
referenced build items. The ``includes``, ``ldflags``, ``objects``, and
``use`` variables of the build item context are updated by the corresponding
-attributes of the build group. All explicitly defined attributes shall be
-specified. The following attributes are explicitly defined for this type:
+attributes of the build group. All explicit attributes shall be specified. The
+explicit attributes for this type are:
includes
The attribute value shall be a list. Each list element shall be a
@@ -538,8 +537,8 @@ This type refines the :ref:`SpecTypeBuildItemType` though the ``build-type``
attribute if the value is ``library``. This set of attributes specifies a
static library. Library items may use additional objects provided by
:ref:`SpecTypeBuildObjectsItemType` items through the build dependency links of
-the item. All explicitly defined attributes shall be specified. The following
+the item. All explicit attributes shall be specified. The explicit attributes
+for this type are:
cflags
@@ -605,9 +604,8 @@ Build Objects Item Type
attribute if the value is ``objects``. This set of attributes specifies a set
-of object files used to build static libraries or test programs. All explicitly
-defined attributes shall be specified. The following attributes are explicitly
-defined for this type:
+of object files used to build static libraries or test programs. All explicit
+attributes shall be specified. The explicit attributes for this type are:
cflags
@@ -665,7 +663,7 @@ Build Option Item Type
attribute if the value is ``option``. This set of attributes specifies a build
-option. The following explicitly defined attributes are required:
+option. The following explicit attributes are mandatory:
* ``actions``
@@ -675,7 +673,7 @@ option. The following explicitly defined attributes are required:
* ``description``
-The following attributes are explicitly defined for this type:
+The explicit attributes for this type are:
actions
@@ -746,7 +744,7 @@ Build Script Item Type
attribute if the value is ``script``. This set of attributes specifies a build
script. The optional attributes may be required by commands executed through
-the scripts. The following explicitly defined attributes are required:
+the scripts. The following explicit attributes are mandatory:
* ``do-build``
@@ -756,7 +754,7 @@ the scripts. The following explicitly defined attributes are required:
* ``prepare-configure``
asflags
@@ -859,9 +857,8 @@ Build Start File Item Type
attribute if the value is ``start-file``. This set of attributes specifies a
-start file to build. A start file is used to link an executable. All
+start file to build. A start file is used to link an executable. All explicit
asflags
@@ -915,9 +912,8 @@ test program executable to build. Test programs may use additional objects
provided by :ref:`SpecTypeBuildObjectsItemType` items. Test programs have an
implicit ``enabled-by`` attribute value which is controlled by the option
action :ref:`set-test-state <SpecTypeBuildOptionItemType>`. If the test state
-is set to ``exclude``, then the test program is not built. All explicitly
+is set to ``exclude``, then the test program is not built. All explicit
cflags
@@ -995,8 +991,8 @@ Constraint Item Type
if the value is ``constraint``. This set of attributes specifies a constraint.
-All explicitly defined attributes shall be specified. The following attributes
-are explicitly defined for this type:
+All explicit attributes shall be specified. The explicit attributes for this
+type are:
rationale
The attribute value shall be an optional string. If the value is present,
@@ -1017,8 +1013,8 @@ Glossary Item Type
if the value is ``glossary``. This set of attributes specifies a glossary item.
+type are:
glossary-type
@@ -1037,8 +1033,8 @@ Glossary Group Item Type
This type refines the :ref:`SpecTypeGlossaryItemType` though the
``glossary-type`` attribute if the value is ``group``. This set of attributes
-specifies a glossary group. All explicitly defined attributes shall be
+specifies a glossary group. All explicit attributes shall be specified. The
name
The attribute value shall be a string. It shall be the human readable name
@@ -1055,8 +1051,8 @@ Glossary Term Item Type
``glossary-type`` attribute if the value is ``term``. This set of attributes
-specifies a glossary term. All explicitly defined attributes shall be
+specifies a glossary term. All explicit attributes shall be specified. The
term
The attribute value shall be a string. It shall be the glossary term.
@@ -1076,8 +1072,8 @@ specification item. Interface items shall specify the interface of the software
product to other software products and the hardware. Use
:ref:`SpecTypeInterfaceDomainItemType` items to specify interface domains, for
example the :term:`API`, C language, compiler, interfaces to the
-implementation, and the hardware. All explicitly defined attributes shall be
+implementation, and the hardware. All explicit attributes shall be specified.
interface-type
@@ -1124,9 +1120,8 @@ Application Configuration Group Item Type
This type refines the :ref:`SpecTypeInterfaceItemType` though the
``interface-type`` attribute if the value is ``appl-config-group``. This set of
-attributes specifies an application configuration group. All explicitly defined
-attributes shall be specified. The following attributes are explicitly defined
-for this type:
+attributes specifies an application configuration group. All explicit
description
The attribute value shall be a string. It shall be the description of the
@@ -1147,9 +1142,8 @@ Application Configuration Option Item Type
``interface-type`` attribute if the value is ``appl-config-option``. This set
-of attributes specifies an application configuration option. All explicitly
+of attributes specifies an application configuration option. All explicit
appl-config-option-type
@@ -1203,8 +1197,8 @@ Application Configuration Feature Option Item Type
This type refines the :ref:`SpecTypeApplicationConfigurationOptionItemType`
though the ``appl-config-option-type`` attribute if the value is ``feature``.
This set of attributes specifies an application configuration feature option.
+type are:
default
The attribute value shall be a string. It shall describe what happens if
@@ -1224,8 +1218,8 @@ This type refines the following types:
``appl-config-option-type`` attribute if the value is ``integer``
This set of attributes specifies application configuration initializer or
-integer option. All explicitly defined attributes shall be specified. The
+integer option. All explicit attributes shall be specified. The explicit
constraints
@@ -1248,9 +1242,8 @@ This type refines the following types:
* :ref:`SpecTypeInterfaceItemType` though the ``interface-type`` attribute if
the value is ``union``
-This set of attributes specifies a compound (struct or union). All explicitly
+This set of attributes specifies a compound (struct or union). All explicit
brief
The attribute value shall be an :ref:`SpecTypeInterfaceBriefDescription`.
@@ -1292,8 +1285,8 @@ Interface Define Item Type
``interface-type`` attribute if the value is ``define``. This set of attributes
-specifies a define. All explicitly defined attributes shall be specified. The
+specifies a define. All explicit attributes shall be specified. The explicit
brief
@@ -1321,9 +1314,8 @@ This type refines the :ref:`SpecTypeInterfaceItemType` though the
specifies an interface domain. Items of the types
:ref:`SpecTypeInterfaceContainerItemType` and
:ref:`SpecTypeInterfaceHeaderFileItemType` are placed into domains through
-links with the :ref:`SpecTypeInterfacePlacementLinkRole`. All explicitly
+links with the :ref:`SpecTypeInterfacePlacementLinkRole`. All explicit
description
@@ -1340,8 +1332,8 @@ Interface Enum Item Type
``interface-type`` attribute if the value is ``enum``. This set of attributes
-specifies an enum. All explicitly defined attributes shall be specified. The
+specifies an enum. All explicit attributes shall be specified. The explicit
brief
@@ -1365,8 +1357,8 @@ Interface Enumerator Item Type
``interface-type`` attribute if the value is ``enumerator``. This set of
-attributes specifies an enumerator. All explicitly defined attributes shall be
+attributes specifies an enumerator. All explicit attributes shall be specified.
brief
@@ -1404,8 +1396,8 @@ Interface Function Item Type
``interface-type`` attribute if the value is ``function``. This set of
-attributes specifies a function. All explicitly defined attributes shall be
+attributes specifies a function. All explicit attributes shall be specified.
brief
@@ -1438,8 +1430,8 @@ Interface Group Item Type
``interface-type`` attribute if the value is ``group``. This set of attributes
-specifies an interface group. All explicitly defined attributes shall be
+specifies an interface group. All explicit attributes shall be specified. The
brief
@@ -1464,8 +1456,8 @@ This type refines the :ref:`SpecTypeInterfaceItemType` though the
attributes specifies a header file. The item shall have exactly one link with
the :ref:`SpecTypeInterfacePlacementLinkRole` to an
:ref:`SpecTypeInterfaceDomainItemType` item. This link defines the interface
-domain of the header file. All explicitly defined attributes shall be
+domain of the header file. All explicit attributes shall be specified. The
path
The attribute value shall be a string. It shall be the path used to include
@@ -1483,8 +1475,8 @@ Interface Macro Item Type
``interface-type`` attribute if the value is ``macro``. This set of attributes
-specifies a macro. All explicitly defined attributes shall be specified. The
+specifies a macro. All explicit attributes shall be specified. The explicit
brief
@@ -1516,8 +1508,8 @@ Interface Typedef Item Type
``interface-type`` attribute if the value is ``typedef``. This set of
-attributes specifies a typedef. All explicitly defined attributes shall be
+attributes specifies a typedef. All explicit attributes shall be specified. The
brief
@@ -1542,9 +1534,8 @@ Interface Unspecified Item Type
``interface-type`` attribute if the value is ``unspecified``. This set of
-attributes specifies an unspecified interface. All explicitly defined
-for this type:
+attributes specifies an unspecified interface. All explicit attributes shall be
name
The attribute value shall be a string. It shall be the name of the
@@ -1557,8 +1548,8 @@ Interface Variable Item Type
``interface-type`` attribute if the value is ``variable``. This set of
-attributes specifies a variable. All explicitly defined attributes shall be
+attributes specifies a variable. All explicit attributes shall be specified.
brief
@@ -1584,8 +1575,8 @@ Requirement Item Type
if the value is ``requirement``. This set of attributes specifies a
-requirement. All explicitly defined attributes shall be specified. The
+requirement. All explicit attributes shall be specified. The explicit
rationale
@@ -1633,9 +1624,8 @@ Functional Requirement Item Type
This type refines the :ref:`SpecTypeRequirementItemType` though the
``requirement-type`` attribute if the value is ``functional``. This set of
-attributes specifies a functional requirement. All explicitly defined
-for this type:
+attributes specifies a functional requirement. All explicit attributes shall be
functional-type
The attribute value shall be a :ref:`SpecTypeRequirementFunctionalType`. It
@@ -1648,9 +1638,8 @@ Non-Functional Requirement Item Type
``requirement-type`` attribute if the value is ``non-functional``. This set of
-attributes specifies a non-functional requirement. All explicitly defined
-for this type:
+attributes specifies a non-functional requirement. All explicit attributes
+shall be specified. The explicit attributes for this type are:
non-functional-type
@@ -1665,9 +1654,8 @@ Requirement Validation Item Type
if the value is ``validation``. This set of attributes provides a requirement
validation evidence. The item shall have exactly one link to the validated
-requirement with the :ref:`SpecTypeRequirementValidationLinkRole`. All
+requirement with the :ref:`SpecTypeRequirementValidationLinkRole`. All explicit
method
The attribute value shall be a :ref:`SpecTypeRequirementValidationMethod`.
@@ -1694,16 +1682,16 @@ Specification Item Type
if the value is ``spec``. This set of attributes specifies specification types.
+type are:
spec-description
The attribute value shall be an optional string. It shall be the
description of the specification type.
spec-example
- The attribute value shall be an optional string. If this value is present,
- then tt shall be an example of the specification type.
+ The attribute value shall be an optional string. If the value is present,
+ then it shall be an example of the specification type.
spec-info
The attribute value shall be a :ref:`SpecTypeSpecificationInformation`.
@@ -1746,7 +1734,7 @@ Please have a look at the following example:
spec-type: int
description: |
This set of attributes specifies an example.
- required-attributes: all
+ mandatory-attributes: all
spec-name: Example Item Type
spec-type: spec
type: spec
@@ -1758,8 +1746,8 @@ Test Case Item Type
if the value is ``test-case``. This set of attributes specifies a test case.
+type are:
actions
@@ -1774,15 +1762,15 @@ description
description.
epilogue
- The attribute value shall be an optional string. If the attribute value is
- present, then it shall be the test case epilogue code. The epilogue code
- is placed in the test case body after the test case actions.
+ then it shall be the test case epilogue code. The epilogue code is placed
+ in the test case body after the test case actions.
fixture
- present, then it shall be a pointer to the test case fixture. The test
- case fixture pointer declaration may be provided by the test case support
- code or via an included header file.
+ then it shall be a pointer to the test case fixture. The test case fixture
+ pointer declaration may be provided by the test case support code or via an
+ included header file.
includes
The attribute value shall be a list of strings. It shall be a list of
@@ -1796,15 +1784,15 @@ name
The attribute value shall be a :ref:`SpecTypeTestName`.
prologue
- present, then it shall be the test case prologue code. The prologue code
- is placed in the test case body before the test case actions. A use case
- is the declaration of local variables used by the test case actions.
+ then it shall be the test case prologue code. The prologue code is placed
+ in the test case body before the test case actions. A use case is the
+ declaration of local variables used by the test case actions.
support
- present, then it shall be the test case support code. The support code is
- placed at file scope before the test case code.
+ then it shall be the test case support code. The support code is placed at
+ file scope before the test case code.
target
@@ -1822,9 +1810,8 @@ if the value is ``test-platform``. Please note:
This item type is work in progress.
-This set of attributes specifies a test platform. All explicitly defined
-for this type:
+This set of attributes specifies a test platform. All explicit attributes shall
+be specified. The explicit attributes for this type are:
description
@@ -1846,9 +1833,8 @@ if the value is ``test-procedure``. Please note:
-This set of attributes specifies a test procedure. All explicitly defined
-for this type:
+This set of attributes specifies a test procedure. All explicit attributes
name
@@ -1869,8 +1855,8 @@ Test Suite Item Type
if the value is ``test-suite``. This set of attributes specifies a test suite.
+type are:
brief
The attribute value shall be a string. It shall be the test suite brief
@@ -1920,8 +1906,9 @@ Application Configuration Option Constraint Set
This set of attributes defines application configuration option constraints.
Additional constraints can be added through the links of the item using the
-:ref:`SpecTypeConstraintLinkRole`. None of the explicitly defined attributes
-are required. The following attributes are explicitly defined for this type:
+:ref:`SpecTypeConstraintLinkRole`. None of the explicit attributes is
+mandatory, they are all are optional. The explicit attributes for this type
+are:
max
The attribute value shall be an :ref:`SpecTypeIntegerOrString`. It shall be
@@ -2115,9 +2102,8 @@ This type is used by the following types:
Build Install Directive
-This set of attributes specifies files installed by a build item. All
+This set of attributes specifies files installed by a build item. All explicit
destination
The attribute value shall be a string. It shall be the install destination
@@ -2183,8 +2169,8 @@ Build Option Action
This set of attributes specifies a build option action. Exactly one of the
+are:
append-test-cppflags
The attribute value shall be a string. It shall be the name of a test
@@ -2376,8 +2362,8 @@ Build Option C Compiler Check Action
This set of attributes specifies a check done using the C compiler. All
+are:
cflags
@@ -2402,8 +2388,8 @@ Build Option C++ Compiler Check Action
This set of attributes specifies a check done using the C++ compiler. All
+are:
cxxflags
@@ -2428,8 +2414,8 @@ Build Option Default by Variant
This set of attributes specifies build option default values by variant. All
+are:
value
The attribute value shall be a :ref:`SpecTypeBuildOptionValue`. It value
@@ -2461,7 +2447,7 @@ Build Option Set Test State Action
This set of attributes specifies test states for a set of test programs.
-Generic attributes may be defined. Each attribute key shall be a
+Generic attributes may be specified. Each attribute key shall be a
:ref:`SpecTypeName`. The attribute value shall be a
:ref:`SpecTypeBuildTestState`. The keys shall be test program names. The names
shall correspond to the name of a :ref:`SpecTypeBuildTestProgramItemType` or
@@ -2649,8 +2635,8 @@ A value of this type shall be of one of the following variants:
value.
* The value may be a set of attributes. Each attribute defines an operator.
- Exactly one of the explicitly defined attributes shall be specified. The
- following attributes are explicitly defined for this type:
+ Exactly one of the explicit attributes shall be specified. The explicit
+ attributes for this type are:
and
The attribute value shall be a list. Each list element shall be an
@@ -2789,8 +2775,8 @@ This type refines the following types:
attribute if the value is ``union``
This set of attributes specifies an interface compound member compound. All
+are:
definition
@@ -2803,9 +2789,8 @@ Interface Compound Member Declaration
This type refines the :ref:`SpecTypeInterfaceCompoundMemberDefinition` though
the ``kind`` attribute if the value is ``member``. This set of attributes
-specifies an interface compound member declaration. All explicitly defined
-for this type:
+specifies an interface compound member declaration. All explicit attributes
definition
The attribute value shall be a string. It shall be the interface compound
@@ -2818,8 +2803,8 @@ Interface Compound Member Definition
This set of attributes specifies an interface compound member definition. All
+are:
brief
@@ -2853,8 +2838,8 @@ Interface Compound Member Definition Directive
-directive. All explicitly defined attributes shall be specified. The following
+directive. All explicit attributes shall be specified. The explicit attributes
+for this type are:
default
@@ -2877,8 +2862,8 @@ Interface Compound Member Definition Variant
-variant. All explicitly defined attributes shall be specified. The following
+variant. All explicit attributes shall be specified. The explicit attributes
+for this type are:
definition
@@ -2919,8 +2904,8 @@ Interface Definition Directive
This set of attributes specifies an interface definition directive. All
+are:
default
The attribute value shall be an :ref:`SpecTypeInterfaceDefinition`. The
@@ -2948,9 +2933,8 @@ This type is used by the following types:
Interface Definition Variant
-This set of attributes specifies an interface definition variant. All
+This set of attributes specifies an interface definition variant. All explicit
definition
@@ -3024,8 +3008,8 @@ A value of this type shall be of one of the following variants:
in the expression.
and
@@ -3091,9 +3075,8 @@ links.
Interface Function Definition
-This set of attributes specifies a function definition. All explicitly defined
-for this type:
+This set of attributes specifies a function definition. All explicit attributes
body
@@ -3124,9 +3107,8 @@ This type is used by the following types:
Interface Function Definition Directive
-This set of attributes specifies a function definition directive. All
+This set of attributes specifies a function definition directive. All explicit
default
The attribute value shall be an :ref:`SpecTypeInterfaceFunctionDefinition`.
@@ -3146,9 +3128,8 @@ This type is used by the following types:
Interface Function Definition Variant
-This set of attributes specifies a function definition variant. All explicitly
+This set of attributes specifies a function definition variant. All explicit
definition
@@ -3194,8 +3175,8 @@ This type refines the :ref:`SpecTypeLink` though the ``role`` attribute if the
value is ``interface-include``. It defines the interface include role of links
and is used to indicate that an interface container includes another interface
container. For example, one header file includes another header file. All
+are:
enabled-by
The attribute value shall be an :ref:`SpecTypeEnabledXByExpression`. It
@@ -3235,9 +3216,8 @@ This type is used by the following types:
Interface Parameter
-This set of attributes specifies an interface parameter. All explicitly defined
-for this type:
+This set of attributes specifies an interface parameter. All explicit
description
The attribute value shall be an :ref:`SpecTypeInterfaceDescription`.
@@ -3292,9 +3272,8 @@ interface container, for example a header file.
Interface Return Directive
-This set of attributes specifies an interface return. All explicitly defined
-for this type:
+This set of attributes specifies an interface return. All explicit attributes
return
The attribute value shall be an optional string. It shall describe the
@@ -3315,9 +3294,8 @@ This type is used by the following types:
Interface Return Value
-This set of attributes specifies an interface return value. All explicitly
+This set of attributes specifies an interface return value. All explicit
description
@@ -3346,8 +3324,8 @@ Link
This set of attributes specifies a link from one specification item to another
specification item. The links in a list are ordered. The first link in the
-list is processed first. All explicitly defined attributes shall be specified.
+list is processed first. All explicit attributes shall be specified. The
role
The attribute value shall be a :ref:`SpecTypeName`. It shall be the role of
@@ -3503,9 +3481,8 @@ This type is used by the following types:
Requirement Reference
-This set of attributes specifies a requirement reference. All explicitly
+This set of attributes specifies a requirement reference. All explicit
identifier
The attribute value shall be a string. It shall be the type-specific
@@ -3743,7 +3720,7 @@ This type is used by the following types:
Specification Attribute
:ref:`SpecTypeSpecificationAttributeValue`. The generic attributes specify an
attribute set.
@@ -3757,20 +3734,20 @@ This type is used by the following types:
Specification Attribute Set
-This set of attributes specifies a set of attributes. The following explicitly
-defined attributes are required:
+This set of attributes specifies a set of attributes. The following explicit
+attributes are mandatory:
* ``attributes``
* ``description``
-* ``required-attributes``
+* ``mandatory-attributes``
attributes
The attribute value shall be a :ref:`SpecTypeSpecificationAttribute`. It
- shall be the specification of the set of explicitly defined attributes.
+ shall be the specification of the set of explicit attributes.
description
@@ -3781,10 +3758,10 @@ generic-attributes
:ref:`SpecTypeSpecificationGenericAttributes`. It shall be the
specification of the generic attributes of the attribute set.
-required-attributes
+mandatory-attributes
- :ref:`SpecTypeSpecificationRequiredAttributes`. It shall be the set of
- required attributes of the attribute set.
+ :ref:`SpecTypeSpecificationMandatoryAttributes`. It shall be the set of
+ mandatory attributes of the attribute set.
@@ -3795,9 +3772,8 @@ This type is used by the following types:
Specification Attribute Value
-This set of attributes specifies an attribute value. All explicitly defined
-for this type:
+This set of attributes specifies an attribute value. All explicit attributes
description
@@ -3817,8 +3793,7 @@ Specification Boolean Value
This attribute set specifies a boolean value. Only the ``description``
-attribute is required. The following attributes are explicitly defined for this
-type:
+attribute is mandatory. The explicit attributes for this type are:
assert
The attribute value shall be a boolean. This optional attribute defines the
@@ -3849,8 +3824,8 @@ constraints.
and
@@ -3917,8 +3892,8 @@ Specification Floating-Point Value
This set of attributes specifies a floating-point value. Only the
-``description`` attribute is required. The following attributes are explicitly
+``description`` attribute is mandatory. The explicit attributes for this type
+are:
assert
@@ -3942,8 +3917,8 @@ Specification Generic Attributes
This set of attributes specifies generic attributes. Generic attributes are
attributes which are not explicitly defined. They are restricted to a uniform
-attribute value type. All explicitly defined attributes shall be specified. The
+attribute value type. All explicit attributes shall be specified. The explicit
description
@@ -3962,9 +3937,8 @@ This type is used by the following types:
Specification Information
-This set of attributes specifies attribute values. At least one of the
+This set of attributes specifies attribute values. At least one of the explicit
bool
The attribute value shall be a :ref:`SpecTypeSpecificationBooleanValue`. It
@@ -4009,8 +3983,8 @@ value of the specified attribute satisfies the required constraints.
and
@@ -4075,8 +4049,7 @@ Specification Integer Value
This set of attributes specifies an integer value. Only the ``description``
-type:
assert
The attribute value shall be a :ref:`SpecTypeSpecificationIntegerAssert`.
@@ -4097,9 +4070,8 @@ This type is used by the following types:
Specification List
-This set of attributes specifies a list of attributes or values. All explicitly
+This set of attributes specifies a list of attributes or values. All explicit
description
@@ -4113,6 +4085,36 @@ This type is used by the following types:
* :ref:`SpecTypeSpecificationInformation`
+.. _SpecTypeSpecificationMandatoryAttributes:
+Specification Mandatory Attributes
+It defines which explicit attributes are mandatory.
+A value of this type shall be of one of the following variants:
+* The value may be a list. Each list element shall be a :ref:`SpecTypeName`.
+ The list defines the mandatory attributes through their key names.
+* The value may be a string. It defines how many explicit attributes are
+ mandatory. If `none` is used, then none of the explicit attributes is
+ mandatory, they are all optional. The value shall be an element of
+ * "``all``",
+ * "``at-least-one``",
+ * "``at-most-one``",
+ * "``exactly-one``", and
+ * "``none``".
+This type is used by the following types:
+* :ref:`SpecTypeSpecificationAttributeSet`
.. _SpecTypeSpecificationMemberLinkRole:
Specification Member Link Role
@@ -4129,8 +4131,8 @@ Specification Refinement Link Role
value is ``spec-refinement``. It defines the specification refinement role of
-links. All explicitly defined attributes shall be specified. The following
+links. All explicit attributes shall be specified. The explicit attributes for
+this type are:
spec-key
@@ -4142,36 +4144,6 @@ spec-value
specification type refinement attribute value of the specification
refinement.
-.. _SpecTypeSpecificationRequiredAttributes:
-Specification Required Attributes
-This attribute value defines which of the explicitly defined attributes are
-required.
-A value of this type shall be of one of the following variants:
-* The value may be a list. Each list element shall be a :ref:`SpecTypeName`.
- This list defines the required attributes through their keys.
-* The value may be a string. This string defines the how many explicitly
- defined attributes are required. The value shall be an element of
- * "``all``",
- * "``at-least-one``",
- * "``at-most-one``",
- * "``exactly-one``", and
- * "``none``".
-This type is used by the following types:
-* :ref:`SpecTypeSpecificationAttributeSet`
.. _SpecTypeSpecificationStringAssert:
Specification String Assert
@@ -4183,8 +4155,8 @@ the specified attribute satisfies the required constraints.
and
@@ -4269,7 +4241,7 @@ Specification String Value
This set of attributes specifies a string. Only the ``description`` attribute
-is required. The following attributes are explicitly defined for this type:
+is mandatory. The explicit attributes for this type are:
assert
The attribute value shall be a :ref:`SpecTypeSpecificationStringAssert`.
@@ -4290,9 +4262,8 @@ This type is used by the following types:
Test Case Action
-This set of attributes specifies a test case action. All explicitly defined
-for this type:
+This set of attributes specifies a test case action. All explicit attributes
action
The attribute value shall be a string. It shall be the test case action
@@ -4319,9 +4290,8 @@ This type is used by the following types:
Test Case Check
-This set of attributes specifies a test case check. All explicitly defined
-for this type:
+This set of attributes specifies a test case check. All explicit attributes
check
The attribute value shall be a string. It shall be the test case check
2.26.2
