[PATCH 2/4] eng: Add generic attribute key types
Sebastian Huber
Thu Jun 4 13:02:27 UTC 2020
Update #3715.
eng/req/items.rst | 63 ++++++++++++++++++++++++++++-------------------
1 file changed, 37 insertions(+), 26 deletions(-)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 6bf992f..cf0805d 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -2447,8 +2447,8 @@ Build Option Set Test State Action
This set of attributes specifies test states for a set of test programs.
-Generic attributes may be specified. Each attribute key shall be a
-:ref:`SpecTypeName`. The attribute value shall be a
+Generic attributes may be specified. Each generic attribute key shall be a
+:ref:`SpecTypeName`. Each generic attribute value shall be a
:ref:`SpecTypeBuildTestState`. The keys shall be test program names. The names
shall correspond to the name of a :ref:`SpecTypeBuildTestProgramItemType` or
:ref:`SpecTypeBuildAdaTestProgramItemType` item. Due to the processing order
@@ -3385,6 +3385,8 @@ This type is used by the following types:
* :ref:`SpecTypeBuildItemType`
+* :ref:`SpecTypeBuildOptionSetTestStateAction`
* :ref:`SpecTypeGlossaryItemType`
* :ref:`SpecTypeInterfaceItemType`
@@ -3397,6 +3399,8 @@ This type is used by the following types:
* :ref:`SpecTypeSpecificationAttributeValue`
+* :ref:`SpecTypeSpecificationExplicitAttributes`
* :ref:`SpecTypeSpecificationGenericAttributes`
* :ref:`SpecTypeSpecificationItemType`
@@ -3715,20 +3719,6 @@ This type is used by the following types:
* :ref:`SpecTypeRootItemType`
-.. _SpecTypeSpecificationAttribute:
-Specification Attribute
-:ref:`SpecTypeSpecificationAttributeValue`. The generic attributes specify an
-attribute set.
-This type is used by the following types:
-* :ref:`SpecTypeSpecificationAttributeSet`
.. _SpecTypeSpecificationAttributeSet:
Specification Attribute Set
@@ -3746,8 +3736,9 @@ attributes are mandatory:
The explicit attributes for this type are:
attributes
- The attribute value shall be a :ref:`SpecTypeSpecificationAttribute`. It
- shall be the specification of the set of explicit attributes.
+ The attribute value shall be a
+ :ref:`SpecTypeSpecificationExplicitAttributes`. It shall specify the
+ explicit attributes of the attribute set.
description
The attribute value shall be an optional string. It shall be the
@@ -3755,12 +3746,12 @@ description
generic-attributes
- :ref:`SpecTypeSpecificationGenericAttributes`. It shall be the
- specification of the generic attributes of the attribute set.
+ :ref:`SpecTypeSpecificationGenericAttributes`. It shall specify the generic
+ attributes of the attribute set.
mandatory-attributes
- :ref:`SpecTypeSpecificationMandatoryAttributes`. It shall be the set of
+ :ref:`SpecTypeSpecificationMandatoryAttributes`. It shall specify the
mandatory attributes of the attribute set.
@@ -3785,7 +3776,7 @@ spec-type
-* :ref:`SpecTypeSpecificationAttribute`
.. _SpecTypeSpecificationBooleanValue:
@@ -3812,6 +3803,21 @@ This type is used by the following types:
* :ref:`SpecTypeSpecificationInformation`
+.. _SpecTypeSpecificationExplicitAttributes:
+Specification Explicit Attributes
+:ref:`SpecTypeSpecificationAttributeValue`. Each generic attribute specifies an
+explicit attribute of the attribute set. The key of the each generic attribute
+defines the attribute key of the explicit attribute.
+This type is used by the following types:
+* :ref:`SpecTypeSpecificationAttributeSet`
.. _SpecTypeSpecificationFloatingXPointAssert:
Specification Floating-Point Assert
@@ -3916,15 +3922,20 @@ Specification Generic Attributes
This set of attributes specifies generic attributes. Generic attributes are
-attributes which are not explicitly defined. They are restricted to a uniform
-attribute value type. All explicit attributes shall be specified. The explicit
-attributes for this type are:
+attributes which are not explicitly specified by
+:ref:`SpecTypeSpecificationExplicitAttributes`. They are restricted to uniform
+attribute key and value types. All explicit attributes shall be specified. The
+explicit attributes for this type are:
description
description of the generic attributes.
-spec-type
+key-spec-type
+ The attribute value shall be a :ref:`SpecTypeName`. It shall be the
+ specification type of the generic attribute keys.
+value-spec-type
specification type of the generic attribute values.
2.26.2
