[PATCH rtems-littlevgl 4/4] lv_drv_conf: Enable USE_BSD_EVDEV option
Vijay Kumar Banerjee
vijay at rtems.org
Thu Jun 4 18:44:34 UTC 2020
lv_drv_conf.h | 6 +++++-
1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/lv_drv_conf.h b/lv_drv_conf.h
index 697ceaf..e8d2c40 100644
--- a/lv_drv_conf.h
+++ b/lv_drv_conf.h
@@ -322,7 +322,11 @@
# define USE_EVDEV 0
#endif
-#if USE_EVDEV
+#ifndef USE_BSD_EVDEV
+# define USE_BSD_EVDEV 1
+#endif
+#if USE_EVDEV || USE_BSD_EVDEV
# define EVDEV_NAME "/dev/input/event0" /*You can use the "evtest" Linux tool to get the list of devices and test them*/
# define EVDEV_SWAP_AXES 0 /*Swap the x and y axes of the touchscreen*/
2.21.1
