[PATCH rtems-littlevgl 4/4] lv_drv_conf: Enable USE_BSD_EVDEV option
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jun 5 08:29:22 UTC 2020
Hello Vijay,
On 04/06/2020 20:44, Vijay Kumar Banerjee wrote:
>  lv_drv_conf.h | 6 +++++-
>  1 file changed, 5 insertions(+), 1 deletion(-)
> diff --git a/lv_drv_conf.h b/lv_drv_conf.h
> index 697ceaf..e8d2c40 100644
> --- a/lv_drv_conf.h
> +++ b/lv_drv_conf.h
> @@ -322,7 +322,11 @@
>  #  define USE_EVDEV           0
>  #endif
> -#if USE_EVDEV
> +#ifndef USE_BSD_EVDEV
> +#  define USE_BSD_EVDEV           1
> +#endif
I haven't tested it and haven't had a detailed look. But first question
that springs to my mind: Can we still use no evdev on targets without it
with this change? Or becomes some evdev module for libbsd mandatory with
it if you want to use lvgl?
Best regards
Christian
> +#if USE_EVDEV || USE_BSD_EVDEV
>  #  define EVDEV_NAME   "/dev/input/event0"        /*You can use the "evtest" Linux tool to get the list of devices and test them*/
>  #  define EVDEV_SWAP_AXES         0               /*Swap the x and y axes of the touchscreen*/
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
