LVGL applications with mouse
Vijay Kumar Banerjee
vijay at rtems.org
Sat Jun 6 11:09:54 UTC 2020
On Fri, Jun 5, 2020 at 8:30 PM Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Vijay,
> On 04/06/2020 21:36, Vijay Kumar Banerjee wrote:
> > Hi!
> > I had been looking for an opportunity to do this for a long time and I'm
> > excited to post that LVGL apps on RTEMS can now use input devices
> > through the evdev interface!
> Sounds like a nice feature.
> > I prepared some BSD evdev patches for lvgl repository and managed to get
> > them merged upstream. The patchset that I recently send to devel for
> > libbsd[1] and rtems-littlevgl[2], updates the rtems-libbsd and
> > rtems-littlevgl repository to adapt to the latest lvgl changes upstream
> > and adds the evdev support to rtems-littlevgl.
> > I wrote an example lvgl application that uses the mouse, connected
> > through USB port of Beaglebone black. The example application uses the
> > RTEMS logo, which makes it a bit heavier patch for the devel. I have
> > posted the commit on my github fork [3] and would really appreciate it
> > if someone can review and approve it to merge upstream.
> Although most likely touch screens are more common in embedded systems,
> it's a good example. A lot of touchscreens should work via evdev too.
I couldn't work on the touchscreen due to the lack of hardware. The
intention is indeed to enable the use of a touchscreen or mouse
through evdev interface.
Can you please test if the touchscreen works on BBB with evdev01.exe
test in libbsd? If this works, I'll try to get the touchscreen model
that you have (most probably after the lockdown is over :) ) and will
integrate it into the same demo app.
> Regarding the logo size: Also an RTEMS logo is a nice idea, maybe
> something smaller would be better to avoid that big file in the repo?
> Depending on how you generated the image: Maybe some run length encoding
> could reduce the size too (for example GIMP offers an option for that
> when exporting images to C sources).
Thanks for pointing this out. This indeed lowered the size by half.
I'm trying to get it working with lvgl and will post a patch to the
list once I get it done.
> > Finally, please have a look at this very short video that shows the
> > example application running. It uses many features of lvgl, including
> > image, button, and input:
> > https://blog.thelunatic.dev/assets/video/lvgl_rtems_logo.mp4
> Looks great.
Thanks.
Best regards,
Vijay
> Best regards
> Christian
> > We can now make full-fledged GUI applications with LVGL on RTEMS. :)
> > [1]: https://lists.rtems.org/pipermail/devel/2020-June/060049.html
> > [2]: https://lists.rtems.org/pipermail/devel/2020-June/060050.html
> > [3]:
> > https://github.com/thelunatic/rtems-examples/commit/c526d3c06a69591dc36e62af32728c51012ea6c1
> > Thanks!
> > Vijay
> > devel mailing list
> > devel at rtems.org
