[PATCH 2/2] Adding strong and weak definitions
Mon Jun 8 07:43:55 UTC 2020
On 07/06/2020 15:36, Sebastian Huber wrote:
> On 06/06/2020 15:09, Richi Dubey wrote:
>> Hii,
>> Thanks for your review.
>>> The glossary is generated from specification items:
>>> https://git.rtems.org/sebh/rtems-qual.git/tree/spec/glos/term
>>> I will work on a documentation how this works in the next days.
>> Have you already submitted one? If yes, could you please send me the
>> link to it. If no, Do I need to wait and learn that before sending in
>> the new patch?
> Yes, I sent a patch for the RTEMS Software Engineering manual:
> https://lists.rtems.org/pipermail/devel/2020-June/060036.html
> I will probably check it in tomorrow.
I updated the documentation:
https://docs.rtems.org/branches/master/eng/req/howto.html#getting-started
Could you please try to add the new glossary terms using the method
described in this how-to. You are some sort of a beta tester for this.
If anything is unclear, then please complain immediately.
