[PATCH 2/2] Adding strong and weak definitions
Richi Dubey richidubey at gmail.com
Wed Jun 10 14:41:10 UTC 2020
Hi,
Please mark the following required changes:
1) Add: cd rtems-qual/
After git clone and before git submodule init.
2) I am getting the following error on running git submodule update:
richi at YouAreAmazing:~/rtems-qual$ git submodule update
Cloning into '/home/richi/rtems-qual/external/rsb'...
Cloning into '/home/richi/rtems-qual/external/rtems'...
Cloning into '/home/richi/rtems-qual/external/rtems-docs'...
Submodule path 'external/rsb': checked out
'9482a1b33b4c8552f6affa582664b4ac25f9cdf4'
error: Server does not allow request for unadvertised object
aaa638b1550e94b37df382474fe4785a6cc7d350
Fetched in submodule path 'external/rtems', but it did not contain
aaa638b1550e94b37df382474fe4785a6cc7d350. Direct fetching of that
commit failed.
I don't understand this error.
3) Is the space in ". env/bin/activate" intentional?
4) I do not know how to use cite, Can i use it directly in the text field?
5) When I run ./spec2doc.py, I get the following error:
(env) richi at YouAreAmazing:~/rtems-qual$ ./spec2doc.py
Traceback (most recent call last):
  File "./spec2doc.py", line 41, in <module>
    main()
  File "./spec2doc.py", line 34, in main
    item_cache = rtemsqual.items.ItemCache(config["spec"])
  File "/home/richi/rtems-qual/rtemsqual/items.py", line 331, in __init__
    self._load_items(config)
  File "/home/richi/rtems-qual/rtemsqual/items.py", line 403, in _load_items
    self._load_items_recursive(path, path, cache_dir)
  File "/home/richi/rtems-qual/rtemsqual/items.py", line 381, in
    for name in os.listdir(path):
FileNotFoundError: [Errno 2] No such file or directory: 'external/rtems/spec'
Is it because I messed something up in the strongapa.yml ?
My /spec/glossary/strongapa.yml is :
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
enabled-by: true
glossary-type: term
links:
- role: glossary-member
  uid: ../glossary-general
term: Strong APA
text:
  In this model, on the arrival of a task, every task reachable
  from the newly arrived task is checked to see if an existing
  task can be shifted(or deallocated its processor) and newly
  arrived task can take its place if the newly arrived task has
  a higher priority. Similar analysis is done when a task
  finishes its execution (Here task and thread have interchangeable
  defintions).
  :cite:`Cerqueira:2014:LPA`.
type: glossary
Please tell me how to resolve this error.
Thanks,
Richi.
On Mon, Jun 8, 2020 at 1:13 PM Sebastian Huber
> On 07/06/2020 15:36, Sebastian Huber wrote:
> > On 06/06/2020 15:09, Richi Dubey wrote:
> >> Hii,
> >> Thanks for your review.
> >>> The glossary is generated from specification items:
> >>> https://git.rtems.org/sebh/rtems-qual.git/tree/spec/glos/term
> >>> I will work on a documentation how this works in the next days.
> >> Have you already submitted one? If yes, could you please send me the
> >> link to it. If no, Do I need to wait and learn that before sending in
> >> the new patch?
> > Yes, I sent a patch for the RTEMS Software Engineering manual:
> > https://lists.rtems.org/pipermail/devel/2020-June/060036.html
> > I will probably check it in tomorrow.
> I updated the documentation:
> https://docs.rtems.org/branches/master/eng/req/howto.html#getting-started
> Could you please try to add the new glossary terms using the method
> described in this how-to. You are some sort of a beta tester for this.
> If anything is unclear, then please complain immediately.
