Need help with configuring and using user defined scheduler
Kuan-Hsun Chen c0066c at gmail.com
Mon Jun 8 18:36:37 UTC 2020
Hi Richi,
If you just want to build the testsuites in sptest, you have to add an
option like "-enable-tests=yes" when you call ./configure.
Please have a look at git/rtems/testsuites/configure.ac, you should see
Line 48 has this condition.
(Just dig out my patch here:
https://lists.rtems.org/pipermail/devel/2016-December/016600.html, and I
did something similar as you)
Best,
Kuan-Hsun
On Mon, Jun 8, 2020 at 4:55 PM Sebastian Huber <
> Hello,
> I am not really motivated to explain the old build system. I hope we can
> create the RTEMS 5 branch soon and merge in the new build system.
> For experiments you can just modify the existing scheduler
> implementation. This avoids changing anything in the build system.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200608/5e9aee1b/attachment.html>
