Need help with configuring and using user defined scheduler
Richi Dubey richidubey at gmail.com
Tue Jun 9 12:33:28 UTC 2020
Dear Dr. Chen,
Hi, I saw your patch and it shows how to introduce a new test in the
testsuite. As others suggested, I might not make my test anytime soon.
But thank you for sharing this with me and I am going to bookmark this
for future reference when I develop a(another) test for strongapa.
Thanks,
Richi.
On Tue, Jun 9, 2020 at 12:07 AM Kuan-Hsun Chen <c0066c at gmail.com> wrote:
> Hi Richi,
> If you just want to build the testsuites in sptest, you have to add an option like "-enable-tests=yes" when you call ./configure.
> Please have a look at git/rtems/testsuites/configure.ac, you should see Line 48 has this condition.
> (Just dig out my patch here: https://lists.rtems.org/pipermail/devel/2016-December/016600.html, and I did something similar as you)
> Best,
> Kuan-Hsun
> On Mon, Jun 8, 2020 at 4:55 PM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> I am not really motivated to explain the old build system. I hope we can
>> create the RTEMS 5 branch soon and merge in the new build system.
>> For experiments you can just modify the existing scheduler
>> implementation. This avoids changing anything in the build system.
>> devel mailing list
>> devel at rtems.org
