Need help in figuring out how a scheduler is assigned to a task
Tue Jun 9 06:18:01 UTC 2020
Richi,
On Mon, Jun 8, 2020 at 8:52 AM Sebastian Huber
> On 08/06/2020 16:33, Richi Dubey wrote:
> > Thanks for telling me about the uniprocessor rule for having a single
> > scheduler for all the tasks. It makes sense. However I still cannot
> > find the code which actually links our processor to that scheduler!
> > Talking on a high level, I cannot find a code anywhere that tells
> > kernel/processor to use Simple scheduler for all the tasks when we
> > write #define CONFIGURE_SCHEDULER_SIMPLE inside a testcase(I could not
> > find anything related in the scheduler.h configuration file too). I
> > hope my doubt makes sense.
> Depending on the configuration options, the header file
> <rtems/confdefs/scheduler.h> defines a couple of data structures. One is
> the _Scheduler_Table:
> https://git.rtems.org/rtems/tree/cpukit/include/rtems/confdefs/scheduler.h#n239
> This is how the scheduler is defined for an application. You can look a
> the preprocessed header file to see all the data structures.
You will need to learn some techniques for navigating a large code
base. I don't know if there is a good tutorial out there, but check
out information about:
* ctags
* cscope
They can integrate with editors on *nix and provide you with
identifier/name/text search in an indexed database built from a
filesystem directory tree. Or you can use them from the command line
also. This is the best way to find code definitions and to navigate
code quickly. You can push/pop searches on a stack also, so you can
easily follow a function's control flow down, and then backtrace up.
UNIX utilities:
* grep
* ack (an updated variant of grep)
* find
Gedare
