Cacheable OCM support for the Zynq BSP
Jonathan Brandmeyer jbrandmeyer at planetiq.com
Wed Jun 10 23:30:35 UTC 2020
We've patched the RTEMS kernel in order to support using the Zynq on-chip
memory as inner-cacheable memory.  The enclosed patch should apply cleanly
to master.
Background: During normal startup, the ROM bootloader performs
vendor-specific initialization of  core 1, and then sits in a
wait-for-event loop until a special value has been written to a specific
address in OCM.  In that state, the MMU has not yet been initialized and
core 1 is treating OCM as Device memory.
By the time the RTEMS boot gets to _CPU_SMP_Start_processor, core 0's MMU
has already been initialized with the application-defined memory map.  I'd
like to use the on-chip memory as inner cacheable memory in my
application.  In order to ensure that the kick address write actually
becomes visible to core 1, a cache line flush of the affected line is
necessary prior to sending the event that wakes up the other core.
I also added an invalidation prior to the kick-address write out of an
abundance of caution.  it shouldn't be necessary, but I had a hard time
proving it definitively.
There are a plethora of cache maintenance functions available for the job
in RTEMS.  I picked an inline helper that operates directly on CP15.  The
code's commentary suggests that the L2 hasn't been initialized yet, and the
higher-level `rtems_cache_*_multiple_data_lines` API affects both L1D and
L2.  Also, I'm using inner-cacheable/outer-shareable memory attributes for
OCM specifically because of where it sits in the SOC's busswork, so it
turns out that we *never* need to flush L2 for that memory anyway.
Jonathan Brandmeyer
PlanetiQ
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200610/040ed465/attachment.html>
Type: application/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200610/040ed465/attachment.bin>
