Cacheable OCM support for the Zynq BSP
Wed Jun 10 23:57:29 UTC 2020
On 11/6/20 9:30 am, Jonathan Brandmeyer wrote:
> We've patched the RTEMS kernel in order to support using the Zynq on-chip memory
> as inner-cacheable memory.  The enclosed patch should apply cleanly to master.
> Background: During normal startup, the ROM bootloader performs vendor-specific
> initialization of  core 1, and then sits in a wait-for-event loop until a
> special value has been written to a specific address in OCM.  In that state, the
> MMU has not yet been initialized and core 1 is treating OCM as Device memory.
> By the time the RTEMS boot gets to _CPU_SMP_Start_processor, core 0's MMU has
> already been initialized with the application-defined memory map.  I'd like to
> use the on-chip memory as inner cacheable memory in my application.  In order to
> ensure that the kick address write actually becomes visible to core 1, a cache
> line flush of the affected line is necessary prior to sending the event that
> wakes up the other core.
Have the patches been tested with the OCM in the default state?
> I also added an invalidation prior to the kick-address write out of an abundance
> of caution.  it shouldn't be necessary, but I had a hard time proving it
> definitively.
> There are a plethora of cache maintenance functions available for the job in
> RTEMS.  I picked an inline helper that operates directly on CP15.  The code's
> commentary suggests that the L2 hasn't been initialized yet, and the
> higher-level `rtems_cache_*_multiple_data_lines` API affects both L1D and L2.
> Also, I'm using inner-cacheable/outer-shareable memory attributes for OCM
> specifically because of where it sits in the SOC's busswork, so it turns out
> that we *never* need to flush L2 for that memory anyway.
> Jonathan Brandmeyer
> PlanetiQ
> devel mailing list
> devel at rtems.org
