[PATCH RTEMS v2 1/6] libfreebsd: Import OFW files from FreeBSD.
G S Niteesh Babu
niteesh.gs at gmail.com
Thu Jun 11 12:23:10 UTC 2020
freebsd head: b8c57b4
The following files have been imported from FreeBSD to implement
OF_* functions into RTEMS.
1) openfirm.h
2) openfirm.c
3) ofw_fdt.c
cpukit/libfreebsd/dev/ofw/ofw_fdt.c | 479 +++++++++++++++
cpukit/libfreebsd/dev/ofw/openfirm.c | 848 +++++++++++++++++++++++++++
cpukit/libfreebsd/dev/ofw/openfirm.h | 187 ++++++
3 files changed, 1514 insertions(+)
create mode 100644 cpukit/libfreebsd/dev/ofw/ofw_fdt.c
create mode 100644 cpukit/libfreebsd/dev/ofw/openfirm.c
create mode 100644 cpukit/libfreebsd/dev/ofw/openfirm.h
diff --git a/cpukit/libfreebsd/dev/ofw/ofw_fdt.c b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
new file mode 100644
index 0000000000..e4f72e8142
--- /dev/null
+++ b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
@@ -0,0 +1,479 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2009-2010 The FreeBSD Foundation
+ * All rights reserved.
+ * This software was developed by Semihalf under sponsorship from
+ * the FreeBSD Foundation.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/kernel.h>
+#include <sys/malloc.h>
+#include <sys/systm.h>
+#include <contrib/libfdt/libfdt.h>
+#include <machine/stdarg.h>
+#include <dev/fdt/fdt_common.h>
+#include <dev/ofw/ofwvar.h>
+#include <dev/ofw/openfirm.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include "ofw_if.h"
+#ifdef DEBUG
+#define debugf(fmt, args...) do { printf("%s(): ", __func__); \
+ printf(fmt,##args); } while (0)
+#else
+#endif
+#if defined(__arm__)
+#if defined(SOC_MV_ARMADAXP) || defined(SOC_MV_ARMADA38X) || \
+ defined(SOC_MV_DISCOVERY) || defined(SOC_MV_DOVE) || \
+ defined(SOC_MV_FREY) || defined(SOC_MV_KIRKWOOD) || \
+ defined(SOC_MV_LOKIPLUS) || defined(SOC_MV_ORION)
+#define FDT_MARVELL
+#endif
+#endif
+static int ofw_fdt_init(ofw_t, void *);
+static phandle_t ofw_fdt_peer(ofw_t, phandle_t);
+static phandle_t ofw_fdt_child(ofw_t, phandle_t);
+static phandle_t ofw_fdt_parent(ofw_t, phandle_t);
+static phandle_t ofw_fdt_instance_to_package(ofw_t, ihandle_t);
+static ssize_t ofw_fdt_getproplen(ofw_t, phandle_t, const char *);
+static ssize_t ofw_fdt_getprop(ofw_t, phandle_t, const char *, void *, size_t);
+static int ofw_fdt_nextprop(ofw_t, phandle_t, const char *, char *, size_t);
+static int ofw_fdt_setprop(ofw_t, phandle_t, const char *, const void *,
+ size_t);
+static ssize_t ofw_fdt_canon(ofw_t, const char *, char *, size_t);
+static phandle_t ofw_fdt_finddevice(ofw_t, const char *);
+static ssize_t ofw_fdt_instance_to_path(ofw_t, ihandle_t, char *, size_t);
+static ssize_t ofw_fdt_package_to_path(ofw_t, phandle_t, char *, size_t);
+static int ofw_fdt_interpret(ofw_t, const char *, int, cell_t *);
+static ofw_method_t ofw_fdt_methods[] = {
+ OFWMETHOD(ofw_init, ofw_fdt_init),
+ OFWMETHOD(ofw_peer, ofw_fdt_peer),
+ OFWMETHOD(ofw_child, ofw_fdt_child),
+ OFWMETHOD(ofw_parent, ofw_fdt_parent),
+ OFWMETHOD(ofw_instance_to_package, ofw_fdt_instance_to_package),
+ OFWMETHOD(ofw_getproplen, ofw_fdt_getproplen),
+ OFWMETHOD(ofw_getprop, ofw_fdt_getprop),
+ OFWMETHOD(ofw_nextprop, ofw_fdt_nextprop),
+ OFWMETHOD(ofw_setprop, ofw_fdt_setprop),
+ OFWMETHOD(ofw_canon, ofw_fdt_canon),
+ OFWMETHOD(ofw_finddevice, ofw_fdt_finddevice),
+ OFWMETHOD(ofw_instance_to_path, ofw_fdt_instance_to_path),
+ OFWMETHOD(ofw_package_to_path, ofw_fdt_package_to_path),
+ OFWMETHOD(ofw_interpret, ofw_fdt_interpret),
+ { 0, 0 }
+static ofw_def_t ofw_fdt = {
+ OFW_FDT,
+ ofw_fdt_methods,
+ 0
+OFW_DEF(ofw_fdt);
+static void *fdtp = NULL;
+static int
+sysctl_handle_dtb(SYSCTL_HANDLER_ARGS)
+ return (sysctl_handle_opaque(oidp, fdtp, fdt_totalsize(fdtp), req));
+static void
+sysctl_register_fdt_oid(void *arg)
+ /* If there is no FDT registered, skip adding the sysctl */
+ if (fdtp == NULL)
+ return;
+ SYSCTL_ADD_PROC(NULL, SYSCTL_STATIC_CHILDREN(_hw_fdt), OID_AUTO, "dtb",
+ CTLTYPE_OPAQUE | CTLFLAG_RD | CTLFLAG_MPSAFE, NULL, 0,
+ sysctl_handle_dtb, "", "Device Tree Blob");
+SYSINIT(dtb_oid, SI_SUB_KMEM, SI_ORDER_ANY, sysctl_register_fdt_oid, NULL);
+static int
+ofw_fdt_init(ofw_t ofw, void *data)
+ int err;
+ /* Check FDT blob integrity */
+ if ((err = fdt_check_header(data)) != 0)
+ return (err);
+ fdtp = data;
+ return (0);
+ * Device tree functions.
+ * We use the offset from fdtp to the node as the 'phandle' in OF interface.
+ * phandle is a u32 value, therefore we cannot use the pointer to node as
+ * phandle in 64 bit. We also do not use the usual fdt offset as phandle,
+ * as it can be 0, and the OF interface has special meaning for phandle 0.
+static phandle_t
+fdt_offset_phandle(int offset)
+ if (offset < 0)
+ return (0);
+ return ((phandle_t)offset + fdt_off_dt_struct(fdtp));
+static int
+fdt_phandle_offset(phandle_t p)
+ int pint = (int)p;
+ int dtoff = fdt_off_dt_struct(fdtp);
+ if (pint < dtoff)
+ return (-1);
+ return (pint - dtoff);
+/* Return the next sibling of this node or 0. */
+static phandle_t
+ofw_fdt_peer(ofw_t ofw, phandle_t node)
+ int offset;
+ if (node == 0) {
+ /* Find root node */
+ offset = fdt_path_offset(fdtp, "/");
+ return (fdt_offset_phandle(offset));
+ offset = fdt_phandle_offset(node);
+ if (offset < 0)
+ return (0);
+ offset = fdt_next_subnode(fdtp, offset);
+/* Return the first child of this node or 0. */
+static phandle_t
+ofw_fdt_child(ofw_t ofw, phandle_t node)
+ int offset;
+ if (offset < 0)
+ return (0);
+ offset = fdt_first_subnode(fdtp, offset);
+/* Return the parent of this node or 0. */
+static phandle_t
+ofw_fdt_parent(ofw_t ofw, phandle_t node)
+ int offset, paroffset;
+ if (offset < 0)
+ return (0);
+ paroffset = fdt_parent_offset(fdtp, offset);
+ return (fdt_offset_phandle(paroffset));
+/* Return the package handle that corresponds to an instance handle. */
+static phandle_t
+ofw_fdt_instance_to_package(ofw_t ofw, ihandle_t instance)
+ /* Where real OF uses ihandles in the tree, FDT uses xref phandles */
+ return (OF_node_from_xref(instance));
+/* Get the length of a property of a package. */
+static ssize_t
+ofw_fdt_getproplen(ofw_t ofw, phandle_t package, const char *propname)
+ const void *prop;
+ int offset, len;
+ offset = fdt_phandle_offset(package);
+ if (offset < 0)
+ return (-1);
+ len = -1;
+ prop = fdt_getprop(fdtp, offset, propname, &len);
+ if (prop == NULL && strcmp(propname, "name") == 0) {
+ /* Emulate the 'name' property */
+ fdt_get_name(fdtp, offset, &len);
+ return (len + 1);
+ if (prop == NULL && offset == fdt_path_offset(fdtp, "/chosen")) {
+ if (strcmp(propname, "fdtbootcpu") == 0)
+ return (sizeof(cell_t));
+ if (strcmp(propname, "fdtmemreserv") == 0)
+ return (sizeof(uint64_t)*2*fdt_num_mem_rsv(fdtp));
+ if (prop == NULL)
+ return (-1);
+ return (len);
+/* Get the value of a property of a package. */
+static ssize_t
+ofw_fdt_getprop(ofw_t ofw, phandle_t package, const char *propname, void *buf,
+ size_t buflen)
+ const void *prop;
+ const char *name;
+ int len, offset;
+ uint32_t cpuid;
+ if (offset < 0)
+ return (-1);
+ name = fdt_get_name(fdtp, offset, &len);
+ strncpy(buf, name, buflen);
+ return (len + 1);
+ if (strcmp(propname, "fdtbootcpu") == 0) {
+ cpuid = cpu_to_fdt32(fdt_boot_cpuid_phys(fdtp));
+ len = sizeof(cpuid);
+ prop = &cpuid;
+ if (strcmp(propname, "fdtmemreserv") == 0) {
+ prop = (char *)fdtp + fdt_off_mem_rsvmap(fdtp);
+ len = sizeof(uint64_t)*2*fdt_num_mem_rsv(fdtp);
+ if (prop == NULL)
+ return (-1);
+ bcopy(prop, buf, min(len, buflen));
+ return (len);
+ * Get the next property of a package. Return values:
+ * -1: package or previous property does not exist
+ * 0: no more properties
+ * 1: success
+static int
+ofw_fdt_nextprop(ofw_t ofw, phandle_t package, const char *previous, char *buf,
+ size_t size)
+ const void *prop;
+ const char *name;
+ int offset;
+ if (offset < 0)
+ return (-1);
+ if (previous == NULL)
+ /* Find the first prop in the node */
+ offset = fdt_first_property_offset(fdtp, offset);
+ else {
+ fdt_for_each_property_offset(offset, fdtp, offset) {
+ prop = fdt_getprop_by_offset(fdtp, offset, &name, NULL);
+ if (prop == NULL)
+ return (-1); /* Internal error */
+ /* Skip until we find 'previous', then bail out */
+ if (strcmp(name, previous) != 0)
+ continue;
+ offset = fdt_next_property_offset(fdtp, offset);
+ break;
+ if (offset < 0)
+ return (0); /* No properties */
+ prop = fdt_getprop_by_offset(fdtp, offset, &name, &offset);
+ if (prop == NULL)
+ strncpy(buf, name, size);
+ return (1);
+/* Set the value of a property of a package. */
+static int
+ofw_fdt_setprop(ofw_t ofw, phandle_t package, const char *propname,
+ const void *buf, size_t len)
+ int offset;
+ if (offset < 0)
+ return (-1);
+ if (fdt_setprop_inplace(fdtp, offset, propname, buf, len) != 0)
+ /* Try to add property, when setting value inplace failed */
+ return (fdt_setprop(fdtp, offset, propname, buf, len));
+ return (0);
+/* Convert a device specifier to a fully qualified pathname. */
+static ssize_t
+ofw_fdt_canon(ofw_t ofw, const char *device, char *buf, size_t len)
+ return (-1);
+/* Return a package handle for the specified device. */
+static phandle_t
+ofw_fdt_finddevice(ofw_t ofw, const char *device)
+ int offset;
+ offset = fdt_path_offset(fdtp, device);
+ if (offset < 0)
+ return (-1);
+/* Return the fully qualified pathname corresponding to an instance. */
+static ssize_t
+ofw_fdt_instance_to_path(ofw_t ofw, ihandle_t instance, char *buf, size_t len)
+ phandle_t phandle;
+ phandle = OF_instance_to_package(instance);
+ if (phandle == -1)
+ return (-1);
+ return (OF_package_to_path(phandle, buf, len));
+/* Return the fully qualified pathname corresponding to a package. */
+static ssize_t
+ofw_fdt_package_to_path(ofw_t ofw, phandle_t package, char *buf, size_t len)
+ return (-1);
+#if defined(FDT_MARVELL)
+static int
+ofw_fdt_fixup(ofw_t ofw)
+#define FDT_MODEL_LEN 80
+ char model[FDT_MODEL_LEN];
+ phandle_t root;
+ ssize_t len;
+ int i;
+ if ((root = ofw_fdt_finddevice(ofw, "/")) == -1)
+ return (ENODEV);
+ if ((len = ofw_fdt_getproplen(ofw, root, "model")) <= 0)
+ return (0);
+ bzero(model, FDT_MODEL_LEN);
+ if (ofw_fdt_getprop(ofw, root, "model", model, FDT_MODEL_LEN) <= 0)
+ return (0);
+ * Search fixup table and call handler if appropriate.
+ for (i = 0; fdt_fixup_table[i].model != NULL; i++) {
+ if (strncmp(model, fdt_fixup_table[i].model,
+ FDT_MODEL_LEN) != 0)
+ * Sometimes it's convenient to provide one
+ * fixup entry that refers to many boards.
+ * To handle this case, simply check if model
+ * is compatible parameter
+ if(!ofw_bus_node_is_compatible(root,
+ fdt_fixup_table[i].model))
+ continue;
+ if (fdt_fixup_table[i].handler != NULL)
+ (*fdt_fixup_table[i].handler)(root);
+ return (0);
+#endif
+static int
+ofw_fdt_interpret(ofw_t ofw, const char *cmd, int nret, cell_t *retvals)
+ int rv;
+ * Note: FDT does not have the possibility to 'interpret' commands,
+ * but we abuse the interface a bit to use it for doing non-standard
+ * operations on the device tree blob.
+ * Currently the only supported 'command' is to trigger performing
+ * fixups.
+ if (strncmp("perform-fixup", cmd, 13) != 0)
+ return (0);
+ rv = ofw_fdt_fixup(ofw);
+ if (nret > 0)
+ retvals[0] = rv;
+ return (rv);
+#else
+ return (0);
+#endif
\ No newline at end of file
diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.c b/cpukit/libfreebsd/dev/ofw/openfirm.c
index 0000000000..50ebf2cf16
--- /dev/null
+++ b/cpukit/libfreebsd/dev/ofw/openfirm.c
@@ -0,0 +1,848 @@
+/* $NetBSD: Locore.c,v 1.7 2000/08/20 07:04:59 tsubai Exp $ */
+ * SPDX-License-Identifier: BSD-4-Clause
+ * Copyright (C) 1995, 1996 Wolfgang Solfrank.
+ * Copyright (C) 1995, 1996 TooLs GmbH.
+ * are met:
+ * 3. All advertising materials mentioning features or use of this software
+ * must display the following acknowledgement:
+ * This product includes software developed by TooLs GmbH.
+ * 4. The name of TooLs GmbH may not be used to endorse or promote products
+ * derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY TOOLS GMBH ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL TOOLS GMBH BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Copyright (C) 2000 Benno Rice.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY Benno Rice ``AS IS'' AND ANY EXPRESS OR
+#include "opt_platform.h"
+#include <sys/lock.h>
+#include <sys/mutex.h>
+#include <sys/queue.h>
+#include <sys/endian.h>
+static void OF_putchar(int c, void *arg);
+MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
+static ihandle_t stdout;
+static ofw_def_t *ofw_def_impl = NULL;
+static ofw_t ofw_obj;
+static struct ofw_kobj ofw_kernel_obj;
+static struct kobj_ops ofw_kernel_kops;
+struct xrefinfo {
+ phandle_t xref;
+ phandle_t node;
+ device_t dev;
+ SLIST_ENTRY(xrefinfo) next_entry;
+static SLIST_HEAD(, xrefinfo) xreflist = SLIST_HEAD_INITIALIZER(xreflist);
+static struct mtx xreflist_lock;
+static boolean_t xref_init_done;
+#define FIND_BY_XREF 0
+#define FIND_BY_NODE 1
+#define FIND_BY_DEV 2
+ * xref-phandle-device lookup helper routines.
+ * As soon as we are able to use malloc(), walk the node tree and build a list
+ * of info that cross-references node handles, xref handles, and device_t
+ * instances. This list exists primarily to allow association of a device_t
+ * with an xref handle, but it is also used to speed up translation between xref
+ * and node handles. Before malloc() is available we have to recursively search
+ * the node tree each time we want to translate between a node and xref handle.
+ * Afterwards we can do the translations by searching this much shorter list.
+static void
+xrefinfo_create(phandle_t node)
+ struct xrefinfo * xi;
+ phandle_t child, xref;
+ * Recursively descend from parent, looking for nodes with a property
+ * named either "phandle", "ibm,phandle", or "linux,phandle". For each
+ * such node found create an entry in the xreflist.
+ for (child = OF_child(node); child != 0; child = OF_peer(child)) {
+ xrefinfo_create(child);
+ if (OF_getencprop(child, "phandle", &xref, sizeof(xref)) ==
+ -1 && OF_getencprop(child, "ibm,phandle", &xref,
+ sizeof(xref)) == -1 && OF_getencprop(child,
+ "linux,phandle", &xref, sizeof(xref)) == -1)
+ continue;
+ xi = malloc(sizeof(*xi), M_OFWPROP, M_WAITOK | M_ZERO);
+ xi->node = child;
+ xi->xref = xref;
+ SLIST_INSERT_HEAD(&xreflist, xi, next_entry);
+static void
+xrefinfo_init(void *unsed)
+ * There is no locking during this init because it runs much earlier
+ * than any of the clients/consumers of the xref list data, but we do
+ * initialize the mutex that will be used for access later.
+ mtx_init(&xreflist_lock, "OF xreflist lock", NULL, MTX_DEF);
+ xrefinfo_create(OF_peer(0));
+ xref_init_done = true;
+SYSINIT(xrefinfo, SI_SUB_KMEM, SI_ORDER_ANY, xrefinfo_init, NULL);
+static struct xrefinfo *
+xrefinfo_find(uintptr_t key, int find_by)
+ struct xrefinfo *rv, *xi;
+ rv = NULL;
+ mtx_lock(&xreflist_lock);
+ SLIST_FOREACH(xi, &xreflist, next_entry) {
+ if ((find_by == FIND_BY_XREF && (phandle_t)key == xi->xref) ||
+ (find_by == FIND_BY_NODE && (phandle_t)key == xi->node) ||
+ (find_by == FIND_BY_DEV && key == (uintptr_t)xi->dev)) {
+ rv = xi;
+ break;
+ mtx_unlock(&xreflist_lock);
+ return (rv);
+xrefinfo_add(phandle_t node, phandle_t xref, device_t dev)
+ struct xrefinfo *xi;
+ xi = malloc(sizeof(*xi), M_OFWPROP, M_WAITOK);
+ xi->node = node;
+ xi->xref = xref;
+ xi->dev = dev;
+ return (xi);
+ * OFW install routines. Highest priority wins, equal priority also
+ * overrides allowing last-set to win.
+SET_DECLARE(ofw_set, ofw_def_t);
+boolean_t
+OF_install(char *name, int prio)
+ ofw_def_t *ofwp, **ofwpp;
+ static int curr_prio = 0;
+ /* Allow OF layer to be uninstalled */
+ if (name == NULL) {
+ ofw_def_impl = NULL;
+ return (FALSE);
+ * Try and locate the OFW kobj corresponding to the name.
+ SET_FOREACH(ofwpp, ofw_set) {
+ ofwp = *ofwpp;
+ if (ofwp->name &&
+ !strcmp(ofwp->name, name) &&
+ prio >= curr_prio) {
+ curr_prio = prio;
+ ofw_def_impl = ofwp;
+ return (TRUE);
+ return (FALSE);
+/* Initializer */
+int
+OF_init(void *cookie)
+ phandle_t chosen;
+ int rv;
+ if (ofw_def_impl == NULL)
+ return (-1);
+ ofw_obj = &ofw_kernel_obj;
+ * Take care of compiling the selected class, and
+ * then statically initialize the OFW object.
+ kobj_class_compile_static(ofw_def_impl, &ofw_kernel_kops);
+ kobj_init_static((kobj_t)ofw_obj, ofw_def_impl);
+ rv = OFW_INIT(ofw_obj, cookie);
+ if ((chosen = OF_finddevice("/chosen")) != -1)
+ if (OF_getencprop(chosen, "stdout", &stdout,
+ sizeof(stdout)) == -1)
+ stdout = -1;
+ return (rv);
+static void
+OF_putchar(int c, void *arg __unused)
+ char cbuf;
+ if (c == '\n') {
+ cbuf = '\r';
+ OF_write(stdout, &cbuf, 1);
+ cbuf = c;
+void
+OF_printf(const char *fmt, ...)
+ va_list va;
+ va_start(va, fmt);
+ (void)kvprintf(fmt, OF_putchar, NULL, 10, va);
+ va_end(va);
+ * Generic functions
+/* Test to see if a service exists. */
+int
+OF_test(const char *name)
+ return (-1);
+ return (OFW_TEST(ofw_obj, name));
+int
+OF_interpret(const char *cmd, int nreturns, ...)
+ va_list ap;
+ cell_t slots[16];
+ int i = 0;
+ int status;
+ return (-1);
+ status = OFW_INTERPRET(ofw_obj, cmd, nreturns, slots);
+ if (status == -1)
+ return (status);
+ va_start(ap, nreturns);
+ while (i < nreturns)
+ *va_arg(ap, cell_t *) = slots[i++];
+ va_end(ap);
+ return (status);
+phandle_t
+OF_peer(phandle_t node)
+ return (0);
+ return (OFW_PEER(ofw_obj, node));
+phandle_t
+OF_child(phandle_t node)
+ return (0);
+ return (OFW_CHILD(ofw_obj, node));
+phandle_t
+OF_parent(phandle_t node)
+ return (0);
+ return (OFW_PARENT(ofw_obj, node));
+phandle_t
+OF_instance_to_package(ihandle_t instance)
+ return (-1);
+ return (OFW_INSTANCE_TO_PACKAGE(ofw_obj, instance));
+ssize_t
+OF_getproplen(phandle_t package, const char *propname)
+ return (-1);
+ return (OFW_GETPROPLEN(ofw_obj, package, propname));
+/* Check existence of a property of a package. */
+int
+OF_hasprop(phandle_t package, const char *propname)
+ return (OF_getproplen(package, propname) >= 0 ? 1 : 0);
+ssize_t
+OF_getprop(phandle_t package, const char *propname, void *buf, size_t buflen)
+ return (-1);
+ return (OFW_GETPROP(ofw_obj, package, propname, buf, buflen));
+ssize_t
+OF_getencprop(phandle_t node, const char *propname, pcell_t *buf, size_t len)
+ ssize_t retval;
+ int i;
+ KASSERT(len % 4 == 0, ("Need a multiple of 4 bytes"));
+ retval = OF_getprop(node, propname, buf, len);
+ if (retval <= 0)
+ return (retval);
+ for (i = 0; i < len/4; i++)
+ buf[i] = be32toh(buf[i]);
+ return (retval);
+ * Recursively search the node and its parent for the given property, working
+ * downward from the node to the device tree root. Returns the value of the
+ * first match.
+ssize_t
+OF_searchprop(phandle_t node, const char *propname, void *buf, size_t len)
+ ssize_t rv;
+ for (; node != 0; node = OF_parent(node))
+ if ((rv = OF_getprop(node, propname, buf, len)) != -1)
+ return (rv);
+ return (-1);
+ssize_t
+OF_searchencprop(phandle_t node, const char *propname, pcell_t *buf, size_t len)
+ ssize_t rv;
+ if ((rv = OF_getencprop(node, propname, buf, len)) != -1)
+ return (rv);
+ return (-1);
+ * Store the value of a property of a package into newly allocated memory
+ * (using the M_OFWPROP malloc pool and M_WAITOK).
+ssize_t
+OF_getprop_alloc(phandle_t package, const char *propname, void **buf)
+ int len;
+ *buf = NULL;
+ if ((len = OF_getproplen(package, propname)) == -1)
+ return (-1);
+ if (len > 0) {
+ *buf = malloc(len, M_OFWPROP, M_WAITOK);
+ if (OF_getprop(package, propname, *buf, len) == -1) {
+ free(*buf, M_OFWPROP);
+ *buf = NULL;
+ return (-1);
+ return (len);
+ * (using the M_OFWPROP malloc pool and M_WAITOK). elsz is the size of a
+ * single element, the number of elements is return in number.
+ssize_t
+OF_getprop_alloc_multi(phandle_t package, const char *propname, int elsz, void **buf)
+ int len;
+ *buf = NULL;
+ if ((len = OF_getproplen(package, propname)) == -1 ||
+ len % elsz != 0)
+ return (-1);
+ if (len > 0) {
+ *buf = NULL;
+ return (-1);
+ return (len / elsz);
+ssize_t
+OF_getencprop_alloc(phandle_t package, const char *name, void **buf)
+ ssize_t ret;
+ ret = OF_getencprop_alloc_multi(package, name, sizeof(pcell_t),
+ buf);
+ if (ret < 0)
+ return (ret);
+ else
+ return (ret * sizeof(pcell_t));
+ssize_t
+OF_getencprop_alloc_multi(phandle_t package, const char *name, int elsz,
+ void **buf)
+ ssize_t retval;
+ pcell_t *cell;
+ int i;
+ retval = OF_getprop_alloc_multi(package, name, elsz, buf);
+ if (retval == -1)
+ return (-1);
+ cell = *buf;
+ for (i = 0; i < retval * elsz / 4; i++)
+ cell[i] = be32toh(cell[i]);
+ return (retval);
+/* Free buffer allocated by OF_getencprop_alloc or OF_getprop_alloc */
+void OF_prop_free(void *buf)
+ free(buf, M_OFWPROP);
+/* Get the next property of a package. */
+int
+OF_nextprop(phandle_t package, const char *previous, char *buf, size_t size)
+ return (-1);
+ return (OFW_NEXTPROP(ofw_obj, package, previous, buf, size));
+int
+OF_setprop(phandle_t package, const char *propname, const void *buf, size_t len)
+ return (-1);
+ return (OFW_SETPROP(ofw_obj, package, propname, buf,len));
+ssize_t
+OF_canon(const char *device, char *buf, size_t len)
+ return (-1);
+ return (OFW_CANON(ofw_obj, device, buf, len));
+phandle_t
+OF_finddevice(const char *device)
+ return (-1);
+ return (OFW_FINDDEVICE(ofw_obj, device));
+ssize_t
+OF_instance_to_path(ihandle_t instance, char *buf, size_t len)
+ return (-1);
+ return (OFW_INSTANCE_TO_PATH(ofw_obj, instance, buf, len));
+ssize_t
+OF_package_to_path(phandle_t package, char *buf, size_t len)
+ return (-1);
+ return (OFW_PACKAGE_TO_PATH(ofw_obj, package, buf, len));
+/* Look up effective phandle (see FDT/PAPR spec) */
+static phandle_t
+OF_child_xref_phandle(phandle_t parent, phandle_t xref)
+ phandle_t child, rxref;
+ * Recursively descend from parent, looking for a node with a property
+ * named either "phandle", "ibm,phandle", or "linux,phandle" that
+ * matches the xref we are looking for.
+ for (child = OF_child(parent); child != 0; child = OF_peer(child)) {
+ rxref = OF_child_xref_phandle(child, xref);
+ if (rxref != -1)
+ return (rxref);
+ if (OF_getencprop(child, "phandle", &rxref, sizeof(rxref)) ==
+ -1 && OF_getencprop(child, "ibm,phandle", &rxref,
+ sizeof(rxref)) == -1 && OF_getencprop(child,
+ "linux,phandle", &rxref, sizeof(rxref)) == -1)
+ continue;
+ if (rxref == xref)
+ return (child);
+ return (-1);
+phandle_t
+OF_node_from_xref(phandle_t xref)
+ phandle_t node;
+ if (xref_init_done) {
+ if ((xi = xrefinfo_find(xref, FIND_BY_XREF)) == NULL)
+ return (xref);
+ return (xi->node);
+ if ((node = OF_child_xref_phandle(OF_peer(0), xref)) == -1)
+ return (xref);
+ return (node);
+phandle_t
+OF_xref_from_node(phandle_t node)
+ phandle_t xref;
+ if ((xi = xrefinfo_find(node, FIND_BY_NODE)) == NULL)
+ return (node);
+ return (xi->xref);
+ if (OF_getencprop(node, "phandle", &xref, sizeof(xref)) == -1 &&
+ OF_getencprop(node, "ibm,phandle", &xref, sizeof(xref)) == -1 &&
+ OF_getencprop(node, "linux,phandle", &xref, sizeof(xref)) == -1)
+ return (node);
+ return (xref);
+device_t
+OF_device_from_xref(phandle_t xref)
+ return (NULL);
+ return (xi->dev);
+ panic("Attempt to find device before xreflist_init");
+phandle_t
+OF_xref_from_device(device_t dev)
+ if ((xi = xrefinfo_find((uintptr_t)dev, FIND_BY_DEV)) == NULL)
+ return (0);
+ panic("Attempt to find xref before xreflist_init");
+int
+OF_device_register_xref(phandle_t xref, device_t dev)
+ * If the given xref handle doesn't already exist in the list then we
+ * add a list entry. In theory this can only happen on a system where
+ * nodes don't contain phandle properties and xref and node handles are
+ * synonymous, so the xref handle is added as the node handle as well.
+ xrefinfo_add(xref, xref, dev);
+ else
+ xi->dev = dev;
+ return (0);
+ panic("Attempt to register device before xreflist_init");
+/* Call the method in the scope of a given instance. */
+int
+OF_call_method(const char *method, ihandle_t instance, int nargs, int nreturns,
+ va_list ap;
+ cell_t args_n_results[12];
+ int n, status;
+ if (nargs > 6 || ofw_def_impl == NULL)
+ return (-1);
+ for (n = 0; n < nargs; n++)
+ args_n_results[n] = va_arg(ap, cell_t);
+ status = OFW_CALL_METHOD(ofw_obj, instance, method, nargs, nreturns,
+ args_n_results);
+ if (status != 0)
+ return (status);
+ for (; n < nargs + nreturns; n++)
+ *va_arg(ap, cell_t *) = args_n_results[n];
+ va_end(ap);
+ return (0);
+ * Device I/O functions
+/* Open an instance for a device. */
+ihandle_t
+OF_open(const char *device)
+ return (0);
+ return (OFW_OPEN(ofw_obj, device));
+/* Close an instance. */
+void
+OF_close(ihandle_t instance)
+ return;
+ OFW_CLOSE(ofw_obj, instance);
+/* Read from an instance. */
+ssize_t
+OF_read(ihandle_t instance, void *addr, size_t len)
+ return (-1);
+ return (OFW_READ(ofw_obj, instance, addr, len));
+/* Write to an instance. */
+ssize_t
+OF_write(ihandle_t instance, const void *addr, size_t len)
+ return (-1);
+ return (OFW_WRITE(ofw_obj, instance, addr, len));
+/* Seek to a position. */
+int
+OF_seek(ihandle_t instance, uint64_t pos)
+ return (-1);
+ return (OFW_SEEK(ofw_obj, instance, pos));
+ * Memory functions
+/* Claim an area of memory. */
+void *
+OF_claim(void *virt, size_t size, u_int align)
+ return ((void *)-1);
+ return (OFW_CLAIM(ofw_obj, virt, size, align));
+/* Release an area of memory. */
+void
+OF_release(void *virt, size_t size)
+ return;
+ OFW_RELEASE(ofw_obj, virt, size);
+ * Control transfer functions
+/* Suspend and drop back to the Open Firmware interface. */
+void
+OF_enter()
+ return;
+ OFW_ENTER(ofw_obj);
+/* Shut down and drop back to the Open Firmware interface. */
+void
+OF_exit()
+ panic("OF_exit: Open Firmware not available");
+ /* Should not return */
+ OFW_EXIT(ofw_obj);
+ for (;;) /* just in case */
diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.h b/cpukit/libfreebsd/dev/ofw/openfirm.h
index 0000000000..74a7075367
--- /dev/null
+++ b/cpukit/libfreebsd/dev/ofw/openfirm.h
@@ -0,0 +1,187 @@
+/* $NetBSD: openfirm.h,v 1.1 1998/05/15 10:16:00 tsubai Exp $ */
+ * SPDX-License-Identifier: (BSD-4-Clause AND BSD-2-Clause-FreeBSD)
+ * are met:
+ * are met:
+ * $FreeBSD$
+#ifndef _DEV_OPENFIRM_H_
+#define _DEV_OPENFIRM_H_
+#include <sys/types.h>
+#include <machine/_bus.h>
+ * Prototypes for Open Firmware Interface Routines
+typedef uint32_t ihandle_t;
+typedef uint32_t phandle_t;
+typedef uint32_t pcell_t;
+#ifdef _KERNEL
+#include <machine/ofw_machdep.h>
+MALLOC_DECLARE(M_OFWPROP);
+ * Open Firmware interface initialization. OF_install installs the named
+ * interface as the Open Firmware access mechanism, OF_init initializes it.
+boolean_t OF_install(char *name, int prio);
+int OF_init(void *cookie);
+ * Known Open Firmware interface names
+#define OFW_STD_DIRECT "ofw_std" /* Standard OF interface */
+#define OFW_STD_REAL "ofw_real" /* Real-mode OF interface */
+#define OFW_STD_32BIT "ofw_32bit" /* 32-bit OF interface */
+#define OFW_FDT "ofw_fdt" /* Flattened Device Tree */
+/* Generic functions */
+int OF_test(const char *name);
+void OF_printf(const char *fmt, ...);
+/* Device tree functions */
+phandle_t OF_peer(phandle_t node);
+phandle_t OF_child(phandle_t node);
+phandle_t OF_parent(phandle_t node);
+ssize_t OF_getproplen(phandle_t node, const char *propname);
+ssize_t OF_getprop(phandle_t node, const char *propname, void *buf,
+ size_t len);
+ssize_t OF_getencprop(phandle_t node, const char *prop, pcell_t *buf,
+ size_t len); /* Same as getprop, but maintains endianness */
+int OF_hasprop(phandle_t node, const char *propname);
+ssize_t OF_searchprop(phandle_t node, const char *propname, void *buf,
+ size_t len);
+ssize_t OF_searchencprop(phandle_t node, const char *propname,
+ pcell_t *buf, size_t len);
+ssize_t OF_getprop_alloc(phandle_t node, const char *propname,
+ void **buf);
+ssize_t OF_getprop_alloc_multi(phandle_t node, const char *propname,
+ int elsz, void **buf);
+ssize_t OF_getencprop_alloc(phandle_t node, const char *propname,
+ void **buf);
+ssize_t OF_getencprop_alloc_multi(phandle_t node, const char *propname,
+void OF_prop_free(void *buf);
+int OF_nextprop(phandle_t node, const char *propname, char *buf,
+ size_t len);
+int OF_setprop(phandle_t node, const char *name, const void *buf,
+ size_t len);
+ssize_t OF_canon(const char *path, char *buf, size_t len);
+phandle_t OF_finddevice(const char *path);
+ssize_t OF_package_to_path(phandle_t node, char *buf, size_t len);
+ * Some OF implementations (IBM, FDT) have a concept of effective phandles
+ * used for device-tree cross-references. Given one of these, returns the
+ * real phandle. If one can't be found (or running on OF implementations
+ * without this property), returns its input.
+phandle_t OF_node_from_xref(phandle_t xref);
+phandle_t OF_xref_from_node(phandle_t node);
+ * When properties contain references to other nodes using xref handles it is
+ * often necessary to use interfaces provided by the driver for the referenced
+ * instance. These routines allow a driver that provides such an interface to
+ * register its association with an xref handle, and for other drivers to obtain
+ * the device_t associated with an xref handle.
+device_t OF_device_from_xref(phandle_t xref);
+phandle_t OF_xref_from_device(device_t dev);
+int OF_device_register_xref(phandle_t xref, device_t dev);
+/* Device I/O functions */
+ihandle_t OF_open(const char *path);
+void OF_close(ihandle_t instance);
+ssize_t OF_read(ihandle_t instance, void *buf, size_t len);
+ssize_t OF_write(ihandle_t instance, const void *buf, size_t len);
+int OF_seek(ihandle_t instance, uint64_t where);
+phandle_t OF_instance_to_package(ihandle_t instance);
+ssize_t OF_instance_to_path(ihandle_t instance, char *buf, size_t len);
+int OF_call_method(const char *method, ihandle_t instance,
+ int nargs, int nreturns, ...);
+/* Memory functions */
+void *OF_claim(void *virtrequest, size_t size, u_int align);
+void OF_release(void *virt, size_t size);
+/* Control transfer functions */
+void OF_enter(void);
+void OF_exit(void) __attribute__((noreturn));
+/* User interface functions */
+int OF_interpret(const char *cmd, int nreturns, ...);
+ * Decode the Nth register property of the given device node and create a bus
+ * space tag and handle for accessing it. This is for use in setting up things
+ * like early console output before newbus is available.
+int OF_decode_addr(phandle_t dev, int regno, bus_space_tag_t *ptag,
+ bus_space_handle_t *phandle, bus_size_t *sz);
+#endif /* _KERNEL */
+#endif /* _DEV_OPENFIRM_H_ */
2.17.1
