[PATCH RTEMS v2 2/6] libfreebsd: Added ofw_if.h
G S Niteesh Babu niteesh.gs at gmail.com
Thu Jun 11 12:23:11 UTC 2020
This file is the RTEMS implementation of ofw_if.h in FreeBSD. The
ofw_if.h in FreeBSD is an autogenerated header file that maps the
OF_function calls to their respective implementation. But in RTEMS
this file maps the OF_functions directly to their FDT implementation.
 cpukit/libfreebsd/dev/ofw/ofw_if.h | 62 ++++++++++++++++++++++++++++++
 1 file changed, 62 insertions(+)
 create mode 100644 cpukit/libfreebsd/dev/ofw/ofw_if.h
diff --git a/cpukit/libfreebsd/dev/ofw/ofw_if.h b/cpukit/libfreebsd/dev/ofw/ofw_if.h
new file mode 100644
index 0000000000..b27864a032
--- /dev/null
+++ b/cpukit/libfreebsd/dev/ofw/ofw_if.h
@@ -0,0 +1,62 @@
+/* SPDX-License-Identifier: BSD-2-Clause
+ * @file
+ * @ingroup LIBFREEBSD
+ * @brief Declaration of OFW functions.
+ * Copyright (C) <2020> Niteesh Babu <niteesh.gs at gmail.com>
+ * are met:
+#ifndef _LIBFREEBSD_OFW_IF_H
+#define _LIBFREEBSD_OFW_IF_H
+#include "openfirm.h"
+typedef void*	ofw_t;
+int OFW_INIT(ofw_t ofw_obj, void *cookie);
+phandle_t OFW_PEER(ofw_t ofw_obj, phandle_t node);
+phandle_t OFW_CHILD(ofw_t ofw_obj, phandle_t node);
+phandle_t OFW_PARENT(ofw_t ofw_obj, phandle_t node);
+phandle_t OFW_INSTANCE_TO_PACKAGE(ofw_t ofw_obj, ihandle_t instance);
+ssize_t OFW_GETPROPLEN(ofw_t ofw_obj, phandle_t package, const char *propname);
+ssize_t OFW_GETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
+	    void *buf, size_t buflen);
+int OFW_NEXTPROP(ofw_t ofw_obj, phandle_t package, const char *prev, char *buf,
+	    size_t size);
+int OFW_SETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
+	    const void *buf, size_t len);
+ssize_t OFW_CANON(ofw_t ofw_obj, const char *device, char *buf, size_t len);
+phandle_t OFW_FINDDEVICE(ofw_t ofw_obj, const char *device);
+ssize_t OFW_INSTANCE_TO_PATH(ofw_t ofw_obj, ihandle_t instance, char *buf,
+	    size_t len);
+ssize_t OFW_PACKAGE_TO_PATH(ofw_t ofw_obj, phandle_t package, char *buf,
+	    size_t len);
+#endif /* _LIBFREEBSD_OFW_IF_H */
2.17.1
