Small doubt in importance of Scheduler_Context for uniprocessor schedulers
Sat Jun 13 18:04:42 UTC 2020
On Sat, Jun 13, 2020 at 11:41 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> I was going through the deterministic scheduler for uniprocessor and noticed in the code:
>  "cpukit/include/rtems/score/schedulerpriority.h" :
> typedef struct {
>    * @brief Basic scheduler context.
>   Scheduler_Context Base;
>    * @brief Bit map to indicate non-empty ready queues.
>   Priority_bit_map_Control Bit_map;
>    * @brief One ready queue per priority level.
>   Chain_Control Ready[ 0 ];
> } Scheduler_priority_Context;
> Where Scheduler_Context is defined as:
> From "cpukit/include/rtems/score/scheduler.h":
> typedef struct Scheduler_Context {
>    * @brief Lock to protect this scheduler instance.
>   ISR_LOCK_MEMBER( Lock )
> #if defined(RTEMS_SMP)
>    * @brief The set of processors owned by this scheduler instance.
>   Processor_mask Processors;
> #endif
> } Scheduler_Context;
> and ISR_LOCK is defined as:
> "cpukit/include/rtems/score/isrlock.h"
>  * @brief Defines an ISR lock member.
>  * Do not add a ';' after this macro.
>  * @param _designator The designator for the interrupt lock.
> #if defined( RTEMS_SMP )
>   #define ISR_LOCK_MEMBER( _designator ) ISR_lock_Control _designator;
> #else
> #endif
> Since we left the preprocessor directive as empty for the else case, it means that for a non smp system, we don't use the ISR_LOCK as well as the processor mask.
> Then could someone please help me understand why we would include Scheduler_Context Base in the Scheduler_priority_Context since this scheduler is for a uniprocessor system and Scheduler_Context has nothing?
I think it's there for consistency.
> Thanks,
> Richi.
> devel mailing list
> devel at rtems.org
