[PATCH] Added APA terms
Richi Dubey
richidubey at gmail.com
Mon Jun 15 14:39:06 UTC 2020
Hi,
Please ignore the first commit. I sent it directly from rtems-qual which
was a mistake.
Thanks
On Mon, Jun 15, 2020 at 8:08 PM Richi Dubey <richidubey at gmail.com> wrote:
> c-user/glossary.rst | 13 ++++++++++++-
> 1 file changed, 12 insertions(+), 1 deletion(-)
> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> index 86350a8..589d41b 100644
> --- a/c-user/glossary.rst
> +++ b/c-user/glossary.rst
> @@ -1,6 +1,6 @@
> .. SPDX-License-Identifier: CC-BY-SA-4.0
> -.. Copyright (C) 2017, 2019 embedded brains GmbH (
> http://www.embedded-brains.de)
> +.. Copyright (C) 2017, 2020 embedded brains GmbH (
> .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation
> (OAR)
> Glossary
> @@ -16,6 +16,10 @@ Glossary
> A term used to describe an object which has been created by an
> application.
> + APA
> + Arbitrary Processor Affinity.
> + In this model, a thread is allowed to have an arbitrary affinity
> to the processor set, rather than a global mapping from one thread to all
> processors or one thread to one processor. It has two variants, :term:`Weak
> APA` and :term:`Strong APA`
> aperiodic task
> A task which must execute only at irregular intervals and has
> only a soft
> deadline.
> @@ -777,6 +781,9 @@ Glossary
> :term:`return value` to indicate a successful operation or error
> conditions.
> + Strong APA
> + Strong APA is a specialization of :term:`APA`. In this model, on
> the arrival of a :term:`thread`, every thread reachable from the newly
> arrived thread is checked to see if an existing thread can be shifted (or
> deallocated its processor) and the newly arrived thread take its place if
> the newly arrived thread has a higher priority. Similar analysis is done
> when a thread finishes its execution (Here, the terms task and thread have
> interchangeable definitions). :cite:`Cerqueira:2014:LPA`
> suspend
> A term used to describe a task that is not competing for the CPU
> because it
> has had a ``rtems_task_suspend`` directive.
> @@ -905,6 +912,10 @@ Glossary
> Message queues, regions, and semaphores have a wait queue
> associated with
> them.
> + Weak APA
> + Weak APA is a specialization of :term:`APA`. This refers to
> Linux's pull push implementation of APA model. On the arrival of a thread,
> the thread is scheduled when a processor in its affinity set is idle or a
> processor is executing a thread which is at a lower priority.
> + :cite:`Cerqueira:2014:LPA`
> YAML
> This term is an acronym for `YAML Ain't Markup Language <
> https://yaml.org/>`_.
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200615/5855fe17/attachment.html>
