[PATCH] Added APA terms
Mon Jun 15 15:56:33 UTC 2020
On 15/06/2020 16:38, Richi Dubey wrote:
>   c-user/glossary.rst | 13 ++++++++++++-
>   1 file changed, 12 insertions(+), 1 deletion(-)
> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> index 86350a8..589d41b 100644
> --- a/c-user/glossary.rst
> +++ b/c-user/glossary.rst
> @@ -1,6 +1,6 @@
>   .. SPDX-License-Identifier: CC-BY-SA-4.0
> -.. Copyright (C) 2017, 2019 embedded brains GmbH (http://www.embedded-brains.de)
> +.. Copyright (C) 2017, 2020 embedded brains GmbH (http://www.embedded-brains.de)
The stuff should probably have your copyright.
>   .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation (OAR)
>   Glossary
> @@ -16,6 +16,10 @@ Glossary
>           A term used to describe an object which has been created by an
>           application.
> +    APA
> +        Arbitrary Processor Affinity.
> +        In this model, a thread is allowed to have an arbitrary affinity to the processor set, rather than a global mapping from one thread to all processors or one thread to one processor. It has two variants, :term:`Weak APA` and :term:`Strong APA`
Please fix the line width (max. 79 chars). Please have a look at the
phrase for acronyms:
https://docs.rtems.org/branches/master/eng/req/howto.html#glossary-specification
>       aperiodic task
>           A task which must execute only at irregular intervals and has only a soft
>           deadline.
> @@ -777,6 +781,9 @@ Glossary
>           :term:`return value` to indicate a successful operation or error
>           conditions.
> +    Strong APA
> +        Strong APA is a specialization of :term:`APA`. In this model, on the arrival of a :term:`thread`, every thread reachable from the newly arrived thread is checked to see if an existing thread can be shifted (or deallocated its processor)
It is a "model" of what? What means "arrival", "reachable from", and
"shifted"?
>   and the newly arrived thread take its place if the newly arrived thread has a higher priority. Similar analysis is done when a thread finishes its execution (Here, the terms task and thread have interchangeable definitions).
Task/thread statement is superfluous.
> :cite:`Cerqueira:2014:LPA`
Please make sure that your text is built from complete sentences.
>       suspend
>           A term used to describe a task that is not competing for the CPU because it
>           has had a ``rtems_task_suspend`` directive.
> @@ -905,6 +912,10 @@ Glossary
>           Message queues, regions, and semaphores have a wait queue associated with
>           them.
> +    Weak APA
> +        Weak APA is a specialization of :term:`APA`. This refers to Linux's pull push implementation of APA model. On the arrival of a thread, the thread is scheduled when a processor in its affinity set is idle or a processor is executing a thread which is at a lower priority.
> +        :cite:`Cerqueira:2014:LPA`
>       YAML
>           This term is an acronym for `YAML Ain't Markup Language <https://yaml.org/>`_.
