Use of RTEMS_GLOBAL in non-multiprocessing configurations?
Sebastian Huber
Mon Jun 15 16:28:32 UTC 2020
On 15/06/2020 18:24, Sebastian Huber wrote:
> On 15/06/2020 18:13, Joel Sherrill wrote:
>> On Mon, Jun 15, 2020 at 10:52 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> Hello,
>> should the use of RTEMS_GLOBAL be an error in
>> rtems_semaphore_create(),
>> rtems_task_create(), rtems_message_queue_create(), and
>> rtems_partition_create() if RTEMS was configured without
>> multiprocessing
>> enabled?
>> Based on the original use cases, I would say no. The idea was that
>> you could create
>> objects and attach to them to limit cohesion. The intention was to
>> avoid the use of
>> global variables for sharing object Ids. If I offer a service via a
>> message queue
>> globally and my library/service is deployed in a non-MP
>> configuration, it should still
>> work. For tasks, that would imply events. For partitions, it just
>> means the memory is
>> available to "the system" which is a single processor.
> Ok, but I think this is a bit inconsistent to the
> #if defined(RTEMS_MULTIPROCESSING)
> if (
> _Attributes_Is_global( attribute_set )
> && !_System_state_Is_multiprocessing
> return RTEMS_MP_NOT_CONFIGURED;
> #endif
> error case. If your system has only one node and is configured for
> multiprocessing shouldn't this behave exactly as an uniprocessor
> system with multiprocessing disabled?
The background for this question is that I go though the entire Classic
API and write specification items for it. The specification items
include the API documentation:
https://devel.rtems.org/ticket/3993
I will probably add some text similar to the one in your e-mail to
explain that the use of RTEMS_GLOBAL is all right in non-multiprocessing
configurations.
