Use of RTEMS_GLOBAL in non-multiprocessing configurations?
Sebastian Huber
Mon Jun 15 16:24:56 UTC 2020
On 15/06/2020 18:13, Joel Sherrill wrote:
> On Mon, Jun 15, 2020 at 10:52 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello,
> should the use of RTEMS_GLOBAL be an error in
> rtems_semaphore_create(),
> rtems_task_create(), rtems_message_queue_create(), and
> rtems_partition_create() if RTEMS was configured without
> multiprocessing
> enabled?
> Based on the original use cases, I would say no. The idea was that you
> could create
> objects and attach to them to limit cohesion. The intention was to
> avoid the use of
> global variables for sharing object Ids. If I offer a service via a
> message queue
> globally and my library/service is deployed in a non-MP configuration,
> it should still
> work. For tasks, that would imply events. For partitions, it just
> means the memory is
> available to "the system" which is a single processor.
Ok, but I think this is a bit inconsistent to the
#if defined(RTEMS_MULTIPROCESSING)
if (
_Attributes_Is_global( attribute_set )
&& !_System_state_Is_multiprocessing
return RTEMS_MP_NOT_CONFIGURED;
#endif
error case. If your system has only one node and is configured for
multiprocessing shouldn't this behave exactly as an uniprocessor system
with multiprocessing disabled?
