[PATCH] rtems: Remove RTEMS_MP_NOT_CONFIGURED error
Tue Jun 16 05:52:19 UTC 2020
Some objects can be created with a local or global scope in a
multiprocessing network. In non-multiprocessing configurations setting
the scope to local or global had no effect since such a system can be
viewed as a multiprocessing network with just one node. One and all
nodes is the same in such a network. However, if multiprocessing was
configured, creation of a global object in a single node network
resulted in an RTEMS_MP_NOT_CONFIGURED error. Remove this error
condition for symmetry to the non-multiprocessing setup. This is in line
with the task affinity behaviour in SMP systems.
Update #4005.
 cpukit/rtems/src/msgqcreate.c                 |  8 ++++---
 cpukit/rtems/src/partcreate.c                 |  6 ++---
 cpukit/rtems/src/semcreate.c                  |  7 ++----
 cpukit/rtems/src/taskcreate.c                 | 12 ++++------
 testsuites/sptests/sp04/init.c                |  2 +-
 testsuites/sptests/sp12/init.c                |  2 +-
 testsuites/sptests/sp13/init.c                |  2 +-
 testsuites/sptests/sp15/init.c                |  2 +-
 testsuites/sptests/spmsgq_err01/init.c        | 21 ------------------
 .../sptests/spmsgq_err01/spmsgq_err01.scn     |  1 -
 testsuites/sptests/sppartition_err01/init.c   | 22 -------------------
 .../sppartition_err01/sppartition_err01.scn   |  1 -
 testsuites/sptests/spsem_err01/init.c         | 21 ------------------
 .../sptests/spsem_err01/spsem_err01.scn       |  1 -
 testsuites/sptests/sptask_err03/init.c        | 22 -------------------
 .../sptests/sptask_err03/sptask_err03.scn     |  1 -
 16 files changed, 18 insertions(+), 113 deletions(-)
diff --git a/cpukit/rtems/src/msgqcreate.c b/cpukit/rtems/src/msgqcreate.c
index 9d4e8cdfd6..3741347cc9 100644
--- a/cpukit/rtems/src/msgqcreate.c
+++ b/cpukit/rtems/src/msgqcreate.c
@@ -52,9 +52,11 @@ rtems_status_code rtems_message_queue_create(
     return RTEMS_INVALID_ADDRESS;
 #if defined(RTEMS_MULTIPROCESSING)
-  if ( (is_global = _Attributes_Is_global( attribute_set ) ) &&
-       !_System_state_Is_multiprocessing )
-    return RTEMS_MP_NOT_CONFIGURED;
+  if ( !_System_state_Is_multiprocessing ) {
+    attribute_set = _Attributes_Clear( attribute_set, RTEMS_GLOBAL );
+  is_global = _Attributes_Is_global( attribute_set );
 #endif
   if ( count == 0 )
diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
index 2aefce8067..9aa5e80bf1 100644
--- a/cpukit/rtems/src/partcreate.c
+++ b/cpukit/rtems/src/partcreate.c
@@ -66,9 +66,9 @@ rtems_status_code rtems_partition_create(
-  if ( _Attributes_Is_global( attribute_set ) &&
 #endif
   the_partition = _Partition_Allocate();
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index 6cdd877cce..b57b635d85 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -57,11 +57,8 @@ rtems_status_code rtems_semaphore_create(
-  if (
-    _Attributes_Is_global( attribute_set )
-      && !_System_state_Is_multiprocessing
 #endif
diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
index 288eafa5c7..b430d3c705 100644
--- a/cpukit/rtems/src/taskcreate.c
+++ b/cpukit/rtems/src/taskcreate.c
@@ -111,15 +111,11 @@ rtems_status_code rtems_task_create(
-  if ( _Attributes_Is_global( the_attribute_set ) ) {
-    is_global = true;
-    if ( !_System_state_Is_multiprocessing )
+    the_attribute_set = _Attributes_Clear( the_attribute_set, RTEMS_GLOBAL );
-  } else
-    is_global = false;
+  is_global = _Attributes_Is_global( the_attribute_set );
 #endif
diff --git a/testsuites/sptests/sp04/init.c b/testsuites/sptests/sp04/init.c
index 11aae46ea3..b163aec8ed 100644
--- a/testsuites/sptests/sp04/init.c
+++ b/testsuites/sptests/sp04/init.c
@@ -84,7 +84,7 @@ rtems_task Init(
      1,
      RTEMS_MINIMUM_STACK_SIZE * 2,
      RTEMS_PREEMPT|RTEMS_TIMESLICE,
-     RTEMS_DEFAULT_ATTRIBUTES,
+     RTEMS_GLOBAL,
      &Task_id[ 2 ]
   directive_failed( status, "rtems_task_create of TA2" );
diff --git a/testsuites/sptests/sp12/init.c b/testsuites/sptests/sp12/init.c
index 789f7e3249..7aa09d3676 100644
--- a/testsuites/sptests/sp12/init.c
+++ b/testsuites/sptests/sp12/init.c
@@ -73,7 +73,7 @@ rtems_task Init(
   status = rtems_semaphore_create(
     Semaphore_name[ 3 ],
     1,
+    RTEMS_GLOBAL,
     RTEMS_NO_PRIORITY,
     &Semaphore_id[ 3 ]
diff --git a/testsuites/sptests/sp13/init.c b/testsuites/sptests/sp13/init.c
index 7ed8dabc53..a23d369001 100644
--- a/testsuites/sptests/sp13/init.c
+++ b/testsuites/sptests/sp13/init.c
@@ -105,7 +105,7 @@ rtems_task Init(
     Queue_name[ 3 ],
     100,
     MESSAGE_SIZE,
+    RTEMS_GLOBAL,
     &Queue_id[ 3 ]
   directive_failed( status, "rtems_message_queue_create of Q3" );
diff --git a/testsuites/sptests/sp15/init.c b/testsuites/sptests/sp15/init.c
index 25be0425e2..2565495a06 100644
--- a/testsuites/sptests/sp15/init.c
+++ b/testsuites/sptests/sp15/init.c
@@ -71,7 +71,7 @@ rtems_task Init(
     Area_2,
     274,
     128,
+    RTEMS_GLOBAL,
     &Partition_id[ 2 ]
   directive_failed( status, "rtems_partition_create of PT2" );
diff --git a/testsuites/sptests/spmsgq_err01/init.c b/testsuites/sptests/spmsgq_err01/init.c
index 24537725dc..1ff8490d1a 100644
--- a/testsuites/sptests/spmsgq_err01/init.c
+++ b/testsuites/sptests/spmsgq_err01/init.c
@@ -98,27 +98,6 @@ rtems_task Init(
   puts( "TA1 - rtems_message_queue_create - Q 1 - RTEMS_INVALID_NAME" );
-   *  The check for an object being global is only made if
-   *  multiprocessing is enabled.
-#if defined(RTEMS_MULTIPROCESSING)
-  status = rtems_message_queue_create(
-    Queue_name[ 1 ],
-    1,
-    MESSAGE_SIZE,
-    RTEMS_GLOBAL,
-    &Junk_id
-  fatal_directive_status(
-    status,
-    RTEMS_MP_NOT_CONFIGURED,
-    "rtems_message_queue_create of mp not configured"
-#endif
-  puts( "TA1 - rtems_message_queue_create - Q 1 - RTEMS_MP_NOT_CONFIGURED" );
   /* not enough memory for messages */
     Queue_name[ 1 ],
diff --git a/testsuites/sptests/spmsgq_err01/spmsgq_err01.scn b/testsuites/sptests/spmsgq_err01/spmsgq_err01.scn
index 7bd31fc744..26add5eb82 100644
--- a/testsuites/sptests/spmsgq_err01/spmsgq_err01.scn
+++ b/testsuites/sptests/spmsgq_err01/spmsgq_err01.scn
@@ -4,7 +4,6 @@ TA1 - rtems_message_queue_create - NULL Id - RTEMS_INVALID_ADDRESS
 TA1 - rtems_message_queue_create - count = 0 - RTEMS_INVALID_NUMBER
 TA1 - rtems_message_queue_create - size = 0 - RTEMS_INVALID_SIZE
-TA1 - rtems_message_queue_create - Q 1 - RTEMS_MP_NOT_CONFIGURED
 TA1 - rtems_message_queue_create - Q 2 - RTEMS_UNSATISFIED
 TA1 - rtems_message_queue_create - Q 2 - RTEMS_UNSATISFIED #2
 TA1 - rtems_message_queue_create - Q 1 - 2 DEEP - RTEMS_SUCCESSFUL
diff --git a/testsuites/sptests/sppartition_err01/init.c b/testsuites/sptests/sppartition_err01/init.c
index 39ee700daa..39373852fb 100644
--- a/testsuites/sptests/sppartition_err01/init.c
+++ b/testsuites/sptests/sppartition_err01/init.c
@@ -126,28 +126,6 @@ void test_partition_errors(void)
-  status = rtems_partition_create(
-    Partition_name[ 1 ],
-    Partition_good_area,
-    128,
-    64,
-    RTEMS_GLOBAL,
-    &junk_id
-    status,
-    "rtems_partition_create of global"
-#endif
-  puts( "TA1 - rtems_partition_create - RTEMS_MP_NOT_CONFIGURED" );
 #if defined(_C3x) || defined(_C4x)
   puts( "TA1 - rtems_partition_create - RTEMS_INVALID_ADDRESS - SKIPPED" );
 #else
diff --git a/testsuites/sptests/sppartition_err01/sppartition_err01.scn b/testsuites/sptests/sppartition_err01/sppartition_err01.scn
index 2b010ee6d4..01319353e7 100644
--- a/testsuites/sptests/sppartition_err01/sppartition_err01.scn
+++ b/testsuites/sptests/sppartition_err01/sppartition_err01.scn
@@ -4,7 +4,6 @@ TA1 - rtems_partition_create - length - RTEMS_INVALID_SIZE
 TA1 - rtems_partition_create - buffer size - RTEMS_INVALID_SIZE
 TA1 - rtems_partition_create - length < buffer size - RTEMS_INVALID_SIZE
 TA1 - rtems_partition_create - buffer size < overhead - RTEMS_INVALID_SIZE
-TA1 - rtems_partition_create - RTEMS_MP_NOT_CONFIGURED
 TA1 - rtems_partition_create - RTEMS_INVALID_SIZE
 TA1 - rtems_partition_delete - unknown RTEMS_INVALID_ID
diff --git a/testsuites/sptests/spsem_err01/init.c b/testsuites/sptests/spsem_err01/init.c
index 39a366b41a..f1f1592ebf 100644
--- a/testsuites/sptests/spsem_err01/init.c
+++ b/testsuites/sptests/spsem_err01/init.c
@@ -199,27 +199,6 @@ rtems_task Init(
   puts( "TA1 - rtems_semaphore_create - RTEMS_INVALID_NUMBER" );
-  status = rtems_semaphore_create(
-    Semaphore_name[ 3 ],
-    1,
-    RTEMS_GLOBAL,
-    RTEMS_NO_PRIORITY,
-    &Junk_id
-    status,
-    "rtems_semaphore_create of mp not configured"
-#endif
-  puts( "TA1 - rtems_semaphore_create - RTEMS_MP_NOT_CONFIGURED" );
   status = rtems_semaphore_delete( 100 );
     status,
diff --git a/testsuites/sptests/spsem_err01/spsem_err01.scn b/testsuites/sptests/spsem_err01/spsem_err01.scn
index b6172196b0..5adf40f865 100644
--- a/testsuites/sptests/spsem_err01/spsem_err01.scn
+++ b/testsuites/sptests/spsem_err01/spsem_err01.scn
@@ -12,7 +12,6 @@ TA1 - rtems_semaphore_create - FIFO and ceiling - RTEMS_NOT_DEFINED
 TA1 - rtems_semaphore_create - ceiling and inherit - RTEMS_NOT_DEFINED
 TA1 - rtems_semaphore_create - RTEMS_NOT_DEFINED
-TA1 - rtems_semaphore_create - RTEMS_MP_NOT_CONFIGURED
 TA1 - rtems_semaphore_delete - RTEMS_INVALID_ID
 TA1 - rtems_semaphore_delete - local RTEMS_INVALID_ID
 TA1 - rtems_semaphore_ident - global RTEMS_INVALID_NAME
diff --git a/testsuites/sptests/sptask_err03/init.c b/testsuites/sptests/sptask_err03/init.c
index 2ac54b9037..bda2cd4a1f 100644
--- a/testsuites/sptests/sptask_err03/init.c
+++ b/testsuites/sptests/sptask_err03/init.c
@@ -228,27 +228,5 @@ rtems_task Init(
   puts( "TA1 - rtems_task_create - 11 - RTEMS_TOO_MANY" );
-  status = rtems_task_create(
-    task_name,
-    4,
-    RTEMS_MINIMUM_STACK_SIZE,
-    RTEMS_DEFAULT_MODES,
-    RTEMS_GLOBAL,
-    &Junk_id
-    status,
-    "rtems_task_create of global task in a single cpu system"
-#endif
-  puts( "TA1 - rtems_task_create - RTEMS_MP_NOT_CONFIGURED" );
   TEST_END();
diff --git a/testsuites/sptests/sptask_err03/sptask_err03.scn b/testsuites/sptests/sptask_err03/sptask_err03.scn
index 2787bafba5..e6047e4476 100644
--- a/testsuites/sptests/sptask_err03/sptask_err03.scn
+++ b/testsuites/sptests/sptask_err03/sptask_err03.scn
@@ -14,5 +14,4 @@ TA1 - rtems_task_create - 8 created - RTEMS_SUCCESSFUL
 TA1 - rtems_task_create - 9 created - RTEMS_SUCCESSFUL
 TA1 - rtems_task_create - 10 created - RTEMS_SUCCESSFUL
-TA1 - rtems_task_create - RTEMS_MP_NOT_CONFIGURED
 *** END TEST TASK ERROR 03 ***
2.26.2
