[PATCH] rtems: Remove RTEMS_MP_NOT_CONFIGURED error
Chris Johns
chrisj at rtems.org
Thu Jun 18 01:43:20 UTC 2020
OK to push this change and the doco patch.
Thanks
On 16/6/20 3:52 pm, Sebastian Huber wrote:
> Some objects can be created with a local or global scope in a
> multiprocessing network. In non-multiprocessing configurations setting
> the scope to local or global had no effect since such a system can be
> viewed as a multiprocessing network with just one node. One and all
> nodes is the same in such a network. However, if multiprocessing was
> configured, creation of a global object in a single node network
> resulted in an RTEMS_MP_NOT_CONFIGURED error. Remove this error
> condition for symmetry to the non-multiprocessing setup. This is in line
> with the task affinity behaviour in SMP systems.
> Update #4005.
> cpukit/rtems/src/msgqcreate.c | 8 ++++---
> cpukit/rtems/src/partcreate.c | 6 ++---
> cpukit/rtems/src/semcreate.c | 7 ++----
> cpukit/rtems/src/taskcreate.c | 12 ++++------
> testsuites/sptests/sp04/init.c | 2 +-
> testsuites/sptests/sp12/init.c | 2 +-
> testsuites/sptests/sp13/init.c | 2 +-
> testsuites/sptests/sp15/init.c | 2 +-
> testsuites/sptests/spmsgq_err01/init.c | 21 ------------------
> .../sptests/spmsgq_err01/spmsgq_err01.scn | 1 -
> testsuites/sptests/sppartition_err01/init.c | 22 -------------------
> .../sppartition_err01/sppartition_err01.scn | 1 -
> testsuites/sptests/spsem_err01/init.c | 21 ------------------
> .../sptests/spsem_err01/spsem_err01.scn | 1 -
> testsuites/sptests/sptask_err03/init.c | 22 -------------------
> .../sptests/sptask_err03/sptask_err03.scn | 1 -
> 16 files changed, 18 insertions(+), 113 deletions(-)
> diff --git a/cpukit/rtems/src/msgqcreate.c b/cpukit/rtems/src/msgqcreate.c
> index 9d4e8cdfd6..3741347cc9 100644
> --- a/cpukit/rtems/src/msgqcreate.c
> +++ b/cpukit/rtems/src/msgqcreate.c
> @@ -52,9 +52,11 @@ rtems_status_code rtems_message_queue_create(
> return RTEMS_INVALID_ADDRESS;
> #if defined(RTEMS_MULTIPROCESSING)
> - if ( (is_global = _Attributes_Is_global( attribute_set ) ) &&
> - !_System_state_Is_multiprocessing )
> - return RTEMS_MP_NOT_CONFIGURED;
> + if ( !_System_state_Is_multiprocessing ) {
> + attribute_set = _Attributes_Clear( attribute_set, RTEMS_GLOBAL );
> + is_global = _Attributes_Is_global( attribute_set );
> #endif
> if ( count == 0 )
> diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
> index 2aefce8067..9aa5e80bf1 100644
> --- a/cpukit/rtems/src/partcreate.c
> +++ b/cpukit/rtems/src/partcreate.c
> @@ -66,9 +66,9 @@ rtems_status_code rtems_partition_create(
> - if ( _Attributes_Is_global( attribute_set ) &&
> #endif
> the_partition = _Partition_Allocate();
> diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
> index 6cdd877cce..b57b635d85 100644
> --- a/cpukit/rtems/src/semcreate.c
> +++ b/cpukit/rtems/src/semcreate.c
> @@ -57,11 +57,8 @@ rtems_status_code rtems_semaphore_create(
> - if (
> - _Attributes_Is_global( attribute_set )
> - && !_System_state_Is_multiprocessing
> #endif
> diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
> index 288eafa5c7..b430d3c705 100644
> --- a/cpukit/rtems/src/taskcreate.c
> +++ b/cpukit/rtems/src/taskcreate.c
> @@ -111,15 +111,11 @@ rtems_status_code rtems_task_create(
> - if ( _Attributes_Is_global( the_attribute_set ) ) {
> - is_global = true;
> - if ( !_System_state_Is_multiprocessing )
> + the_attribute_set = _Attributes_Clear( the_attribute_set, RTEMS_GLOBAL );
> - } else
> - is_global = false;
> + is_global = _Attributes_Is_global( the_attribute_set );
> #endif
> diff --git a/testsuites/sptests/sp04/init.c b/testsuites/sptests/sp04/init.c
> index 11aae46ea3..b163aec8ed 100644
> --- a/testsuites/sptests/sp04/init.c
> +++ b/testsuites/sptests/sp04/init.c
> @@ -84,7 +84,7 @@ rtems_task Init(
> 1,
> RTEMS_MINIMUM_STACK_SIZE * 2,
> RTEMS_PREEMPT|RTEMS_TIMESLICE,
> - RTEMS_DEFAULT_ATTRIBUTES,
> + RTEMS_GLOBAL,
> &Task_id[ 2 ]
> directive_failed( status, "rtems_task_create of TA2" );
> diff --git a/testsuites/sptests/sp12/init.c b/testsuites/sptests/sp12/init.c
> index 789f7e3249..7aa09d3676 100644
> --- a/testsuites/sptests/sp12/init.c
> +++ b/testsuites/sptests/sp12/init.c
> @@ -73,7 +73,7 @@ rtems_task Init(
> status = rtems_semaphore_create(
> Semaphore_name[ 3 ],
> 1,
> + RTEMS_GLOBAL,
> RTEMS_NO_PRIORITY,
> &Semaphore_id[ 3 ]
> diff --git a/testsuites/sptests/sp13/init.c b/testsuites/sptests/sp13/init.c
> index 7ed8dabc53..a23d369001 100644
> --- a/testsuites/sptests/sp13/init.c
> +++ b/testsuites/sptests/sp13/init.c
> @@ -105,7 +105,7 @@ rtems_task Init(
> Queue_name[ 3 ],
> 100,
> MESSAGE_SIZE,
> + RTEMS_GLOBAL,
> &Queue_id[ 3 ]
> directive_failed( status, "rtems_message_queue_create of Q3" );
> diff --git a/testsuites/sptests/sp15/init.c b/testsuites/sptests/sp15/init.c
> index 25be0425e2..2565495a06 100644
> --- a/testsuites/sptests/sp15/init.c
> +++ b/testsuites/sptests/sp15/init.c
> @@ -71,7 +71,7 @@ rtems_task Init(
> Area_2,
> 274,
> 128,
> + RTEMS_GLOBAL,
> &Partition_id[ 2 ]
> directive_failed( status, "rtems_partition_create of PT2" );
> diff --git a/testsuites/sptests/spmsgq_err01/init.c b/testsuites/sptests/spmsgq_err01/init.c
> index 24537725dc..1ff8490d1a 100644
> --- a/testsuites/sptests/spmsgq_err01/init.c
> +++ b/testsuites/sptests/spmsgq_err01/init.c
> @@ -98,27 +98,6 @@ rtems_task Init(
> puts( "TA1 - rtems_message_queue_create - Q 1 - RTEMS_INVALID_NAME" );
> - * The check for an object being global is only made if
> - * multiprocessing is enabled.
> -#if defined(RTEMS_MULTIPROCESSING)
> - status = rtems_message_queue_create(
> - Queue_name[ 1 ],
> - 1,
> - MESSAGE_SIZE,
> - RTEMS_GLOBAL,
> - &Junk_id
> - fatal_directive_status(
> - status,
> - RTEMS_MP_NOT_CONFIGURED,
> - "rtems_message_queue_create of mp not configured"
> -#endif
> - puts( "TA1 - rtems_message_queue_create - Q 1 - RTEMS_MP_NOT_CONFIGURED" );
> /* not enough memory for messages */
> Queue_name[ 1 ],
> diff --git a/testsuites/sptests/spmsgq_err01/spmsgq_err01.scn b/testsuites/sptests/spmsgq_err01/spmsgq_err01.scn
> index 7bd31fc744..26add5eb82 100644
> --- a/testsuites/sptests/spmsgq_err01/spmsgq_err01.scn
> +++ b/testsuites/sptests/spmsgq_err01/spmsgq_err01.scn
> @@ -4,7 +4,6 @@ TA1 - rtems_message_queue_create - NULL Id - RTEMS_INVALID_ADDRESS
> TA1 - rtems_message_queue_create - count = 0 - RTEMS_INVALID_NUMBER
> TA1 - rtems_message_queue_create - size = 0 - RTEMS_INVALID_SIZE
> -TA1 - rtems_message_queue_create - Q 1 - RTEMS_MP_NOT_CONFIGURED
> TA1 - rtems_message_queue_create - Q 2 - RTEMS_UNSATISFIED
> TA1 - rtems_message_queue_create - Q 2 - RTEMS_UNSATISFIED #2
> TA1 - rtems_message_queue_create - Q 1 - 2 DEEP - RTEMS_SUCCESSFUL
> diff --git a/testsuites/sptests/sppartition_err01/init.c b/testsuites/sptests/sppartition_err01/init.c
> index 39ee700daa..39373852fb 100644
> --- a/testsuites/sptests/sppartition_err01/init.c
> +++ b/testsuites/sptests/sppartition_err01/init.c
> @@ -126,28 +126,6 @@ void test_partition_errors(void)
> - status = rtems_partition_create(
> - Partition_name[ 1 ],
> - Partition_good_area,
> - 128,
> - 64,
> - RTEMS_GLOBAL,
> - &junk_id
> - status,
> - "rtems_partition_create of global"
> -#endif
> - puts( "TA1 - rtems_partition_create - RTEMS_MP_NOT_CONFIGURED" );
> #if defined(_C3x) || defined(_C4x)
> puts( "TA1 - rtems_partition_create - RTEMS_INVALID_ADDRESS - SKIPPED" );
> #else
> diff --git a/testsuites/sptests/sppartition_err01/sppartition_err01.scn b/testsuites/sptests/sppartition_err01/sppartition_err01.scn
> index 2b010ee6d4..01319353e7 100644
> --- a/testsuites/sptests/sppartition_err01/sppartition_err01.scn
> +++ b/testsuites/sptests/sppartition_err01/sppartition_err01.scn
> @@ -4,7 +4,6 @@ TA1 - rtems_partition_create - length - RTEMS_INVALID_SIZE
> TA1 - rtems_partition_create - buffer size - RTEMS_INVALID_SIZE
> TA1 - rtems_partition_create - length < buffer size - RTEMS_INVALID_SIZE
> TA1 - rtems_partition_create - buffer size < overhead - RTEMS_INVALID_SIZE
> -TA1 - rtems_partition_create - RTEMS_MP_NOT_CONFIGURED
> TA1 - rtems_partition_create - RTEMS_INVALID_SIZE
> TA1 - rtems_partition_delete - unknown RTEMS_INVALID_ID
> diff --git a/testsuites/sptests/spsem_err01/init.c b/testsuites/sptests/spsem_err01/init.c
> index 39a366b41a..f1f1592ebf 100644
> --- a/testsuites/sptests/spsem_err01/init.c
> +++ b/testsuites/sptests/spsem_err01/init.c
> @@ -199,27 +199,6 @@ rtems_task Init(
> puts( "TA1 - rtems_semaphore_create - RTEMS_INVALID_NUMBER" );
> - status = rtems_semaphore_create(
> - Semaphore_name[ 3 ],
> - 1,
> - RTEMS_GLOBAL,
> - RTEMS_NO_PRIORITY,
> - &Junk_id
> - status,
> - "rtems_semaphore_create of mp not configured"
> -#endif
> - puts( "TA1 - rtems_semaphore_create - RTEMS_MP_NOT_CONFIGURED" );
> status = rtems_semaphore_delete( 100 );
> status,
> diff --git a/testsuites/sptests/spsem_err01/spsem_err01.scn b/testsuites/sptests/spsem_err01/spsem_err01.scn
> index b6172196b0..5adf40f865 100644
> --- a/testsuites/sptests/spsem_err01/spsem_err01.scn
> +++ b/testsuites/sptests/spsem_err01/spsem_err01.scn
> @@ -12,7 +12,6 @@ TA1 - rtems_semaphore_create - FIFO and ceiling - RTEMS_NOT_DEFINED
> TA1 - rtems_semaphore_create - ceiling and inherit - RTEMS_NOT_DEFINED
> TA1 - rtems_semaphore_create - RTEMS_NOT_DEFINED
> -TA1 - rtems_semaphore_create - RTEMS_MP_NOT_CONFIGURED
> TA1 - rtems_semaphore_delete - RTEMS_INVALID_ID
> TA1 - rtems_semaphore_delete - local RTEMS_INVALID_ID
> TA1 - rtems_semaphore_ident - global RTEMS_INVALID_NAME
> diff --git a/testsuites/sptests/sptask_err03/init.c b/testsuites/sptests/sptask_err03/init.c
> index 2ac54b9037..bda2cd4a1f 100644
> --- a/testsuites/sptests/sptask_err03/init.c
> +++ b/testsuites/sptests/sptask_err03/init.c
> @@ -228,27 +228,5 @@ rtems_task Init(
> puts( "TA1 - rtems_task_create - 11 - RTEMS_TOO_MANY" );
> - status = rtems_task_create(
> - task_name,
> - 4,
> - RTEMS_MINIMUM_STACK_SIZE,
> - RTEMS_DEFAULT_MODES,
> - RTEMS_GLOBAL,
> - &Junk_id
> - status,
> - "rtems_task_create of global task in a single cpu system"
> -#endif
> - puts( "TA1 - rtems_task_create - RTEMS_MP_NOT_CONFIGURED" );
> TEST_END();
> diff --git a/testsuites/sptests/sptask_err03/sptask_err03.scn b/testsuites/sptests/sptask_err03/sptask_err03.scn
> index 2787bafba5..e6047e4476 100644
> --- a/testsuites/sptests/sptask_err03/sptask_err03.scn
> +++ b/testsuites/sptests/sptask_err03/sptask_err03.scn
> @@ -14,5 +14,4 @@ TA1 - rtems_task_create - 8 created - RTEMS_SUCCESSFUL
> TA1 - rtems_task_create - 9 created - RTEMS_SUCCESSFUL
> TA1 - rtems_task_create - 10 created - RTEMS_SUCCESSFUL
> -TA1 - rtems_task_create - RTEMS_MP_NOT_CONFIGURED
> *** END TEST TASK ERROR 03 ***
