GSoC 2020: Weekly Progress Update
Mritunjay Sharma mritunjaysharma394 at gmail.com
Wed Jun 17 05:11:09 UTC 2020
Hello everyone,
Following up as decided to update the weekly progress report on irc
channel on every Wednesday, I am updating the progress on the mailing list
as well.
==Previous Work==
Trying to fix missing files like "install/sh" error
to make the ptpd build run.
==Progress==
Earlier errors have been resolved but a new one popped up in the morning.
Modified source-builder/config/ptpd-2-1.cfg file again,
after Googling a little and following Heinz advice,
%source setup ptpd -q -n ptpd-%{ptpd_version}
%patch setup ptpd -p1
+autoreconf -vfi
+automake --add-missing
cd ${build_top}
%build
After this I made the local ptpd-master again a tar ball and used it,
which fixed the earlier, but now another error has popped up which I
am trying to fix.
The error is as follows:
"/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1/do-build:
155:
../ptpd-master/configure: not found
shell cmd failed: /bin/sh -ex
error: building ptpd-master-arm-rtems5-1
  See error report: rsb-report-ptpd-master-arm-rtems5-1.txt
Build Set: Time 0:00:00.191542"
==Blockers==
These configure errors are the main blockers.
==Future options==
Looking forward to raise this with the ptpd community
and trying with the help of mentors to fix the problems
as soon as possible.
Thanks,
Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200617/f59ca1f8/attachment.html>
