[PATCH v1 0/9] Enable SMP for pc386 based bsps
Wed Jun 17 05:40:08 UTC 2020
On 17/6/20 8:34 am, Chris Johns wrote:
> On 16/6/20 10:55 pm, Joel Sherrill wrote:
>> On Tue, Jun 16, 2020 at 7:08 AM <Jan.Sommer at dlr.de <mailto:Jan.Sommer at dlr.de>>
>> wrote:
>> We had this problem trying to set up the embedded PC we use for testing in the
>> new lab.
>> When we tried the same hardware with FreeDOS, it worked. When we tried an old Dell
>> desktop as the RTEMS PC, the serial port didn't work.
> I have a legacy small form factor ITX computer with a standard COM1 RS232 only port.
I have debugged the problem on my hardware and the issue seems to be no serial
port initialisation during start up. There was no call being made to the legacy
ns16550 intialise call ns16550_init.
I am wondering if the improvements to remove code that is not used and the
removal of the console in tests means nothing is left to make the call and we
have depended on it being there. I have a patch I am testing which I will post
soon to add the initialisation to the BSP printk input and output functions.
I am now wondering how many other BSPs could be suffering from the same problem?
Any BSP where the bootloader or some initialisation process handles the printk
set up will not see a problem. For example the xilinx zynq BSP will not see a
problem because the systemZ ps7init set up intialises the UART.
