[PATCH 01/10] mDNSResponder: Back to mDNSResponder-878.30.4
Sebastian Huber
Fri Jun 19 11:02:15 UTC 2020
Update #4010.
mDNSResponder/mDNSCore/anonymous.c | 15 +-
mDNSResponder/mDNSCore/mDNS.c | 4 -
mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h | 40 -----
.../mDNSMacOSX/BonjourTop/source/BonjourTop.1 | 156 ++++++++--------
mDNSResponder/mDNSPosix/mDNSPosix.c | 60 +------
mDNSResponder/mDNSPosix/mDNSPosix.h | 6 -
mDNSResponder/mDNSPosix/mDNSUNP.c | 2 +-
mDNSResponder/mDNSResponder.sln | 21 +++
mDNSResponder/mDNSShared/dnssd_clientshim.c | 12 +-
mDNSResponder/mDNSShared/mDNSDebug.c | 4 -
.../mDNSWindows/BonjourQuickLooks.sln | 162 ++++++++---------
.../BonjourQuickLooksInstaller.wixproj | 170 +++++++++---------
12 files changed, 273 insertions(+), 379 deletions(-)
diff --git a/mDNSResponder/mDNSCore/anonymous.c b/mDNSResponder/mDNSCore/anonymous.c
index fde3ed80..5c138d23 100644
--- a/mDNSResponder/mDNSCore/anonymous.c
+++ b/mDNSResponder/mDNSCore/anonymous.c
@@ -274,17 +274,12 @@ mDNSexport void SetAnonData(DNSQuestion *q, ResourceRecord *rr, mDNSBool ForQues
-mDNSlocal char *RRDisplayStringBuf(const ResourceRecord *const rr, char *const buffer)
- return GetRRDisplayString_rdb(rr, &rr->rdata->u, buffer);
// returns -1 if the caller should ignore the result
// returns 1 if the record answers the question
// returns 0 if the record does not answer the question
mDNSexport int AnonInfoAnswersQuestion(const ResourceRecord *const rr, const DNSQuestion *const q)
- char MsgBuffer[MaxMsg]; // Temp storage used while building error log messages
+ mDNSexport mDNS mDNSStorage;
ResourceRecord *nsec3RR;
int i;
AnonymousInfo *qai, *rai;
@@ -368,7 +363,7 @@ mDNSexport int AnonInfoAnswersQuestion(const ResourceRecord *const rr, const DNS
mDNSPlatformMemCmp(qai->AnonData, rai->AnonData, qai->AnonDataLen) != 0)
debugf("AnonInfoAnswersQuestion: AnonData mis-match for record %s question %##s ",
- RRDisplayStringBuf(rr, MsgBuffer), q->qname.c);
+ RRDisplayString(&mDNSStorage, rr), q->qname.c);
return 0;
// AnonData matches i.e they belong to the same group and the same service.
@@ -406,10 +401,10 @@ mDNSexport int AnonInfoAnswersQuestion(const ResourceRecord *const rr, const DNS
// AnonData can be NULL for the cache entry and if we are hearing our own question back, AnonData is NULL for
// that too and we can end up here for that case.
debugf("AnonInfoAnswersQuestion: AnonData %p or nsec3RR %p, NULL for question %##s, record %s", AnonData, nsec3RR,
- q->qname.c, RRDisplayStringBuf(rr, MsgBuffer));
+ q->qname.c, RRDisplayString(&mDNSStorage, rr));
return 0;
- debugf("AnonInfoAnswersQuestion: Validating question %##s, ResourceRecord %s", q->qname.c, RRDisplayStringBuf(nsec3RR, MsgBuffer));
+ debugf("AnonInfoAnswersQuestion: Validating question %##s, ResourceRecord %s", q->qname.c, RRDisplayString(&mDNSStorage, nsec3RR));
nsec3 = (rdataNSEC3 *)nsec3RR->rdata->u.data;
@@ -441,7 +436,7 @@ mDNSexport int AnonInfoAnswersQuestion(const ResourceRecord *const rr, const DNS
return 0;
- LogInfo("AnonInfoAnswersQuestion: ResourceRecord %s matched question %##s (%s)", RRDisplayStringBuf(nsec3RR, MsgBuffer), q->qname.c, DNSTypeName(q->qtype));
+ LogInfo("AnonInfoAnswersQuestion: ResourceRecord %s matched question %##s (%s)", RRDisplayString(&mDNSStorage, nsec3RR), q->qname.c, DNSTypeName(q->qtype));
return 1;
diff --git a/mDNSResponder/mDNSCore/mDNS.c b/mDNSResponder/mDNSCore/mDNS.c
index 6657255b..72375d94 100755
--- a/mDNSResponder/mDNSCore/mDNS.c
+++ b/mDNSResponder/mDNSCore/mDNS.c
@@ -14475,11 +14475,7 @@ mDNSlocal mStatus mDNS_InitStorage(mDNS *const m, mDNS_PlatformSupport *const p,
m->WABBrowseQueriesCount = 0;
m->WABLBrowseQueriesCount = 0;
m->WABRegQueriesCount = 0;
-#ifndef __rtems__
m->AutoTargetServices = 0;
-#else /* __rtems__ */
- m->AutoTargetServices = 1;
-#endif /* __rtems__ */
#if BONJOUR_ON_DEMAND
m->NumAllInterfaceRecords = 0;
diff --git a/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h b/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h
index 72ff7ca1..1962bb19 100755
--- a/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h
+++ b/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h
@@ -3632,46 +3632,6 @@ extern void D2D_stop_advertising_record(AuthRecord *ar);
-#ifdef __rtems__
-typedef struct
- // Client API fields: The client must set up name and InterfaceID *before* calling mDNS_StartResolveService()
- // When the callback is invoked, ip, port, TXTlen and TXTinfo will have been filled in with the results learned from the network.
- domainname name;
- mDNSInterfaceID InterfaceID; // ID of the interface the response was received on
- mDNSAddr ip; // Remote (destination) IP address where this service can be accessed
- mDNSIPPort port; // Port where this service can be accessed
- mDNSu16 TXTlen;
- mDNSu8 TXTinfo[2048]; // Additional demultiplexing information (e.g. LPR queue name)
-} ServiceInfo;
-// Note: Within an mDNSServiceInfoQueryCallback mDNS all API calls are legal except mDNS_Init(), mDNS_Exit(), mDNS_Execute()
-typedef struct ServiceInfoQuery_struct ServiceInfoQuery;
-typedef void mDNSServiceInfoQueryCallback (mDNS *const m, ServiceInfoQuery *query);
-struct ServiceInfoQuery_struct
- // Internal state fields. These are used internally by mDNSCore; the client layer needn't be concerned with them.
- // No fields need to be set up by the client prior to calling mDNS_StartResolveService();
- // all required data is passed as parameters to that function.
- // The ServiceInfoQuery structure memory is working storage for mDNSCore to discover the requested information
- // and place it in the ServiceInfo structure. After the client has called mDNS_StopResolveService(), it may
- // dispose of the ServiceInfoQuery structure while retaining the results in the ServiceInfo structure.
- DNSQuestion qSRV;
- DNSQuestion qTXT;
- DNSQuestion qAv4;
- DNSQuestion qAv6;
- mDNSu8 GotSRV;
- mDNSu8 GotTXT;
- mDNSu8 GotADD;
- mDNSu32 Answers;
- ServiceInfo *info;
- mDNSServiceInfoQueryCallback *ServiceInfoQueryCallback;
- void *ServiceInfoQueryContext;
-extern mStatus mDNS_StartResolveService(mDNS *const m, ServiceInfoQuery *query, ServiceInfo *info, mDNSServiceInfoQueryCallback *Callback, void *Context);
-extern void mDNS_StopResolveService (mDNS *const m, ServiceInfoQuery *query);
#ifdef __cplusplus
#endif
diff --git a/mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.1 b/mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.1
index 6836139c..c5a5d9c0 100644
--- a/mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.1
+++ b/mDNSResponder/mDNSMacOSX/BonjourTop/source/BonjourTop.1
@@ -1,79 +1,79 @@
-.\"Modified from man(1) of FreeBSD, the NetBSD mdoc.template, and mdoc.samples.
-.\"See Also:
-.\"man mdoc.samples for a complete listing of options
-.\"man mdoc for the short list of editing options
-.\"/usr/share/misc/mdoc.template
-.Dd 4/24/13 \" DATE
-.Dt BonjourTop 1 \" Program name and manual section number
-.Os Darwin
-.Sh NAME \" Section Header - required - don't modify
-.Nm BonjourTop,
-.\" The following lines are read in generating the apropos(man -k) database. Use only key
-.\" words here as the database is built based on the words here and in the .ND line.
-.Nm Other_name_for_same_program(),
-.Nm Yet another name for the same program.
-.\" Use .Nm macro to designate other names for the documented program.
-.Nd This line parsed for whatis database.
-.Sh SYNOPSIS \" Section Header - required - don't modify
-.Nm
-.Op Fl abcd \" [-abcd]
-.Op Fl a Ar path \" [-a path]
-.Op Ar file \" [file]
-.Op Ar \" [file ...]
-.Ar arg0 \" Underlined argument - use .Ar anywhere to underline
-arg2 ... \" Arguments
-.Sh DESCRIPTION \" Section Header - required - don't modify
-Use the .Nm macro to refer to your program throughout the man page like such:
-.Nm
-Underlining is accomplished with the .Ar macro like this:
-.Ar underlined text .
-.Pp \" Inserts a space
-A list of items with descriptions:
-.Bl -tag -width -indent \" Begins a tagged list
-.It item a \" Each item preceded by .It macro
-Description of item a
-.It item b
-Description of item b
-.El \" Ends the list
-.Pp
-A list of flags and their descriptions:
-.Bl -tag -width -indent \" Differs from above in tag removed
-.It Fl a \"-a flag as a list item
-Description of -a flag
-.It Fl b
-Description of -b flag
-.Pp
-.\" .Sh ENVIRONMENT \" May not be needed
-.\" .Bl -tag -width "ENV_VAR_1" -indent \" ENV_VAR_1 is width of the string ENV_VAR_1
-.\" .It Ev ENV_VAR_1
-.\" Description of ENV_VAR_1
-.\" .It Ev ENV_VAR_2
-.\" Description of ENV_VAR_2
-.\" .El
-.Sh FILES \" File used or created by the topic of the man page
-.Bl -tag -width "/Users/joeuser/Library/really_long_file_name" -compact
-.It Pa /usr/share/file_name
-FILE_1 description
-.It Pa /Users/joeuser/Library/really_long_file_name
-FILE_2 description
-.\" .Sh DIAGNOSTICS \" May not be needed
-.\" .Bl -diag
-.\" .It Diagnostic Tag
-.\" Diagnostic informtion here.
-.\" .El
-.Sh SEE ALSO
-.\" List links in ascending order by section, alphabetically within a section.
-.\" Please do not reference files that do not exist without filing a bug report
-.Xr a 1 ,
-.Xr b 1 ,
-.Xr c 1 ,
-.Xr a 2 ,
-.Xr b 2 ,
-.Xr a 3 ,
-.Xr b 3
-.\" .Sh BUGS \" Document known, unremedied bugs
+.\"Modified from man(1) of FreeBSD, the NetBSD mdoc.template, and mdoc.samples.
+.\"See Also:
+.\"man mdoc.samples for a complete listing of options
+.\"man mdoc for the short list of editing options
+.\"/usr/share/misc/mdoc.template
+.Dd 4/24/13 \" DATE
+.Dt BonjourTop 1 \" Program name and manual section number
+.Os Darwin
+.Sh NAME \" Section Header - required - don't modify
+.Nm BonjourTop,
+.\" The following lines are read in generating the apropos(man -k) database. Use only key
+.\" words here as the database is built based on the words here and in the .ND line.
+.Nm Other_name_for_same_program(),
+.Nm Yet another name for the same program.
+.\" Use .Nm macro to designate other names for the documented program.
+.Nd This line parsed for whatis database.
+.Sh SYNOPSIS \" Section Header - required - don't modify
+.Nm
+.Op Fl abcd \" [-abcd]
+.Op Fl a Ar path \" [-a path]
+.Op Ar file \" [file]
+.Op Ar \" [file ...]
+.Ar arg0 \" Underlined argument - use .Ar anywhere to underline
+arg2 ... \" Arguments
+.Sh DESCRIPTION \" Section Header - required - don't modify
+Use the .Nm macro to refer to your program throughout the man page like such:
+.Nm
+Underlining is accomplished with the .Ar macro like this:
+.Ar underlined text .
+.Pp \" Inserts a space
+A list of items with descriptions:
+.Bl -tag -width -indent \" Begins a tagged list
+.It item a \" Each item preceded by .It macro
+Description of item a
+.It item b
+Description of item b
+.El \" Ends the list
+.Pp
+A list of flags and their descriptions:
+.Bl -tag -width -indent \" Differs from above in tag removed
+.It Fl a \"-a flag as a list item
+Description of -a flag
+.It Fl b
+Description of -b flag
+.Pp
+.\" .Sh ENVIRONMENT \" May not be needed
+.\" .Bl -tag -width "ENV_VAR_1" -indent \" ENV_VAR_1 is width of the string ENV_VAR_1
+.\" .It Ev ENV_VAR_1
+.\" Description of ENV_VAR_1
+.\" .It Ev ENV_VAR_2
+.\" Description of ENV_VAR_2
+.\" .El
+.Sh FILES \" File used or created by the topic of the man page
+.Bl -tag -width "/Users/joeuser/Library/really_long_file_name" -compact
+.It Pa /usr/share/file_name
+FILE_1 description
+.It Pa /Users/joeuser/Library/really_long_file_name
+FILE_2 description
+.\" .Sh DIAGNOSTICS \" May not be needed
+.\" .Bl -diag
+.\" .It Diagnostic Tag
+.\" Diagnostic informtion here.
+.\" .El
+.Sh SEE ALSO
+.\" List links in ascending order by section, alphabetically within a section.
+.\" Please do not reference files that do not exist without filing a bug report
+.Xr a 1 ,
+.Xr b 1 ,
+.Xr c 1 ,
+.Xr a 2 ,
+.Xr b 2 ,
+.Xr a 3 ,
+.Xr b 3
+.\" .Sh BUGS \" Document known, unremedied bugs
.\" .Sh HISTORY \" Document history if command behaves in a unique manner
\ No newline at end of file
diff --git a/mDNSResponder/mDNSPosix/mDNSPosix.c b/mDNSResponder/mDNSPosix/mDNSPosix.c
index e567087b..0e10bd56 100755
--- a/mDNSResponder/mDNSPosix/mDNSPosix.c
+++ b/mDNSResponder/mDNSPosix/mDNSPosix.c
@@ -40,10 +40,6 @@
#include <netinet/in.h>
#include <arpa/inet.h>
#include <time.h> // platform support for UTC time
-#ifdef __rtems__
-#include <sys/param.h>
-#include <rtems/libio_.h>
#if USES_NETLINK
#include <asm/types.h>
@@ -80,12 +76,7 @@ struct IfChangeRec
typedef struct IfChangeRec IfChangeRec;
// Note that static data is initialized to zero in (modern) C.
-#ifndef __rtems__
static fd_set gEventFDs;
-static fd_set *gAllocatedEventFDs;
-#define gEventFDs (*gAllocatedEventFDs)
static int gMaxFD; // largest fd in gEventFDs
static GenLinkedList gEventSources; // linked list of PosixEventSource's
static sigset_t gEventSignalSet; // Signals which event loop listens for
@@ -448,15 +439,6 @@ mDNSexport mDNSBool mDNSPlatformSetDNSConfig(mDNSBool setservers, mDNSBool setse
(void) RegDomains;
(void) BrowseDomains;
(void) ackConfig;
-#ifdef __rtems__
- * Copied from mDNSMacOSX/mDNSMacOSX.c to prevent use of uninitialized
- * stack variables.
- if (fqdn ) fqdn->c[0] = 0;
- if (RegDomains ) *RegDomains = NULL;
- if (BrowseDomains) *BrowseDomains = NULL;
return mDNStrue;
@@ -675,7 +657,6 @@ mDNSlocal int SetupSocket(struct sockaddr *intfAddr, mDNSIPPort port, int interf
#endif
if (err < 0) { err = errno; perror("setsockopt - SO_REUSExxxx"); }
-#ifndef __rtems__
// Enable inbound packets on IFEF_AWDL interface.
// Only done for multicast sockets, since we don't expect unicast socket operations
// on the IFEF_AWDL interface. Operation is a no-op for other interface types.
@@ -683,7 +664,6 @@ mDNSlocal int SetupSocket(struct sockaddr *intfAddr, mDNSIPPort port, int interf
#define SO_RECV_ANYIF 0x1104 /* unrestricted inbound processing */
#endif
if (setsockopt(*sktPtr, SOL_SOCKET, SO_RECV_ANYIF, &kOn, sizeof(kOn)) < 0) perror("setsockopt - SO_RECV_ANYIF");
// We want to receive destination addresses and interface identifiers.
@@ -1228,23 +1208,14 @@ mDNSlocal mDNSu32 ProcessRoutingNotification(int sd)
mDNSlocal void InterfaceChangeCallback(int fd, short filter, void *context)
IfChangeRec *pChgRec = (IfChangeRec*) context;
-#ifndef __rtems__
fd_set readFDs;
- fd_set bigEnoughReadFDs[howmany(rtems_libio_number_iops, sizeof(fd_set) * 8)];
-#define readFDs (*(&bigEnoughReadFDs[0]))
mDNSu32 changedInterfaces = 0;
struct timeval zeroTimeout = { 0, 0 };
(void)fd; // Unused
(void)filter; // Unused
-#ifndef __rtems__
FD_ZERO(&readFDs);
- memset(bigEnoughReadFDs, 0, sizeof(bigEnoughReadFDs));
FD_SET(pChgRec->NotifySD, &readFDs);
do
@@ -1301,9 +1272,6 @@ mDNSexport mStatus mDNSPlatformInit(mDNS *const m)
int err = 0;
struct sockaddr sa;
-#ifdef __rtems__
- pthread_mutexattr_t attr;
assert(m != NULL);
if (mDNSPlatformInit_CanReceiveUnicast()) m->CanReceiveUnicastOn5353 = mDNStrue;
@@ -1321,16 +1289,6 @@ mDNSexport mStatus mDNSPlatformInit(mDNS *const m)
if (m->hostlabel.c[0] == 0) MakeDomainLabelFromLiteralString(&m->hostlabel, "Computer");
mDNS_SetFQDN(m);
-#ifdef __rtems__
- if (err == mStatus_NoError) {
- gAllocatedEventFDs = calloc(howmany(rtems_libio_number_iops, sizeof(fd_set) * 8), sizeof(fd_set));
- if (gAllocatedEventFDs == NULL) err = mStatus_NoMemoryErr;
- if (err == mStatus_NoError) err = pthread_mutexattr_init(&attr);
- if (err == mStatus_NoError) err = pthread_mutexattr_setprotocol(&attr, PTHREAD_PRIO_INHERIT);
- if (err == mStatus_NoError) err = pthread_mutex_init(&m->p->mutex, &attr);
- if (err == mStatus_NoError) err = pthread_mutexattr_destroy(&attr);
sa.sa_family = AF_INET;
m->p->unicastSocket4 = -1;
@@ -1415,22 +1373,14 @@ mDNSexport mStatus mDNSPlatformPosixRefreshInterfaceList(mDNS *const m)
// the platform from reentering mDNS core code.
mDNSexport void mDNSPlatformLock (const mDNS *const m)
-#ifndef __rtems__
(void) m; // Unused
- pthread_mutex_lock(&m->p->mutex);
// mDNS core calls this routine when it release the lock taken by
// mDNSPlatformLock and allow the platform to reenter mDNS core code.
mDNSexport void mDNSPlatformUnlock (const mDNS *const m)
-#ifndef __rtems__
(void) m; // Unused
- pthread_mutex_unlock(&m->p->mutex);
#if COMPILER_LIKES_PRAGMA_MARK
@@ -1553,7 +1503,7 @@ mDNSexport void mDNSPlatformMemZero(void *dst, mDNSu32 len)
memset(dst, 0, len);
-mDNSexport void * mDNSPlatformMemAllocate(mDNSu32 len) { return(calloc(1, len)); }
+mDNSexport void * mDNSPlatformMemAllocate(mDNSu32 len) { return(malloc(len)); }
mDNSexport void mDNSPlatformMemFree (void *mem) { free(mem); }
#if _PLATFORM_HAS_STRONG_PRNG_
@@ -1804,10 +1754,8 @@ mStatus mDNSPosixAddFDToEventLoop(int fd, mDNSPosixEventCallback callback, void
if (gEventSources.LinkOffset == 0)
InitLinkedList(&gEventSources, offsetof(PosixEventSource, Next));
-#ifndef __rtems__
if (fd >= (int) FD_SETSIZE || fd < 0)
return mStatus_UnsupportedErr;
if (callback == NULL)
return mStatus_BadParamErr;
@@ -1887,13 +1835,7 @@ mStatus mDNSPosixIgnoreSignalInEventLoop(int signum)
mStatus mDNSPosixRunEventLoopOnce(mDNS *m, const struct timeval *pTimeout,
sigset_t *pSignalsReceived, mDNSBool *pDataDispatched)
-#ifndef __rtems__
fd_set listenFDs = gEventFDs;
- fd_set bigEnoughListenFDs[howmany(rtems_libio_number_iops, sizeof(fd_set) * 8)];
-#define listenFDs (*(&bigEnoughListenFDs[0]))
- memcpy(bigEnoughListenFDs, gAllocatedEventFDs, sizeof(bigEnoughListenFDs));
int fdMax = 0, numReady;
struct timeval timeout = *pTimeout;
diff --git a/mDNSResponder/mDNSPosix/mDNSPosix.h b/mDNSResponder/mDNSPosix/mDNSPosix.h
index acff9c33..ca60d806 100755
--- a/mDNSResponder/mDNSPosix/mDNSPosix.h
+++ b/mDNSResponder/mDNSPosix/mDNSPosix.h
@@ -20,9 +20,6 @@
#include <signal.h>
#include <sys/time.h>
-#ifdef __rtems__
-#include <pthread.h>
#ifdef __cplusplus
extern "C" {
@@ -58,9 +55,6 @@ struct mDNS_PlatformSupport_struct
#if HAVE_IPV6
int unicastSocket6;
#endif
-#ifdef __rtems__
- pthread_mutex_t mutex;
#define uDNS_SERVERS_FILE "/etc/resolv.conf"
diff --git a/mDNSResponder/mDNSPosix/mDNSUNP.c b/mDNSResponder/mDNSPosix/mDNSUNP.c
index a7aafb27..17a37c61 100755
--- a/mDNSResponder/mDNSPosix/mDNSUNP.c
+++ b/mDNSResponder/mDNSPosix/mDNSUNP.c
@@ -244,7 +244,7 @@ struct ifi_info *get_ifi_info(int family, int doaliases)
lastlen = 0;
len = 100 * sizeof(struct ifreq); /* initial buffer size guess */
for ( ; ; ) {
- buf = (char*)calloc(1, len);
+ buf = (char*)malloc(len);
if (buf == NULL) {
goto gotError;
diff --git a/mDNSResponder/mDNSResponder.sln b/mDNSResponder/mDNSResponder.sln
index 8cd5bf74..c93f95a4 100755
--- a/mDNSResponder/mDNSResponder.sln
+++ b/mDNSResponder/mDNSResponder.sln
@@ -9,18 +9,33 @@ EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "mdnsNSP", "mDNSWindows\mdnsNSP\mdnsNSP.vcxproj", "{F4F15529-F0EB-402F-8662-73C5797EE557}"
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ExplorerPlugin", "Clients\ExplorerPlugin\ExplorerPlugin.vcxproj", "{BB8AC1B5-6587-4163-BDC6-788B157705CA}"
+ ProjectSection(ProjectDependencies) = postProject
+ {1643427B-F226-4AD6-B413-97DA64D5C6B4} = {1643427B-F226-4AD6-B413-97DA64D5C6B4}
+ EndProjectSection
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PrinterSetupWizard", "Clients\PrinterSetupWizard\PrinterSetupWizard.vcxproj", "{B1D2CDA2-CC8F-45D5-A694-2EE45B0308CF}"
+ {967F5375-0176-43D3-ADA3-22EE25551C37} = {967F5375-0176-43D3-ADA3-22EE25551C37}
+ EndProjectSection
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PrinterSetupWizardLocRes", "Clients\PrinterSetupWizard\PrinterSetupWizardLocRes.vcxproj", "{967F5375-0176-43D3-ADA3-22EE25551C37}"
+ {CFCCB176-6CAA-472B-B0A2-90511C8E2E52} = {CFCCB176-6CAA-472B-B0A2-90511C8E2E52}
+ EndProjectSection
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "PrinterSetupWizardRes", "Clients\PrinterSetupWizard\PrinterSetupWizardRes.vcxproj", "{CFCCB176-6CAA-472B-B0A2-90511C8E2E52}"
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ExplorerPluginLocRes", "Clients\ExplorerPlugin\ExplorerPluginLocRes.vcxproj", "{1643427B-F226-4AD6-B413-97DA64D5C6B4}"
+ {871B1492-B4A4-4B57-9237-FA798484D7D7} = {871B1492-B4A4-4B57-9237-FA798484D7D7}
+ EndProjectSection
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ExplorerPluginRes", "Clients\ExplorerPlugin\ExplorerPluginRes.vcxproj", "{871B1492-B4A4-4B57-9237-FA798484D7D7}"
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "dns-sd", "Clients\DNS-SD.VisualStudio\dns-sd.vcxproj", "{AA230639-E115-4A44-AA5A-44A61235BA50}"
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E} = {AB581101-18F0-46F6-B56A-83A6B1EA657E}
+ EndProjectSection
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Java", "mDNSWindows\Java\Java.vcxproj", "{9CE2568A-3170-41C6-9F20-A0188A9EC114}"
EndProject
@@ -37,10 +52,16 @@ EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "mDNSNetMonitor", "Clients\mDNSNetMonitor.VisualStudio\mDNSNetMonitor.vcxproj", "{AF35C285-528D-46A1-8A0E-47B0733DC718}"
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ControlPanelLocRes", "mDNSWindows\ControlPanel\ControlPanelLocRes.vcxproj", "{4490229E-025A-478F-A2CF-51154DA83E39}"
+ {5254AA9C-3D2E-4539-86D9-5EB0F4151215} = {5254AA9C-3D2E-4539-86D9-5EB0F4151215}
+ EndProjectSection
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ControlPanelRes", "mDNSWindows\ControlPanel\ControlPanelRes.vcxproj", "{5254AA9C-3D2E-4539-86D9-5EB0F4151215}"
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ControlPanel", "mDNSWindows\ControlPanel\ControlPanel.vcxproj", "{0DF09484-B4C2-4AB4-9FC0-7B091ADEAFEB}"
+ {4490229E-025A-478F-A2CF-51154DA83E39} = {4490229E-025A-478F-A2CF-51154DA83E39}
+ EndProjectSection
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "FirefoxExtension", "Clients\FirefoxExtension\FirefoxExtension.vcxproj", "{7826EA27-D4CC-4FAA-AD23-DF813823227B}"
EndProject
diff --git a/mDNSResponder/mDNSShared/dnssd_clientshim.c b/mDNSResponder/mDNSShared/dnssd_clientshim.c
index b4824b4d..c0a309d5 100644
--- a/mDNSResponder/mDNSShared/dnssd_clientshim.c
+++ b/mDNSResponder/mDNSShared/dnssd_clientshim.c
@@ -25,8 +25,6 @@
#include "dns_sd.h" // Defines the interface to the client layer above
#include "mDNSEmbeddedAPI.h" // The interface we're building on top of
-#include <sys/socket.h>
-#include <netinet/in.h>
extern mDNS mDNSStorage; // We need to pass the address of this storage to the lower-layer functions
#if MDNS_BUILDINGSHAREDLIBRARY || MDNS_BUILDINGSTUBLIBRARY
@@ -70,14 +68,6 @@ typedef struct
DNSQuestion q;
} mDNS_DirectOP_Browse;
-typedef struct
- mDNS_DirectOP_Dispose *disposefn;
- DNSServiceRef aQuery;
- DNSServiceGetAddrInfoReply callback;
- void *context;
-} mDNS_DirectOP_GetAddrInfo;
typedef struct
@@ -684,7 +674,7 @@ DNSServiceErrorType DNSServiceQueryRecord
x->q.ExpectUnique = mDNSfalse;
x->q.ForceMCast = (flags & kDNSServiceFlagsForceMulticast) != 0;
x->q.ReturnIntermed = (flags & kDNSServiceFlagsReturnIntermediates) != 0;
- x->q.SuppressUnusable = (flags & kDNSServiceFlagsSuppressUnusable) != 0;
+ x->q.SuppressUnsable = (flags & kDNSServiceFlagsSuppressUnusable) != 0;
x->q.SearchListIndex = 0;
x->q.AppendSearchDomains = 0;
x->q.RetryWithSearchDomains = mDNSfalse;
diff --git a/mDNSResponder/mDNSShared/mDNSDebug.c b/mDNSResponder/mDNSShared/mDNSDebug.c
index 6c0781c3..1243ae77 100644
--- a/mDNSResponder/mDNSShared/mDNSDebug.c
+++ b/mDNSResponder/mDNSShared/mDNSDebug.c
@@ -60,11 +60,7 @@ mDNSlocal void LogMsgWithLevelv(mDNSLogLevel_t logLevel, const char *format, va_
char buffer[512];
buffer[mDNS_vsnprintf((char *)buffer, sizeof(buffer), format, ptr)] = 0;
-#ifndef __rtems__
mDNSPlatformWriteLogMsg(ProgramName, buffer, logLevel);
- mDNSPlatformWriteLogMsg(NULL, buffer, logLevel);
#define LOG_HELPER_BODY(L) \
diff --git a/mDNSResponder/mDNSWindows/BonjourQuickLooks.sln b/mDNSResponder/mDNSWindows/BonjourQuickLooks.sln
index cef4fe62..3b1cbe75 100644
--- a/mDNSResponder/mDNSWindows/BonjourQuickLooks.sln
+++ b/mDNSResponder/mDNSWindows/BonjourQuickLooks.sln
@@ -1,81 +1,81 @@
-Microsoft Visual Studio Solution File, Format Version 11.00
-# Visual Studio 2010
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL", "DLL\dnssd.vcxproj", "{AB581101-18F0-46F6-B56A-83A6B1EA657E}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "mDNSResponder", "SystemService\Service.vcxproj", "{C1D98254-BA27-4427-A3BE-A68CA2CC5F69}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "mdnsNSP", "mdnsNSP\mdnsNSP.vcxproj", "{F4F15529-F0EB-402F-8662-73C5797EE557}"
-EndProject
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "dns-sd", "..\Clients\DNS-SD.VisualStudio\dns-sd.vcxproj", "{AA230639-E115-4A44-AA5A-44A61235BA50}"
- ProjectSection(ProjectDependencies) = postProject
- {AB581101-18F0-46F6-B56A-83A6B1EA657E} = {AB581101-18F0-46F6-B56A-83A6B1EA657E}
- EndProjectSection
-EndProject
-Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "BonjourQuickLooksInstaller", "BonjourQuickLooksInstaller\BonjourQuickLooksInstaller.wixproj", "{E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}"
-EndProject
-Global
- GlobalSection(SolutionConfigurationPlatforms) = preSolution
- Debug|Win32 = Debug|Win32
- Debug|x64 = Debug|x64
- Debug|x86 = Debug|x86
- Release|Win32 = Release|Win32
- Release|x64 = Release|x64
- Release|x86 = Release|x86
- EndGlobalSection
- GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|Win32.ActiveCfg = Debug|Win32
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|Win32.Build.0 = Debug|Win32
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|x64.ActiveCfg = Debug|x64
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|x64.Build.0 = Debug|x64
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|x86.ActiveCfg = Debug|Win32
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|Win32.ActiveCfg = Release|Win32
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|Win32.Build.0 = Release|Win32
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|x64.ActiveCfg = Release|x64
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|x64.Build.0 = Release|x64
- {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|x86.ActiveCfg = Release|Win32
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|Win32.ActiveCfg = Debug|Win32
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|Win32.Build.0 = Debug|Win32
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|x64.ActiveCfg = Debug|x64
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|x64.Build.0 = Debug|x64
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|x86.ActiveCfg = Debug|Win32
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|Win32.ActiveCfg = Release|Win32
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|Win32.Build.0 = Release|Win32
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|x64.ActiveCfg = Release|x64
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|x64.Build.0 = Release|x64
- {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|x86.ActiveCfg = Release|Win32
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|Win32.ActiveCfg = Debug|Win32
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|Win32.Build.0 = Debug|Win32
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|x64.ActiveCfg = Debug|x64
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|x64.Build.0 = Debug|x64
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|x86.ActiveCfg = Debug|Win32
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|Win32.ActiveCfg = Release|Win32
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|Win32.Build.0 = Release|Win32
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|x64.ActiveCfg = Release|x64
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|x64.Build.0 = Release|x64
- {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|x86.ActiveCfg = Release|Win32
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|Win32.ActiveCfg = Debug|Win32
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|Win32.Build.0 = Debug|Win32
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|x64.ActiveCfg = Debug|x64
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|x64.Build.0 = Debug|x64
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|x86.ActiveCfg = Debug|Win32
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|Win32.ActiveCfg = Release|Win32
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|Win32.Build.0 = Release|Win32
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|x64.ActiveCfg = Release|x64
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|x64.Build.0 = Release|x64
- {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|x86.ActiveCfg = Release|Win32
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|Win32.ActiveCfg = Debug|x86
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|x64.ActiveCfg = Debug|x64
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|x64.Build.0 = Debug|x64
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|x86.ActiveCfg = Debug|x86
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|x86.Build.0 = Debug|x86
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|Win32.ActiveCfg = Release|x86
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|x64.ActiveCfg = Release|x64
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|x64.Build.0 = Release|x64
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|x86.ActiveCfg = Release|x86
- {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|x86.Build.0 = Release|x86
- EndGlobalSection
- GlobalSection(SolutionProperties) = preSolution
- HideSolutionNode = FALSE
- EndGlobalSection
-EndGlobal
+Microsoft Visual Studio Solution File, Format Version 11.00
+# Visual Studio 2010
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "DLL", "DLL\dnssd.vcxproj", "{AB581101-18F0-46F6-B56A-83A6B1EA657E}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "mDNSResponder", "SystemService\Service.vcxproj", "{C1D98254-BA27-4427-A3BE-A68CA2CC5F69}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "mdnsNSP", "mdnsNSP\mdnsNSP.vcxproj", "{F4F15529-F0EB-402F-8662-73C5797EE557}"
+EndProject
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "dns-sd", "..\Clients\DNS-SD.VisualStudio\dns-sd.vcxproj", "{AA230639-E115-4A44-AA5A-44A61235BA50}"
+ EndProjectSection
+EndProject
+Project("{930C7802-8A8C-48F9-8165-68863BCCD9DD}") = "BonjourQuickLooksInstaller", "BonjourQuickLooksInstaller\BonjourQuickLooksInstaller.wixproj", "{E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}"
+EndProject
+Global
+ GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|Win32 = Debug|Win32
+ Debug|x64 = Debug|x64
+ Debug|x86 = Debug|x86
+ Release|Win32 = Release|Win32
+ Release|x64 = Release|x64
+ Release|x86 = Release|x86
+ EndGlobalSection
+ GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|Win32.Build.0 = Debug|Win32
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|x64.ActiveCfg = Debug|x64
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|x64.Build.0 = Debug|x64
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Debug|x86.ActiveCfg = Debug|Win32
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|Win32.ActiveCfg = Release|Win32
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|Win32.Build.0 = Release|Win32
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|x64.ActiveCfg = Release|x64
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|x64.Build.0 = Release|x64
+ {AB581101-18F0-46F6-B56A-83A6B1EA657E}.Release|x86.ActiveCfg = Release|Win32
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|Win32.ActiveCfg = Debug|Win32
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|Win32.Build.0 = Debug|Win32
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|x64.ActiveCfg = Debug|x64
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|x64.Build.0 = Debug|x64
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Debug|x86.ActiveCfg = Debug|Win32
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|Win32.ActiveCfg = Release|Win32
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|Win32.Build.0 = Release|Win32
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|x64.ActiveCfg = Release|x64
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|x64.Build.0 = Release|x64
+ {C1D98254-BA27-4427-A3BE-A68CA2CC5F69}.Release|x86.ActiveCfg = Release|Win32
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|Win32.ActiveCfg = Debug|Win32
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|Win32.Build.0 = Debug|Win32
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|x64.ActiveCfg = Debug|x64
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|x64.Build.0 = Debug|x64
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Debug|x86.ActiveCfg = Debug|Win32
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|Win32.ActiveCfg = Release|Win32
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|Win32.Build.0 = Release|Win32
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|x64.ActiveCfg = Release|x64
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|x64.Build.0 = Release|x64
+ {F4F15529-F0EB-402F-8662-73C5797EE557}.Release|x86.ActiveCfg = Release|Win32
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|Win32.ActiveCfg = Debug|Win32
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|Win32.Build.0 = Debug|Win32
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|x64.ActiveCfg = Debug|x64
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|x64.Build.0 = Debug|x64
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Debug|x86.ActiveCfg = Debug|Win32
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|Win32.ActiveCfg = Release|Win32
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|Win32.Build.0 = Release|Win32
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|x64.ActiveCfg = Release|x64
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|x64.Build.0 = Release|x64
+ {AA230639-E115-4A44-AA5A-44A61235BA50}.Release|x86.ActiveCfg = Release|Win32
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|Win32.ActiveCfg = Debug|x86
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|x64.ActiveCfg = Debug|x64
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|x64.Build.0 = Debug|x64
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|x86.ActiveCfg = Debug|x86
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Debug|x86.Build.0 = Debug|x86
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|Win32.ActiveCfg = Release|x86
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|x64.ActiveCfg = Release|x64
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|x64.Build.0 = Release|x64
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|x86.ActiveCfg = Release|x86
+ {E24A4DC1-9B6F-4DA4-BD76-7D5FE73732BF}.Release|x86.Build.0 = Release|x86
+ EndGlobalSection
+ GlobalSection(SolutionProperties) = preSolution
+ HideSolutionNode = FALSE
+ EndGlobalSection
+EndGlobal
diff --git a/mDNSResponder/mDNSWindows/BonjourQuickLooksInstaller/BonjourQuickLooksInstaller.wixproj b/mDNSResponder/mDNSWindows/BonjourQuickLooksInstaller/BonjourQuickLooksInstaller.wixproj
index f98a8505..9c0520ca 100644
--- a/mDNSResponder/mDNSWindows/BonjourQuickLooksInstaller/BonjourQuickLooksInstaller.wixproj
+++ b/mDNSResponder/mDNSWindows/BonjourQuickLooksInstaller/BonjourQuickLooksInstaller.wixproj
@@ -1,85 +1,85 @@
-<?xml version="1.0" encoding="utf-8"?>
-<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <PropertyGroup>
- <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
- <Platform Condition=" '$(Platform)' == '' ">x86</Platform>
- <ProductVersion>3.10</ProductVersion>
- <ProjectGuid>e24a4dc1-9b6f-4da4-bd76-7d5fe73732bf</ProjectGuid>
- <SchemaVersion>2.0</SchemaVersion>
- <OutputName>BonjourQuickLooks</OutputName>
- <OutputType>Package</OutputType>
- <WixTargetsPath Condition=" '$(WixTargetsPath)' == '' AND '$(MSBuildExtensionsPath32)' != '' ">$(MSBuildExtensionsPath32)\Microsoft\WiX\v3.x\Wix.targets</WixTargetsPath>
- <WixTargetsPath Condition=" '$(WixTargetsPath)' == '' ">$(MSBuildExtensionsPath)\Microsoft\WiX\v3.x\Wix.targets</WixTargetsPath>
- <Name>BonjourQuickLooksInstaller</Name>
- </PropertyGroup>
- <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x86' ">
- <OutputPath>bin\$(Platform)\$(Configuration)\</OutputPath>
- <IntermediateOutputPath>obj\$(Platform)\$(Configuration)\</IntermediateOutputPath>
- <DefineConstants>Debug</DefineConstants>
- </PropertyGroup>
- <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x86' ">
- </PropertyGroup>
- <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x64' ">
- </PropertyGroup>
- <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x64' ">
- </PropertyGroup>
- <ItemGroup>
- <Compile Include="Product.wxs" />
- </ItemGroup>
- <ItemGroup>
- <ProjectReference Include="..\..\Clients\DNS-SD.VisualStudio\dns-sd.vcxproj">
- <Name>dns-sd</Name>
- <Project>{aa230639-e115-4a44-aa5a-44a61235ba50}</Project>
- <Private>True</Private>
- <DoNotHarvest>True</DoNotHarvest>
- <RefProjectOutputGroups>Binaries;Content;Satellites</RefProjectOutputGroups>
- <RefTargetDir>INSTALLFOLDER</RefTargetDir>
- </ProjectReference>
- <ProjectReference Include="..\DLL\dnssd.vcxproj">
- <Name>DLL</Name>
- <Project>{ab581101-18f0-46f6-b56a-83a6b1ea657e}</Project>
- <ProjectReference Include="..\mdnsNSP\mdnsNSP.vcxproj">
- <Name>mdnsNSP</Name>
- <Project>{f4f15529-f0eb-402f-8662-73c5797ee557}</Project>
- <ProjectReference Include="..\SystemService\Service.vcxproj">
- <Name>mDNSResponder</Name>
- <Project>{c1d98254-ba27-4427-a3be-a68ca2cc5f69}</Project>
- </ItemGroup>
- <ItemGroup>
- <WixExtension Include="WixFirewallExtension">
- <HintPath>$(WixExtDir)\WixFirewallExtension.dll</HintPath>
- <Name>WixFirewallExtension</Name>
- </WixExtension>
- </ItemGroup>
- <Import Project="$(WixTargetsPath)" />
- To modify your build process, add your task inside one of the targets below and uncomment it.
- Other similar extension points exist, see Wix.targets.
- <Target Name="BeforeBuild">
- </Target>
- <Target Name="AfterBuild">
- </Target>
-</Project>
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">x86</Platform>
+ <ProductVersion>3.10</ProductVersion>
+ <ProjectGuid>e24a4dc1-9b6f-4da4-bd76-7d5fe73732bf</ProjectGuid>
+ <SchemaVersion>2.0</SchemaVersion>
+ <OutputName>BonjourQuickLooks</OutputName>
+ <OutputType>Package</OutputType>
+ <WixTargetsPath Condition=" '$(WixTargetsPath)' == '' AND '$(MSBuildExtensionsPath32)' != '' ">$(MSBuildExtensionsPath32)\Microsoft\WiX\v3.x\Wix.targets</WixTargetsPath>
+ <WixTargetsPath Condition=" '$(WixTargetsPath)' == '' ">$(MSBuildExtensionsPath)\Microsoft\WiX\v3.x\Wix.targets</WixTargetsPath>
+ <Name>BonjourQuickLooksInstaller</Name>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x86' ">
+ <OutputPath>bin\$(Platform)\$(Configuration)\</OutputPath>
+ <IntermediateOutputPath>obj\$(Platform)\$(Configuration)\</IntermediateOutputPath>
+ <DefineConstants>Debug</DefineConstants>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x86' ">
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x64' ">
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x64' ">
+ </PropertyGroup>
+ <ItemGroup>
+ <Compile Include="Product.wxs" />
+ </ItemGroup>
+ <ItemGroup>
+ <ProjectReference Include="..\..\Clients\DNS-SD.VisualStudio\dns-sd.vcxproj">
+ <Name>dns-sd</Name>
+ <Project>{aa230639-e115-4a44-aa5a-44a61235ba50}</Project>
+ <Private>True</Private>
+ <DoNotHarvest>True</DoNotHarvest>
+ <RefProjectOutputGroups>Binaries;Content;Satellites</RefProjectOutputGroups>
+ <RefTargetDir>INSTALLFOLDER</RefTargetDir>
+ </ProjectReference>
+ <ProjectReference Include="..\DLL\dnssd.vcxproj">
+ <Name>DLL</Name>
+ <Project>{ab581101-18f0-46f6-b56a-83a6b1ea657e}</Project>
+ <ProjectReference Include="..\mdnsNSP\mdnsNSP.vcxproj">
+ <Name>mdnsNSP</Name>
+ <Project>{f4f15529-f0eb-402f-8662-73c5797ee557}</Project>
+ <ProjectReference Include="..\SystemService\Service.vcxproj">
+ <Name>mDNSResponder</Name>
+ <Project>{c1d98254-ba27-4427-a3be-a68ca2cc5f69}</Project>
+ </ItemGroup>
+ <ItemGroup>
+ <WixExtension Include="WixFirewallExtension">
+ <HintPath>$(WixExtDir)\WixFirewallExtension.dll</HintPath>
+ <Name>WixFirewallExtension</Name>
+ </WixExtension>
+ </ItemGroup>
+ <Import Project="$(WixTargetsPath)" />
+ To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Wix.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+</Project>
2.26.2
